Mechanical Maelstrom Season 2.0
  • Mechanical Maelstrom Season 2.0
    Hello and welcome to Mechanical Maelstrom Season 2.0.
    I need 16 people to enter two heavyweight robots each, they must be vapours unless you actually own 2 realies, in which case you can enter those.
    The robots must adhere to these rules:
    €ž« No wheeled robot can weigh more than 100kg
    €ž« No robot at all can weigh less than 80.1kg
    €ž« A 10% weight advantage is given to tracks and shufflers
    €ž« A 50% weight advantage is given to true walkers. The definition of a true walker must be that rotary camshafts do not operate any part of the walking mechanism, and each leg must have 2 stages of movement
    €ž« No un-tethered projectiles are allowed
    €ž« Cluster-bots are allowed, but there can be no more than 4 parts. Each cluster must make up an equal part of the overall weight and if 50% or more of the cluster is eliminated the whole bot is out
    €ž« Pneumatic pressures cannot exceed 2400psi, hydraulic pressures 5000psi
    This tournament will take place in the Annihilation Stadium V2, which is a 15 x 15m2 box with stainless steel floor and 50mm hardox walls that reach 55cm high. Inside the box there are fewer hazards than last season, but we still have a few:
    €ž« Just outside of the bottom left corner there is a 2 x 2m2 pit, opened by a release button in the top right corner
    €ž« In the middle of the top and bottom walls there are static spike strips, 5 metres across
    €ž« In the two remaining corners there are sets of killsaws
    You can reserve a spot, but it will only last three days before becoming vacant again.
    The tournament structure will feature 8 qualifiers of 4 robots in the first round. Each heat is a four way melee with two robots going through, but from then on its straight knockout, with 16 robots down to 8, 8 robots down to 4, 4 down to 2 and 2 down to 1. There are four seeds in this tournament, based on their performances last time around:
    04. Leprosy Infection
    03. Spin Dash Unleashed
    02. Gabriel III
    01. Sheer Heart Attack 2
    If I don¡¦t get 16 entries by two weeks today I will fill up the remaining spaces with random realies.
    Get Entering!!!
    The follwing people reserved spaces in the previous thread:
    Frank Goacher
    Richard Southworth
    Joey McConnell
    Also the seeded robots have reserved spaces.
      quote:
      If I don¡¦t get 16 entries by two weeks today I will fill up the remaining spaces with random realies.Bit optimistic.
      The Zodiac
      Tira V
      Stats on ZED. Good luck with this one.
        I wish to confirm my reservation for the tournament opened by yourself in which robots shall do things.
        My robots that shall do things are:
        Gabriel IV (provisional; stats still need a bit of work doing so will be up in next couple of days - rest assured I believe it is the ultimate front hinged flipper ever designed ) - will take Gabriel IIIs seeding if thats okay
        Nidhogg Evo - http://strickenone.proboards99.com/index.cgi?board=chevhw&action=display&thread=156http://strickenone.proboards99.com/i...isplay&thread= 156
        Yours in something,
        Joey McConnell
        Team Chevron captain, driver, designer, general person of doing stuff
          Ill enter http://strickenone.proboards99.com/i...hread=288Wedga
            Binary Hell & Talisman please, Stats in How Could I Improve Pt 2
              Im going to call the reservations, although Leprosy will definately be back, I need to think about my other contender.
                Given I did so badly last time around, Im going to enter two different robots - one being one of my least sucessful robots, and the other being a deadly flipper thats won me a lot of awards.
                Here they are
                Nitro-Gene 5.0
                http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=17 7http://strickenone.proboards99.com/i...n=display&thre ad=177
                Autoism 3.0
                http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=47 5http://strickenone.proboards99.com/i...n=display&thre ad=475
                Good luck to everyone who enters, and good luck to Lewis in writing :wink:
                  Save SHA2 a spot!
                    Ill take a spot, please!
                    1. Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
                    SHAPE- skirted box, with rounded sides and back.
                    COLOUR- dark blue bodywork, with red-and-white striped skirting.
                    WEIGHT- about 100kg
                    DIMENSIONS- 100cm X 75cm X 20cm
                    SPEED- 16mph
                    TURNING CIRCLE- 0mm
                    GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
                    ARMOUR- 4mm Hardox
                    MOVEMENT- inner, 6WD
                    POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
                    WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
                    SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
                    NOTES- flies Scotland flag.
                    STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
                    WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
                    http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
                    2. Traffic Warden (HW)
                    SHAPE- rigid U shape, rounded rear
                    COLOUR- black with a yellow stripe
                    WEIGHT- 100kg, I hope
                    DIMENSIONS- 95cm X 150cm X 25cm
                    SPEED- 15mph
                    TURNING CIRCLE- 0mm
                    GROUND CLEARANCE- 10mm
                    ARMOUR- 4mm Grade 5 titanium
                    MOVEMENT- four inner wheels
                    POWER- 2 x Etek-RT motors, running at 48v and producing 38hp.
                    WEAPONS- Two vertical hydraulic clamps within the middle of the machine. Each clamp is powered by an 80mm x 40mm ram operating at 3000psi, delivering up to 10 tonnes of crushing power. When an opponent slips into the middle, the clamps activate and hold them in place. Traffic Warden can then drag them around and shove them into the nearest arena hazard. Think of it as Huggy Bear on steroids.
                    SRIMECH- invertible, rounded rear should prevent it getting beached
                    NOTES- flies Scotland flag, super special awesome thanks to Daniel Stickler, Martijn and AJ for helping with the design
                    STRENGTHS- good traction, tough shell, fairly manoueverable, nippy, powerful grip
                    WEAKNESSES- untested weapon, exposed ground clearance
                    http://img381.imageshack.us/img381/1130/trafficwardenfinalto6.pnghttp://img381.imageshack.us/img381/1...enfinalto6.png
                      Count me in.
                      Neo-Mecha
                      Weight: 100kg
                      Shape: Ankle Biter (Battlebots 3.0 Version)... with side skirts
                      Colour: Jet Black for the front and rear, Prussian Blue anywhere else
                      Dimensions: 100 X 77 X 36
                      Power: 2 X Bosch 750s @ 24v powered by 5 X NiCads
                      Wheels: 2 X Aluminium Wheels with Asmaprene Urethane covering
                      Speed: 15 mph
                      Armour: 3.25mm Hardox
                      Ground Clearence: 0mm on the sides due to skirts, and on the back. 6mm anywhere else (Including without skirts)
                      Turning Circle: Everyone should know that this is zero.
                      Weapon: 27kg Front Vertical Spinning Disc made from laser cut titanium, powered by 2 X LEM-130. This also has 2 Hardox teeth curved upwards, and it will spin at 3600RPM. Heavily Shock-Proofed as well.
                      Srimech: At the rear, there is a linear actuated bar, and it can right the robot in 1 second.
                      Strengths: Powerful Weapon, Decent Pushing Power, Fast and effective srimech, Very Reliable
                      Weaknesses: Hopefully, there is none. XD
                      Death Sentence
                      Body Shape: Just a simple Box with X-Terminator style bucket scoop
                      Weight: 110kg
                      Dimensions: 90 X 85 X 30
                      Drive: Steel Tracks with Asmaprene Urethane powered by 2 X LEM-130 @ 36V powered by 4 X NiCad BattlePacks
                      TC: Zero
                      Top Speed: 19 mph
                      GC: Completely 0mm at the back, 0mm anywhere with skirts, and 6mm without skirts
                      Armour: 3.6mm Hardox 600
                      Skirts: A Titanium skirt on each side
                      Weapon: At the front, there is a big and devastating 21kg Horizontal Disc-o-Inferno style flywheel powered by a Honda CR125 Motorbike Motor. Its top speed is 9000RPM. It is deadly within 2 seconds. The bucket scoop at the back serves as a rammer, so if the disc fails it can push robots all day.
                      Srimech: Invertible, rounded sides prevent it from getting beached
                      Strengths: Devastating Name and Weapons, Extremely Sturdy Tracks, Very very very hard to get under, Heavily Shock-Proofed
                      Weaknesses: As usual, the tracks might be exposed to axes or crushers (Although Very Strong and Sturdy)
                        Can I reserve a place, please? I will post stats tomorrow evening when the alcohol wears off!
                        Thank you!!!
                          The May Tracks Has You
                          Shape: Like Comengetorix. It has a wedge extender to give it 0 mm at the front.
                          Speed: 15 MPH.
                          Dimensions(lwh A): 85CM X 45 CM X 24 CM
                          Armour: 4.5 MM hardox.
                          GC: 0 mm at the front, 6 mm everywhere else, covered by skirts made of 3 mm Ti.
                          Weapon 1: Rear hinged flipper, powered by two pneumatic rams at 500 psi.
                          Weapon 2: Upward facing spikes on the wedge. A robot can go over them, but if it tries to reverse, say goodbye to your tyres. By wedging a robot then reversing suddenly, TMTHY can impale the tyres, then fire the flipper to do loads of damage. Even a robot with stuffed tyres will be limping after that.
                          Drive: Inner tracks, powered by Lem-130€™s at 24 volts.
                          Srimech: The flipper.
                          Strengths: Weapon synergy, has sunglasses painted on the side. Once The May Tracks Has You, there is no escape.
                          Weaknesses: Axe/flipper combos could take the tracks out.
                          Notes: There is a strip of metal shaped like sunglasses at the top of the flipper to prevent fast robots just going straight up and over like in Storm 2 vs Firestorm.
                          Cobalt
                          Shape - Mostly a shallow wedge with a small box section at the rear.
                          Speed - 16 MPH
                          Dimensions(lwh): 70CM X 45 CM X 20 CM
                          Armour - 4 mm Hardox for the top, 5 mm for the sides and 5 mm Grade 5 Ti for the base.
                          GC - 3 CMs at the very rear, going down to 0 at the front, assisted by a sharpened wedge extender allowing it to slide under the lowest ground clearance.
                          Weapon 1 - The wedge.
                          Weapon 2 - A flat disc of doom style flywheel on the front wedge. Robots get thrown off after having their bases and wheels shredded. The disc is run on a Lem-130 on 24 volts and spins at 500 RPM. The disc is made of 4 mm Hardox, with two Hardox teeth, angled in the direction of spin.
                          Drive - Two wheel drive, with the wheels positioned at the very rear of the machine and castors around the middle to provide stability. This is powered by two S28-400 Magmotors on 24 volts.
                          Srimech - A lifting bar/plate made of 5 MM Grade 5 Ti/V. This not only self rights the robot, but also gives the disc some protection from axe attacks. The base bar is curved so it avoids hitting the disc. This is powered by a LEM-130 on 24 volts.
                            Black Panther
                            Dantu
                            http://www.alexjholt.tkwww.alexjholt.tk
                              wait, 2 bots? save BTR3 a spot too!
