My first tournament w.a.r
  • My first tournament w.a.r
    hey
    i decided to start my own tournament since lots of other people have them and i dont want to miss out on the fun
    so i need 6 people to enter 2 heavys each, one can be a realie.
    robots with wheels can go up to 100kgs
    walkers weight can go up to 180kg and tracked robots 120kgs
    the arena is the robot wars series 7 arena
    the house robots are shunt, sir killalot, sgt bash and dead metal
    i can push the sign-up numbers up to 12 if i get a lot of interest
    jack
    I will enter Hypertension and Tsunami... all flippers
    Stats for Hypo on Kodys forum which Im sure someone else will post the link for
      No Consequences and Stiltskin for me, if you please: http://strickenone.proboards99.com/index.cgi?board=chevhwhttp://strickenone.proboards99.com/i...i?board=chevhw
      Good luck with your first tourney Jack.
        MeCannibal 3.0 (http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=17 5http://strickenone.proboards99.com/i...n=display&thre ad=175) and Heyght II (http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=30 2http://strickenone.proboards99.com/i...n=display&thre ad=302) for me please.
          Back to Rock III and Flick of the Wrist, both on ZED
            Me! Me! Me!
            Dervish: The L337 Generation - http://strickenone.proboards99.com/index.cgi?board=teambv&action=display&thread=306http://strickenone.proboards99.com/i...isplay&thread= 306
            Monsoon Magnum - http://strickenone.proboards99.com/index.cgi?board=teambv&action=display&thread=305http://strickenone.proboards99.com/i...isplay&thread= 305
            Yay! Lets see some robo-smashing!
            (Message edited by team_britespark on October 19, 200
              Me! Me! Me!
              Chalkie 3G: http://farr.proboards21.com/index.cgi?board=TeamSolarizedStats&action=display& thread=398http://farr.proboards21.com/index.cg...ion=display&th read=398
              Son of Wedgie: http://farr.proboards21.com/index.cgi?board=TeamSolarizedStats&action=display& thread=397http://farr.proboards21.com/index.cg...ion=display&th read=397
              Lets see how a couple 2005-era robots can do
                Damn you people, faster than me again. :sad:
                If you can extend the amounts of entries, Im certainly interested.
                  same here
                    ME ME ME ME ME
                    if entries are increased can I have: Haldux 2.0 and Robo-Mammoth
                      Save me a spot!
                      Thanatos
                      Weight: 100kg
                      Shape: Think a cylinder, but with sloped sides ala Megabyte
                      Colour: Blue shell, Black Top, Silver Base, Green Srimech, Red Teeth
                      Dimensions: 100 X 100 X 25
                      Power: 2 X Bosch 750s, powered by 4 X 24v NiCad Battlepacks
                      Wheels: 2 X Urethane Coated Aluminium Wheels
                      Armour: 4mm Hardox for the shell, 7mm Polycarb for the Base, 4mm Grade 5 Titanium for the srimech.
                      GC: 5mm
                      TC: Complete Zero
                      Weapon: 38kg FBS shell, with 4 X 1kg Hardox teeth (2 on the top and 2 on the bottom), all curved to rip into armour, powered by a LEM-170. This can spin at 1500RPM. Heavily Shock-Proofed as well.
                      Srimech: A Linear Actuated Bar at the top, which can right the robot in 1 second.
                      Strengths: Lethal Weapon, Fast & Effective Srimech
                      Weakness: Weak Base Armour.
                      Walk Dont Run 4
                      Weight: 110kg.
                      Body Shape: Disc.
                      Colour: Emerald Green Weapon, Snow White for top and bottom.
                      Dimensions: 95 X 95 X 27.
                      Drive: 2 X LEM-130s @ 36v powered by 3 X NiCad Batteries.
                      Top Speed: 15 mph.
                      Feet: 4 X Shuffling Pads with Asmaprene urethane rubber, and this prevents WDR from self-destruction.
                      Armour: 13mm Titanium Everywhere.
                      Ground Clearence: 5mm all around.
                      Weapon: 32kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 4 X 1kg Hypno-Disc style teeth, curved and blunt to tear armour, or shock kill an opponent. This brings out about 125kJ, and if the spinner fails, it can use its INSANE pushing power to ram other robots to death. Its also heavily shock-proofed as well.
                      Srimech: Invertible.
                      Strengfths: Deadly Weapon.
                      Weaknesses: Hates Flippers.
                        ok i will push it up to 12 if i can get 2 more people...
                          Wedgin8or and Kracko please, stats on the ZED forums.
                          Or if youre feeling lazy... http://strickenone.proboards99.com/index.cgi?board=heavieshttp://strickenone.proboards99.com/i...?board=heavies
                          Good luck Jack.
                            COMPRESSION
                            BODY SHAPE: Looking down from above it€™s a triangle, the bottom line is the front
                            WEIGHT: 100kg
                            DIMENSIONS (L X W X H): 75cm (90cm with wedge and claws) x 75cm (shrinking progressively down to 25cm at the rear) x 15cm
                            COLOUR: Polished to perfection, the claws are gold with red tips and the spikes are black
                            LOCOMOTION: 2 x 164mm go-kart style wheels with aluminium hubs and vulcanised tyres
                            GROUND CLEARANCE: 7mm
                            SKIRTS: A 5mm hardox hinged wedge at the front (between the claws) that flops over when the robot is inverted, as do the 5mm grade 2 titanium side skirts
                            DRIVE MOTORS: 2 x Bosch 750w motors running at 36v
                            DRIVE BATTERIES: 2 x NiCad battlepacks running at 36v in parallel
                            SPEED: Can reach 25mph to batter opponents around, but is kept to 15mph when driving around
                            TURNING CIRCLE: 0 metres
                            BODY ARMOUR: 3.2mm hardox monocoque for the most part, with 5mm hardox extra protection in key areas such as battery mounts
                            CHASSIS: 3.2mm hardox monocoque
                            WEAPON 1: The front horizontal Kan Opener-style crushing jaws are closed completely via a vivoil pump powered by a LEM-130 motor @ 36v, the hydraulics are at 3000psi giving 4.5 tonnes of crushing force between the tip, this is interchangeable for a pneumatic setup powered from a 3kg bottle and 2 x 100mm rams at 725 psi each. The claws themselves remain the same in both setups and are tungsten tipped with serrated edges
                            WEAPON 2: The hinged wedge between the claws beaches opponents with the Mute-style barbs it has so that the opponent can be pushed around while the claws keep hold, this is perfect for pitting robots because the wedge will flop over the edge of the pit so when the claws let go the opponent will fall straight in. Also on either side of the rear point there is a tungsten tipped spike, so when the robot spins on the spot with the two wheel drive it functions as a thwackbot
                            WEAPON BATTERIES: 2 x NiCad battlepacks running at 24v in parallel
                            SRIMECH: Can run inverted
                            STRENGTHS: Powerful weaponry, can end battles in seconds due to grab and pit using the weapon synergy, fast, good armour
                            THUNDERSTORM
                            BODY SHAPE: Low wedge ala Voltronic with a Firestorm-style blade at the foot of the wedge
                            WEIGHT: 120kg (takes advantage of a 10% bonus allowed for tracks)
                            DIMENSIONS (L X W X H): 75cm x 75cm x 20cm
                            COLOUR: Black with gold outlines and the name written in silver with blood red outline along the top of the wedge
                            LOCOMOTION: 2 x internal fully vulcanised titanium tank tracks
                            GROUND CLEARANCE: 0 at the front, 10mm at sides and rear
                            SKIRTS: 5mm grade 2 titanium torsion sprung skirts at sides and rear
                            DRIVE MOTORS: 2 x LEMCO-200 lynch motors running at 48v
                            DRIVE BATTERIES: 8 x NiCad battlepacks running at 48v in parallel
                            SPEED: 20mph
                            BODY ARMOUR: 5mm hardox monocoque, with 6mm hardox on the wedge and 4mm 7075 aircraft aluminium on the base
                            WEAPON 1: A Firestorm-style front hinged flipper hinged 5cm up the wedge and ending 5cm from the end, it is powered by 2 x 120mm rams at 175psi from 2 x 1.1kg bottles, giving 15-20 flips per bout.
                            WEAPON 2: The robot is a very good pusher
                            WEAPON BATTERIES: Just a few A123s to operate the valves
                            SRIMECH: The flipper will right the robot quickly and easily
                            STRENGTHS: Good all rounder, good pusher, decent weapon, good armour
                            (Message edited by Supersporty on October 23, 200
                              I will enter...
                              Walk Dont Run 4
                              Weight: 110kg.
                              Body Shape: Disc.
                              Top Speed: 15 mph.
                              Neo-Mecha
                              Weight: 100kg
                              Shape: Ankle Biter (Battlebots 3.0 Version)... with side skirts
                              Colour: Jet Black for the front and rear, Prussian Blue anywhere else
                              Dimensions: 100 X 77 X 36
                              Power: 2 X Bosch 750s @ 24v powered by 5 X NiCads
                              Wheels: 2 X Aluminium Wheels with Asmaprene Urethane covering
                              Speed: 15 mph
                              Armour: 3.25mm Hardox
                              Ground Clearence: 0mm on the sides due to skirts, and on the back. 6mm anywhere else (Including without skirts)
                              Turning Circle: Everyone should know that this is zero.
                              Weapon: 27kg Front Vertical Spinning Disc made from laser cut titanium, powered by 2 X LEM-130. This also has 2 Hardox teeth curved upwards, and it will spin at 3600RPM. Heavily Shock-Proofed as well.
                              Srimech: At the rear, there is a linear actuated bar, and it can right the robot in 1 second.
                              Strengths: Powerful Weapon, Decent Pushing Power, Fast and effective srimech
                              Weaknesses: Hopefully, there is none. XD
