BAC
  • BAC
    Ben's antweight competition
    Long time no see everyone!
    I am not going to complete Scrapyard Skirmish, I tried to go too fast
    So I am starting from scratch, I need 6 people to enter 2 antwieghts each
    Rules:
    150g rollers
    220g walkers/shufflers
    No flying robots
    No prohibited weapons
    Clusterbots allowed
    Max parts: 2
    Both parts have to be eliminated
    Combat will take place in the RRC (Reading Robot Club) arena
    Please enter!
    Re: BAC
    I shall enter with Anty B (Extreme 2 Version) and Combatant (Extreme 1 Version)
      Re: BAC
      BEN! It's been a while
      I'll enter Bobcat (stats on ZED) and Eye Of Ran AW (the stats of which will be dredged up by me once I am back on my laptop this evening)
        Re: BAC
        il enter my own real ant: ValliANT Evo and pete w's: defiant
        jack
          Re: BAC
          Good to see you back, Ben. Shame about Skirmish, though.
          I'll enter Flamberge (stats will be posted in my next post) and a new AW coming up very soon. Probably won't have a render for it right away, but hey, stats are better than nothing, ey?
            Re: BAC
            I suppose I shall enter
            I'll enter Legion and Razzler from Ex1, if possible
            Good luck, Jack
              Re: BAC
              good luck jack
              hmm?
              jack
                Re: BAC
                Jack, do you have pics of ValliANT and DefiANT?
                1 space left!
                  Re: BAC
                  Sorry, I meant Good Luck, Ben
                    Re: BAC
                    Change of plans. Since I am unable to think up a second AW, I'll enter a realie alongside Flamberge.
                    1. Flamberge
                    Shape: Somewhat like Surgeon General from Battlebots Season 5.0: an inverted wedge with 2 semi-exposed wheels and the weapon in front. The rear is pointed to avoid beaching.
                    Colour: Silver and gold.
                    Weight: 150g
                    Drive: Basically the same as real antweight robot VariANT. It uses 2 x 10mm motor gearboxes, with a gearing ratio of 100:1.
                    Power: A 12.6v lithium polymer battery.
                    Motivation: 2 30mm high polycarbonate hubs with black electric tape around it for traction.
                    Armour: 1mm titanium
                    Ground Clearance: ...I'm not sure. Probably somewhere in the region of 3-5mm though.
                    Turning Circle: 0
                    Dimensions in CM (LxWxH): 9 x 8 x 3
                    Weaponry: A horizontal spinning bar powered by an 80 watt brushless motor. Can't do accurate antweight calculations at the moment so I can't say how much damage it can inflict, hopefully a lot though. The bar is semi-protected by a 1mm aluminium hub on top of it, which helps it spin when inverted.
                    Srimech: Invertible.
                    Strengths: ...I've no idea.
                    Weaknesses: ...I've no idea.
                    2. Satanix (look on the Roaming Robots site for it and its picture; if you can't find it, ask David Weston.)
                    Hope that's alright.
                      Re: BAC
                      Uh...Satanix is Dave's feather, Kody, fail :P
                      Eye Of Ran AW stats:
                      Eye Of Ran
                      WEIGHT: 150g ish (I can throw together a weight calc if you like)
                      DIMENSIONS: 100 x 80 x 18 mm
                      SHAPE: A cuboid wider than it is long with a wedge at the back, extending from this cuboid is a long bar, at the end of which is the weapon motor (pic available if this is too difficult to understand, this seems to happen a lot with my designs)
                      COLOUR: Mostly fantasy artwork, generally blue and green with some gold. The blade is mostly unpainted with viridian tips.
                      DRIVE: 2 Sanyo 50:1 micro motors driven by a Sabertooth 2x5a controller, driving 2 rear semi-protected rubber tyred wheels, run at 11.1v off a 3 cell lithium polymer pack
                      SPEED: Medium fast
                      GROUND CLEARANCE: Blade is about 1-2mm off the ground, all around the rest is quite high except the rear wedge which is 0
                      ARMOUR: Top plate is a single piece of 3mm polycarb, reinforced with struts of balsa wood to counter the forces of the weapon. The rear wedge is 1mm polycarb covered in spring steel to make it low to the ground, and everything else is either held in with screws or taped to the underside of the top.
                      WEAPONS: A 65 x 15 x 4 mm undercutting titanium blade, which weighs 30g and is driven by a brushless outrunner motor rated at 20000rpm, with the ends curved into hooks to catch and rip the opposition. The blade protects the front of the robot and the vast majority of the sides as well, and packs a punch of...well, it doesn't particuarly matter in antweights :P It is kept from hitting the ground by a tiny piece of polypropylene in the bottom of the motor.
                      SRIMECH: Invertible, the odd shape and weapon should prvent it resting on its sides (it doesn't really have any sides anyway)
                      NOTES: Uses Spektrum radio to prevent it jittering or going out of control.
                      STRENGTHS: Weaponry, good drive and pushing power
                      WEAKNESSES: Newtonian physics
                        Re: BAC
                        Bugger off, Picus man. My head ain't working today. :P
                        Now what was it...ah yeah, Stewie, that was the one I was thinking of, not Satanix. Sorry about that.
                          Re: BAC
                          valliant (my real one ) http://www.antweight.co.uk/results/ws28 ... CF5374.jpg
                          defiant: (the 1 with the wight lid...not the spinner :sad: ) http://www.antweight.co.uk/results/ws28 ... CF5386.jpg
                          good luck ben!!!
                            Re: BAC
                            Hey Ben!
                            1) MicroForce 3.0
                            2) Baby Hell
                            Hope that is okay.
                              Re: BAC
                              Round 1:
                              Battle 1: Stewie VS ValliANT VS Eye of Ran AW
                              Battle 2: Microforce 3.0 VS Razzler VS CombatANT
                              Battle 3: Legion VS Flamberge VS Bobcat
                              Battle 4: DefiANT VS Baby Hell VS Anty B
                              1 robot is eliminated from each match
