Re: FRFFT: Series Three
Okay. I know those above are supposed to be my tactics, but well... Everyone hates me and is trying to get me(except Tira), so...
Run in and break the torsion spring on the rear skirt of Brutalis 2.1. Then, flip it out of the arena. Try to conserve flips, as once I have Brutalis out, only Nidhogg Cubed can try and get me OOTA. Then, get around Nidhogg and shove it into the CPZ. get underneath the sides, and try to flip it into Tira's spinning disc. That 3mm ti/vanadium alloy will be mangled badly. Afterwards, flip Nidhogg OOTA, and if I can't, try to hit the pit release button and shove him down. Since the shapes of the forks are a hybrid between Haardvark's and PA's, it should give me ample time to drive backwards and get away. Do not go after Tira unless it comes after me. When Nodhogg is inverted, try to shove him onto either the flames(it should burn his Petrol Engine), or the angle grinders(should cut the weak ti/van).
Now, If nobody else tries to attack me first, I'll be fine.
