FRFFT: Series One
  • FRFFT: Series One
    Hello, Everyone and welcome to Fighting Robots Fan-Fiction Tournament (FRFFT for short). I do apologize if the name is a bit random, but I liked it
    The Rules
    I need 8 people to enter two robots of any of the following weight classes. There are only four places in each so you need to hurry
    Superheavyweight (100 to 200)
    Heavyweight (50 to 100)
    Middleweight (25 to 50)
    Featherweight (1 to 12)
    Kody K, Dave S, Paul C and Liam E have reserved spots. I just need four more people to enter
    The arena will be the Robot Wars Series 7 Arena. There wont be any house robots, only Refbot. Everything else will be added
    Normal Robot Wars Rules apply. No flying robots. Tracked robots and walking robots are allowed. Clusterbots are allowed, and you can have as many parts as you want. But remember: Half out: ALL out
    Thats it for now. So get cracking!
    FRFFT: Series One
    I enter two of my top dogs here:
    http://strickenone.proboards99.com/index.cgi?action=display&board=tivapours&thread=17 7&page=1http://strickenone.proboards99.com/i...tivapours&thre ad=177&page=1
    +1>Nitro-Gene 5.0
    http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=30 2http://strickenone.proboards99.com/i...n=display&thre ad=302
    +1>Heyght II
    I prefer heavyweights to the oher weights
    Good luck everyone else who enters
      FRFFT: Series One
      Oooh, reserve me a spot until I finish clarifying a few things:
      1: What are the weight limits for tracked and walking machines?
      2: When you say enter two in any of the following weight classes, does that mean we have to enter two in one weight class, or can we enter eight robots, two in each class?
        FRFFT: Series One
        save me a spot
        EDIT: for some odd reason I dont think Liam E is gonna claim his saved spot
        (Message edited by MajinB on October 18, 200
          FRFFT: Series One
          Heavy 1
          The May Tracks Has You
          Shape: Like Comengetorix. It has a wedge extender to give it 0 mm at the front.
          Speed: 20 MPH.
          Dimensions(lwh A): 85CM X 45 CM X 24 CM
          Armour: 4.5 MM hardox.
          GC: 0 mm at the front, 6 mm everywhere else, covered by skirts made of 3 mm Ti.
          Weapon 1: Rear hinged flipper, powered by two pneumatic rams at 500 psi.
          Weapon 2: Upward facing spikes on the wedge. A robot can go over them, but if it tries to reverse, say goodbye to your tyres. By wedging a robot then reversing suddenly, TMTHY can impale the tyres, then fire the flipper to do loads of damage. Even a robot with stuffed tyres will be limping after that.
          Drive: Inner tracks, powered by Lem-130€™s at 24 volts.
          Srimech: The flipper.
          Strengths: Weapon synergy. Once The May Tracks Has You, there is no escape.
          Weaknesses: Axe/flipper combos could take the tracks out.
          Heavy 2
          The 6isc
          Shape: Like an old fashioned bar-bell. It is two circular wheel pods, connected by an axle in the middle of which sits the disc.
          Size: 60X110X60 CM (LWH)
          Weight: ~100 KGs
          Speed: 10 MPH.
          Ground clearance: Under the wheel protectors, it€™s 5 mm.
          Weapon: 26 KG spinning disc, powered by one LEM 130 Lynch motor and going at 2500 RPM. The disc is shaped with its own teeth rather than needing teeth surgically attached to it, so dentistry is quite impossible. The energy output is 36 KJ€™s which, while modest by vapour €˜bot standards should still be enough to make a mess of things.
          Wheels: 6 wheels, but four wheel drive. This has three wheels on either side arranged in a triangular fashion, so it only runs on four at a time. The wheels are 1 CM solid Ti with soft compound rubber wrapped around them to provide shock resistance, and a layer of Vulcalon wrapped around that to provide traction.
          Chassis: The main chassis consists of one solitary 1 CM thick 4 mm box section hardox bar. Slotted over that is a secondary axle, inside which are the batteries. There are also two other triangular chassis€™ supporting the wheels. These are made from 4 MM 1 CM box section Ti bars with weight reducing holes.
          Armour: The true axle and chassis is a 4 MM hardox bar. The battery axle is 2 mm aluminium. The semi circular wheel protectors and side spikes are 5 mm Hardox. The disc itself is 14 MM of Hardox 500, and the outer axle is 4 mm grade 5 Ti.
          Srimech: Totally invertible. Controls won€™t even have to be reversed after flipping, meaning it can just go straight back on the attack.
          Drive: 2 S28-400 Magmotors at 24 volts.
          Strengths: The newest version of The 6isc does away with as many weaknesses in The Disc 5 as I could find.
          Weaknesses: Weak armour in places. Can€™t use axe attacks.
          I currently have no otherweight vapours, so Im not reserving for those brackets. If I can get some done in time Ill enter those.
            FRFFT: Series One
            I would like to enter, please! . Can I reserve a place?
              FRFFT: Series One
              SHW Cranky Croc
              SHW Robo-Hedgehog, with 4MM hardox instead of titanium
              Stats on ZED
                FRFFT: Series One
                Featherweights
                Altitude
                Micro Gore Evo
                Middleweights
                Solstice 2.0
                Xianghua II
                Heavyweights
                Wedgin8or
                Shadow Zone Forever
                Superheavyweights
                Tax Cutter
                The System Of Doctor Tarr And Professor Fether
                Stats be coming soon!
                (Message edited by kodster on October 18, 200
                  FRFFT: Series One
                  Sorry, but I have once again not explained clearly. Allow me to explain clearer
                  I want TWO robots of any kind (Ie: A middleweight and a heavyweight or maybe a superheavyweight and a featherweight) entered by EIGHT people. There are FOUR robots to be entered in each weight catagory, meaning all of you might not get to be in their favourite weight class
                  Paul: Pick a heavyweight, and then either pick a featherweight, middleweight or superheavyweight
                  Kody: Pick two robots from your eight. They cannot be in the same weight class
                  Frank: Same as Paul, please
                  Ben: Same as Frank and Paul please
                  Places so far: Frank, Paul, Daniel, Ben, Kody, Maritjn
                  I forgot to add in the rules: Real Robots are allowed
                  Im sorry about all this. I cant explain things well. I have autism. If this goes terribly wrong again, Ill redo the whole thing but read the above CAREFULLY
                  Thanks for understanding, if you do anyway
                    FRFFT: Series One
                    Ill keep Nitro-Gene 5.0, and Ill enter the featerweight realie, Skink.
                      FRFFT: Series One
                      Middleweight: T-Minus
                      Heavyweight: Neo-Mecha
                      Weight: 100kg
                      Shape: Ankle Biter (Battlebots 3.0 Version)... with side skirts
                      Colour: Jet Black for the front and rear, Prussian Blue anywhere else
                      Dimensions: 100 X 77 X 36
                      Power: 2 X Bosch 750s @ 24v powered by 5 X NiCads
                      Wheels: 2 X Aluminium Wheels with Asmaprene Urethane covering
                      Speed: 15 mph
                      Armour: 3.25mm Hardox
                      Ground Clearence: 0mm on the sides due to skirts, and on the back. 6mm anywhere else (Including without skirts)
                      Turning Circle: Everyone should know that this is zero.
                      Weapon: 27kg Front Vertical Spinning Disc made from laser cut titanium, powered by 2 X LEM-130. This also has 2 Hardox teeth curved upwards, and it will spin at 3600RPM. Heavily Shock-Proofed as well.
                      Srimech: At the rear, there is a linear actuated bar, and it can right the robot in 1 second.
                      Strengths: Powerful Weapon, Decent Pushing Power, Fast and effective srimech
                      Weaknesses: Hopefully, there is none. XD
                        FRFFT: Series One
                        tis perfectly okay Elliot; theres quite a few fanfic people who have forms of autism, so we sympathise, understand and all find ways to work around it and live in peace and harmony
                        I shall enter...
                        The Hurting (very complicated heavyweight :P): http://strickenone.proboards99.com/index.cgi?action=display&board=chevhw&thread=492http://strickenone.proboards99.com/i...chevhw&thread= 492
                        Drive (considerably less complicated superheavyweight): http://strickenone.proboards99.com/index.cgi?action=display&board=chevow&thread=493http://strickenone.proboards99.com/i...chevow&thread= 493
                        Hope this goes well for your first tourney.
                          FRFFT: Series One
                          Heavyweight - Fling
                          Featherweight - Deadly Lampshade
                          http://strickenone.proboards99.com/index.cgi?board=teambvhttp://strickenone.proboards99.com/i...i?board=teambv
                            FRFFT: Series One
                            In that case, Ill keep Shadow Zone Forever (HW) and Xianghua II (MW).
                            Stats (again) coming soon. Just finishing up rendering SZF.
                              FRFFT: Series One
                              http://strickenone.proboards99.com/i...5&page=1Shadow
