Isolation: Spin around a lot, let Deadly Lampshade attack me and then when it does, assuming Im still running, rush into it and try to prevent it from spinning up again, shove it into the house robots and pit if possible.
Doom: Drive at Blizzard. Take losing well.
The Hurting: Keep wedge to it till disc is spun up, and then clout it with the disc until it stops. Try and flip and shove it as well, but mainly disc it.
Drive: Get round Toros sides and/or rear and first opportunity I get, shove it down the pit. Stay away from the walls where possible.
