The Chronicles of Robotia (RPG)
  • The Chronicles of Robotia (RPG)
    OK, this is my final stand. This is probably my last chance of finding my place in the Fanfic section, and I do have experience with Roleplays. So....
    THE CHRONICLES OF ROBOTIA: A NEW BREED OF ROBOT
    Ever since the very first robot was created, the world has strived to find and create the Ultimate battle robot. Hence, Robot Wars was born. Many robots were tried and tested and many unique and interesting designs, weapons and even movement types were created.
    Then, one day, a strange item was invented. It was meant to be one of the most powerful, most formidible features any robot could have. However, it was dubbed too dangerous for the World Association of Robotics (WAR) and was locked away in confinment, never to be seen again...
    ...until now!
    RULES
    Basically, I just need people to enter one vapourbot each. Standard tournament rules apply, and more rules will be explained as the journey progresses. Theres no set number of people I need here, and if anyone wishes to enter whilst the story is progressing, Ill be more than glad to take you on.
    Note, only VAPOURbots. Real Robots will come along, but I will be in control of them.
    A Chris RPG???
    ...so tempted to enter Tira V...
    But Im gonna enter Kracko instead. Yall know where the stats are, I presume.
      I doubt whether WAR ever existed personally, being somewhat skeptical about RW in general :P
      Regardless, seeing as I cant enter Flirty Skirty or Haardvark, it shall have to be Nidhogg Evo for me.
        I must say this sounds very promising.
        Monsoon Magnum, please. Stats can be found on ZED.
          save me a place for now Chris, will fill it later today
            Ill enter Final Resting Place
            Robot Name: Final Resting Place
            Shape: Cylinder
            Weight: 100kg
            Length: 85cm
            Width: 85cm
            Height: 15cm
            Motivation: 8 x Big Nipper style small wheels, 4 on top and 4 on the bottom, they are made of HDPE and have vulcanised tyres
            Drive: 4 x S28-150s @ 24v, 12HP
            Batteries: 4 x NiCad Battlepacks
            Armour: 1mm titanium for the side (though that is untouchable) and 5mm hardox on top and base
            Weaponry: A spinning spike ring similar to that of Del-Dogs (RW UK vs. Germany special), it runs the full circumference of the robot and spins up to 3000rpm in 3 seconds courtesy of a LEM-130 @ 48v. It weighs 25kg and can reach 1500rpm in 1.5 seconds, from where it can produce 72.5Kj, so at 3000rpm it can deliver 145Kj. To protect from its own and other hits it has internal shockproofing, the ring itself is made of 10mm titanium. The blades are curved spikes made of tungsten and weighing 2.5kg each, they are part of the ring so cannot be ripped off. This weapon is capable of serious damage
            Speed: 20mph
            Turning Circle: 0
            Ground Clearance: 8mm
            Srimech: Invertible
            Colour: Red, with name in green on top and base and a gold ring with sapphire blades
            (Message edited by Swimm3r on December 28, 200
              Ill take Baldur
              http://www.alexjholt.tkwww.alexjholt.tk as usual
                I wanna enter Sheer Heart Attack 2, I presume Chris can find the stats?
                  Thats great.
                  Ill attempt to start the story today. Anyone else who wishes to join in is more than welcome.
                    can i enter CroOKeD?
                    stats to come
                    jack
                      here they are:
                      Shape:box wedge,dimensions are,1m long,0.75m wide and 0.5m high at the back.
                      Chassis:6mm mild steel
                      Armor:6mm hardox(f)6mm ti(b+s)
                      Weapon:a co2 full pressure flipper at 750psi with 1 110mm ram,and a 2kg bottle,the arm is hinged at the back and made of 8mm mild steel
                      Battery:2x 12v slas wired in series
                      Motors:2x magmoters at24v
                      weight:98kgs
                      Wheels:2x go-cart wheels
                      Ground clearance:0mm at the front,and 2mm at the sides and the back
                      Speed:10mph
                      Turning circle:0m
                        CHAPTER 1: A NEW UNLEASHING
                        CEASE!!
                        It had been a rather hectic battle. Two robots had been doing everything they could to tear their metaphorical hearts out. Kracko had certainly put up a good fight, knocking its oppodent away. However, the victor in the end was Nidhogg EVO, who had seized hold of the ring-bot, opened the pit and dumped it in.
                        Now, the robots had being towed out of the arena and back to their workbench. Repairs had been made, and all of the humans had gone off to have a much needed break. As Kracko and Nidhogg were left unattended, a strange figure lurked over them. Gingerly lifting up their covers, it set to work....
                        Nidhogg gave a small yawn and stretch with its claw.
                        Oh, man, it groaned, That was some battle I had. I hope I didnt upset Kracko to...
                        Just then, the penny dropped.
                        Wait a minute! Did I...just SPEAK!?
                        He was so startled, he reversed straight off the table. He landed on the floor with a thud, although thankfully the right way up.
                        Hey, do you mind!? snapped Kracko from his table, Some of us are trying to rest!
                        Nidhogg gasped. You two!
                        Me...what? asked Kracko.
                        Youre talking. Were actually talking. AND I can drive myself! explained Nidhogg, giving a small demonstration.
                        Kracko stared at him through his one eye.
                        OK...this is definately the wierdest thing that has ever happened to me, he remarked.
                        Very carefully, he drove off the bench.
                        How on earth did this happen? he wondered, And, more importantly, why?
                        Im sure someone should know, said Nidhogg, I wonder if anyone else has been affected?
                        Kracko was briefly distracted by something. On the floor, he noticed a walkie talkie, crackling slightly. And, just in the distance, was a strange figure, lurking in the shadows.
                        PARTY
                        Kracko
                        Nidhogg EVO
                        DECISION TIME
                        OK, so these two robots have just realised they can talk and drive themselves. They have three options.
                        1: See if they can find some other members of their team.
                        2: Investigate the walkie-talkie.
                        3: Try to catch up with the figure in the shadows.
                        Kody, Joey, decision time.
                        P.S. I am SOOOOO sorry for the cheeziness. I just didnt wish to copy Kodys idea.
                        P.P.S. Dont worry everyone else, youll get involved eventually.
                          #2 seems like the best idea. Other members might be a bit hostile at the moment and the figure in the shadows might be a trap. We could use the talkie to learn something without endangering ourselves. The worst-case-scenario from choosing #2 would be being right back where we started. From there Id choose #1 instead of #3.
                          What say Joey?
                          (Message edited by kodster on December 30, 200
                            Ill go with 2...and you can say what you want about Chris, but he does do w00ty RPGs :P
                              Never said he didnt, just surprised he brought one onto FRA. :P
