Alex's Fourtress - Mini Tourny
  • Alex's Fourtress - Mini Tourny
    That right, against all probability I'm writing a *new* vapour tourny. No, this isn't some kind of Cthulian awakening that'll cause people's minds to collapse in on themselves in despair. Probably about the same level of probability, but it's not *quite* that bad.
    Anyway, to have a tournament so miniture even I can finish it in one sitting - there shall be four spaces only. Hence the dreadful punning name. Four spaces, one robot each, no reservations. If you want to give tactics, give brief tactics against your 3 potential opponents, don't wait for me to do draws as I'm going to write this in one sitting.
    Standard rules apply, and a newly modified version of my classic VGC arena.
    I'm too lazy to illustrate it, but essentially, it is a square with my classic 5ft thick tungsten walls, and instead of 1 side of the arena being a pit, now it is every corner, going up about 1/4ish the length of the wall. The bit goes down into the deepesh abyss of the netherworlds. Or a few feet onto some chipboard matting, whichever you prefer.
    Also, as this is meant to be quick, I'm not going to go back to you if I have questions about your stats, because I shouldn't have to. I'll write them as I read them and carry that to any logical conclusions it needs to, so that serves as incentive for nice tightly wording.
    Now - entries please - first come first serve.
    Re: Alex's Fourtress - Mini Tourny
    I will enter this one with Under Pressure http://strickenone.proboards.com/index. ... =thvapours
      Gabriel V please
      http://strickenone.proboards.com/index. ... 164&page=1
        Axeon 4.0 for me please.
          Tallit please.
            ...beaten by Mark. Oh the shame...
              Lol. Hey Alex! Would you maybe do us the favour of adding 4 more spots so Kody and 3 other people can enter?
                Nah, it's okay. :P
                  Oh.
                  Well anyways: Tactics:
                  If I face Under Pressure: Raise the lifting arm, get underneath Under Pressure, and clamp down with the lifting arm ala The Big Cheese vs Anorakaphobia, shove it into any pit, nuff said. If I suffer any damage, just shake it off and continue pushing.
                  If I face Axeon 4.0: Raise the lifting arm, get under the side of Axeon 4.0, then clamp down with the lifting arm. Then, shove it into the nearest pit.
                  If I face Gabriel V: Get over towards a pit and try to lure Gabriel over. If he comes over, use my superior pushing power to shove Gabriel into the pit.
                    Tactics:
                    Under Pressure: The shape of the robot should make the jaws slide up the skirts, up the front, and be useless as they meet right above the flipper...in theory. Even considering that, avoid the jaws just in case I turn out to be talking bollocks :P and get it around the sides and back if possible, flip it around and over the edge if possible.
                    Tallit: Don't fall for Mark's luring into the pit - keep the action towards the centre and flip it around, get it with the spikes a few times, and generally I have the capacity to jolt it around a bit more with powerful flips and also do more damage than it can. Use flips sparingly after the first two or three though since I want my gas to last the whole fight; revert to ramming and spiking after that and only use the flipper to either self right or if a golden opportunity to pit it comes along. Generally rack up points for damage and aggression for the judges. (If he stays in the corner, go thwackbot and build up rotational energy until he has to come over :P)
                    Axeon 3.0: Avoid as much as possible the area between the front prongs, go for the sides and rear, ram it, flip it, spike it, pit it, push it, pin it, tumble it, flick it, stop that pigeon NOW!
                    Best of luck Kody and Andy, and, uh, Mark as well I guess.
                      Updated Tactics:
                      If I face Gabriel V: Get over towards a pit and stay in the corner. If he goes thwackbot, stay in the corner and do not go after him. He'll be using his battery power up, while I'll have more juice. Keep the lifter raised, so if I get under him, I can repeat my Under Pressure/Axeon 4.0 tactics on him(clamp down with the lifting arm and pit him. Anyways, it'll be nice to see how the clone does against the original.
                        Are you feeling alright, Joey?
                          ...I meant 4.0 and Marti respectively, sorry the last one was intended though, reference to some cartoon or other.
                          Last time I worked it out 9.2ah was about enough power to run those two motors for ten minutes at near to full power, so if Mark believes I will be running out of juice he is quite frankly barking up the wrong tree.
                            Tactics:
                            Axeon 4.0 vs. Under Pressure
                            The shape of Axeon 4.0 means that Under Pressure is going to find it difficult to get the claws around it and crush. I€™m going to try and use my manoeuvrability to get round the back of Under Pressure. Once there I can fire the axe and try to damage the wheels and/or the hydraulic ram. By wedging underneath it looks like I could lift Under Pressure€™s wheels off the ground and push it about easily.
                            Axeon 4.0 vs. Gabriel V
                            Again, to be able to control the match I need to get to the sides or rear. Keep firing the axe and try to cause some damage. Aim for the edges - that€™s probably my best chance. Another idea is to try and grapple with the ears and drag Gabriel V around.
                            Axeon 4.0 vs. Tallit
                            Due to the shape similarity, I€™ll use the same tactics here as against Gabriel V. Keep to the sides and rear and try to hit the edges with the axe. The benefit here is that I should be much more manoeuvrable due to Tallit€™s shuffle pads. Because of this I should be able to avoid the lifting arm.
                            Good luck Martijn, Joey and Mark.
                              Just rolled the draws...
                              Under Pressure (Martijn) vs Tallit (Mark)
                              Axeon 4.0 (Andy) vs. Gabriel V (Joey)
                              I aim to have it all written up wand done in the next 24hours!
