Shape: Like Comengetorix. It has a wedge extender to give it 0 mm at the front.
Speed: 15 MPH.
Dimensions(lwh A): 85CM X 45 CM X 24 CM
Armour: 4.5 MM hardox.
GC: 0 mm at the front, 6 mm everywhere else, covered by skirts made of 3 mm Ti.
Weapon 1: Rear hinged flipper, powered by two pneumatic rams at 500 psi.
Weapon 2: Upward facing spikes on the wedge. A robot can go over them, but if it tries to reverse, say goodbye to your tyres. By wedging a robot then reversing suddenly, TMTHY can impale the tyres, then fire the flipper to do loads of damage. Even a robot with stuffed tyres will be limping after that.
Drive: Inner tracks, powered by Lem-130€™s at 24 volts.
Srimech: The flipper.
Strengths: Weapon synergy, has sunglasses painted on the side. Once The May Tracks Has You, there is no escape.
Weaknesses: Axe/flipper combos could take the tracks out.
Notes: There is a strip of metal shaped like sunglasses at the top of the flipper to prevent fast robots just going straight up and over like in Storm 2 vs Firestorm.
1) No Consequences - Joey
2) Back to Rock III - Martijn
3) Monsoon Season - Dan
4) Nitro-Gene 5.0 - Paul
5) Lethal Weapon - Tony
6) Flank Attack 2: DT - Alex MW
7) Whiplash - Sam Mornington Crescent - Steve
9) Chris
10) Achilles - Alex H
11) The May Tracks Has You - Frank
12) Krackotoa - Kody
Chris has got until 22:30 tomorrow if he wants to enter, after that, the reserved place will be vacated.
Weight: 100 kilos
Body Shape: Basic Invertible box-wedge shape. 1m long, 0.8m wide, 0.3m at maximum height.
Speed: Some 15mph
TC: 0
GC: 8mm, 0mm at front.
Wheels; 6 inner
Armour; 7mm titanium
Power; 3x 12v batteries, powered by S28-400 Magmotors, at 24v.
Colour; Black with white patches
Weapons; A pneumatic CO2 powered flipping arm that spans most of the robots length. It can throw some 400 kilos and has about 50 flips. Although the arm itself is quite narrow (about half the robot width), the flipper plate expands the full width.
Srimech: Its a both-er. It can run inverted AND self-right using the arm.
Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
Strengths; Weapon
Weaknessess: Hard to turn
Honest Joeys Good Thyme Tactix n Predictions Shoppe
Mornington Crescent vs. Monsoon Season vs. Whiplash
Krackotoa vs. Achilles vs. Orka RV
Flank Attack 2: DT vs. Nitro-Gene 5.0 vs. Lethal Weapon
The May Tracks Has You vs. No Consequences vs. Back to Rock III
...right?
From the start of the fight I shall try to find a safe place from where I can spin up, and then once doing so slam myself indiscriminately into either of my opponents until something happens.
If that fails and I get trapped in close quarters when spinning, go for May Tracks or Back To Rock (in that order) and lift them up, trying to get them towards the pit or out of the arena. 150cm of lifting arm should be enough to clear the 1 metre high walls...right?
Best of luck to you guys Marti and Frank, may the fights be long and w00ty.
AJWARS: ERA ACHE
ELIMINATORS Monsoon Season VS MORNINGTON CRESCENT VS Whiplash
Ouch, tough draw here.
Ill attack Whiplash first, as Monsoons stats give me the heebie-jeebies. Avoid the axe, aim for the sides and see if I can rip off those skirts to rack up some Damage points. I doubt Ill be able to do much to the Hardox armour, but the two rings combined should give it a good shock. Keep attacking the sides until it dies. If I feel particularly brave/stupid, try and rip off the axe.
As for Monsoon, theres not much I can do except try to outmanouever it and batter the sides. If Im lucky, Ill be able to scrape through on a judges decision or knock something loose.
As for the other battles, Ill pick Achilles, Nitro-Gene and The May Tracks Has You to fight another day. Looking forward to this one, Andy!
Tactics: Keep the front facing Mornington Crescent at all times and box rush it whenever possible - the Hardox wedge should ensure that I can slam into it without receiving too much damage. Once it has been box rushed, stay close to M.C. and get it into the wedge, slamming it into the arena walls and hopefully, pushing it around the arena and into the arena pit.
With Whiplash, do the same thing: box rush, get underneath and slam it around. Ty and get a good flip in and whilst it is self righting drive it towards the arena wall and hopefully to an Atomic to it (flip it over the arena wall.. poor SMIDSY :sad: )
Daniel, just out of interest, will you be making another Vapourbot Vengance series? I thought at first you were going to replace all the series 7 robots with vapourbots, but what I saw was great as well.
Its a tough battle this - Whiplash could axe-out Mornington Crescents drive chains (get the axe into the wheel housing and break it) but Monsoon could pit everyone. Im going for Monsoon to pit both of these two and win.
Krackotoa may be new, but its my favourite to win the battle, as Orka will be flipped OOTA by the more powerful Achilles, but then Achilles 5mm Titanium armour to be annihilated by MDU
Right - this is a complicated battle, and Im not sure HOW to approach it, because Flank Attack can take out spinners like LW with ease, but it can also outpush me greatly. On the other hand, Lethal Weapon looks to be the easiest to handle, but one touch of his weapon could be deadly.
What Ill do is attempt to take out LW first, possibly with an OOTA - attack him from the sides, push him to the edge and just launch him out. Then go after Flank Attack, attack him and try and OOTA him as well.
Good luck Tony and Alex MW :wink:
5 simple words as to whos going to win this one - The May Tracks Has You
Hope this is a good one AJ - it should be enjoyable
Tactics for Whiplash: Steve, my axe is made out of hardox, even the handle. So, axe away on anyone who dares to come near me. Open the pit, axe away on anyone who comes near, and rush it into the pit like radioactive waste.
Good luck, Danny and Steve-o
As for the other ones, I think Krackotoa, Nitro-Gene, and May Tracks will win.
Back to Rock is gonna rock your streets and ram NC before hes spun up. Lift and pit is the idea for BtR as always, and w00t for potentially damaging The May Tracks tracks (what are they made of?) with my saw while doing so.
Just one goes through from each melee. Thanks for all the comments!
3€¦
2€¦
1€¦
ACTIVATE!
Monsoon Season immediately gets to work, heading for Mornington Crescent. But Whiplash is quick to intervene, slamming hard into the side of the Welsh robot. This distraction has allowed Mornington Crescent to get away and start spinning up those dual rings. Monsoon Season backs away, ignoring Whiplash and again heads towards Mornington Crescent. Despite being slower, Mornington Crescent is controlled nicely to avoid the charge of Monsoon Season. Whiplash clearly wants to make itself known, hurtling into the back of Monsoon Season and swings the mighty Terrorhurtz esque axe down onto the top of Dan€™s robot. Much to Sam€™s surprise, the axe causes little more than a graze to Monsoon Season€™s 30mm HDPE monocoque. Monsoon Season is quick to turn around and slides neatly under the side of Whiplash. The tracked robot starts shoving Whiplash across the arena€¦ but in goes Mornington Crescent!! The double spinning rings collide with Whiplash, flinging it across the arena!
Dan finally gets his opportunity to attack Mornington Crescent and slams the huge Hardox wedge into it, considerably slowing down the rings. But the persistent Whiplash comes back in on the attack, quickly firing it€™s axe onto the top of Monsoon Season again! As Mornington Crescent sneaks away, Whiplash retracts its axe to reveal a small slice on the top of Monsoon Season. Whiplash fires again, grappling Monsoon Season and begins to push it across the arena, across the flame grill and into the corner! The axe fires and causes another cut in the top of Monsoon Season. The Welsh robot manages to manoeuvre itself out of the corner and dashes away, with a trail of flames momentarily chasing behind it€¦ into Mornington Crescent! Steve has stealthily pulled off another attack, this time colliding with Monsoon Season and ripping a huge chunk out of the HDPE! As the two robots bounce away, Whiplash drives into Mornington Crescent and fires the axe. But it has caused little more than a scratch to the paintwork. Monsoon Season recovers from its battering and catches Whiplash side on, immediately firing the flipper and swinging the Canadian robot through the air.
Mornington Crescent makes its casual get-away, but this time is pursued by Monsoon Season while Whiplash self-rights. The spinning rims start whirring once again, but Monsoon Season is just too quick and meets it with the front wedge. A few sparks scatter and Mornington Crescent bumps away. Monsoon Season continues its drive and manages to pin Mornington Crescent against the wall€¦ and Whiplash comes in with the axe! Again! And again! Then Monsoon Season flips Mornington Crescent hard against the arena wall! Whiplash fires the axe once more and this time drives Mornington Crescent into the corner, as Monsoon Season hits the pit release target. The great chasm descends as Whiplash gives Mornington Crescent a couple more swipes with the axe. Monsoon Season rushes on the attack, gliding under Whiplash and throwing it into the wall with the flipper! The vicious attack has allowed Mornington Crescent to get free, and Steve races away to get spun up again.
Whiplash and Monsoon Season seem more intent in finishing each other off, though. As Whiplash springs away from the wall with its axe, Monsoon Season sweeps it up on the wedge and pushes it€¦ right across the edge of the pit! Whiplash hurries away round the other side of the pit€¦ but hits Mornington Crescent head on! A skirt is ripped clean off the side of Whiplash, who is sent spinning dangerously close to the edge of the pit again! Monsoon Season doesn€™t miss its opportunity and quickly thumps into Whiplash, finally getting it into the pit€¦ but gets smashed by Mornington Crescent for its troubles! The impact causes little damage to Monsoon Season€™s flipper plate, and Steve drives his robot away to spin up again. Not for the first time, Monsoon Season is quick to follow. Mornington Crescent changes direction quickly and brushes past Monsoon Season, leaving it open for attack€¦ and what an attack it is!! Mornington Crescent has left an almighty tear across the back end of Monsoon Season.
But Dan responds quickly, turning right on the spot and grinding the Hardox plate against the slowing spinners of Mornington Crescent€¦ and flips! But Monsoon Season failed to get enough of Mornington Crescent, and it trundles away again, spinning up those rings. Dan continues his chase, keeping the front end nicely in line with Mornington Crescent, who is darting about all other the place. Monsoon Season attempts an attack but Steve steers his robot away with confidence€¦ until both robots go on a head to head charge! Mornington Crescent€™s rings hit Monsoon Season€™s scoop just as Dan operates the flipper, and both robots crash away from each other. Monsoon Season goes into spin, but Mornington Crescent is able to correct itself quickly and launches another attack!! Another chunk of HDPE is ripped away from Monsoon Season€™s side. But the actual robot seems largely unaffected yet again, and swerves into Mornington Crescent, firing the flipper and throwing the Scottish robot upside down.
Mornington Crescent creeps round to Monsoon Season€™s side and dishes out another hit before going on another spin-and-run. Monsoon Season, looking slightly more groggy than usual, gives chase. Mornington Crescent continues to glide around the arena, spinning the rings up towards their maximum 1500rpm. Dan seems to be quite fed up of playing cat and mouse, but carries on reluctantly. Mornington Crescent is revving up ferociously, and Monsoon Season can€™t get anywhere near it€¦ until now!! Mornington Crescent ricochets off the side on Monsoon Season, causing both machines to leave the ground and repel away from each other! Monsoon Season skids across the floor€¦ and does little else€¦ Mornington Crescent approaches again, but Monsoon Season flips! Steve cautiously backs off for a moment, but it seems the drive of Monsoon Season has finally given up. With one last directed attack Monsoon Season is flung stylishly into the pit, right on top of Whiplash.
CEASE!
Mornington Crescent goes through to Round 2!
Hope that wasn€™t too awful for you all€¦ I€™m sure there will be a Mornington Season in there somewhere.
