RoboBASH Mini-Tourney
  • RoboBASH Mini-Tourney
    Right, Ive decided to take a bit of a break to the main competition and get on with it after this is done. I need 8 contestants to enter 1 vapour each.
    The Arena:
    First of all, the arena is 21m X 19m. there is a pit in the middle and two killsaws to the left and right side of the arena. The flipper and the flames are exactly the same position as Robot Wars Series 7. The dropzone is a metre away from the pit.
    And one more thing...
    This tourney contains house robots. Entering discretion is advised.
    House Robots: All the house robots from Robot Wars, and I may need more...
    So, get enterin. :wink:
    hi
    can i enter CroOkeD?
    ill post the stats in a mo...
    jack
      You mean all the non invertible house robots with fibreglass and wire mesh bodyshells, big yet mostly useless weapons, and lots of petrol engines in easily attackable locations? Im in
      No Consequences stats are on ZED for your consideration.
        Time for the debut of...
        *melodramatic drumroll*
        ...Dantu
        http://www.alexjholt.tkwww.alexjholt.tk
          Shape:box wedge,dimensions are,1m long,0.75m wide and 0.5m high at the back.
          Chassis:6mm mild steel
          Armor:6mm hardox(f)6mm ti(b+s)
          Weapon:a co2 full pressure flipper at 750psi with 1 110mm ram,and a 2kg bottle,the arm is hinged at the back and made of 8mm mild steel
          Battery:2x 12v slas wired in series
          Motors:2x magmoters at24v
          weight:98kgs
          Wheels:2x go-cart wheels
          Ground clearance:0mm at the front,and 2mm at the sides and the back
          Speed:10mph
          Turning circle:0m
            Ill enter Back to Rock III!
              Ill have Robo-Hedgehog
                Lets give Traffic Warden a test drive.
                Traffic Warden (HW)
                SHAPE- rigid U shape, rounded rear
                COLOUR- black with a yellow stripe
                WEIGHT- 100kg, I hope
                DIMENSIONS- 95cm X 150cm X 25cm
                SPEED- 15mph
                TURNING CIRCLE- 0mm
                GROUND CLEARANCE- 10mm
                ARMOUR- 4mm Grade 5 titanium
                MOVEMENT- four inner wheels
                POWER- 2 x Etek-RT motors, running at 48v and producing 38hp.
                WEAPONS- Two vertical hydraulic clamps within the middle of the machine. Each clamp is powered by an 80mm x 40mm ram operating at 3000psi, delivering up to 10 tonnes of crushing power. When an opponent slips into the middle, the clamps activate and hold them in place. Traffic Warden can then drag them around and shove them into the nearest arena hazard. Think of it as Huggy Bear on steroids.
                SRIMECH- invertible, rounded rear should prevent it getting beached
                NOTES- flies Scotland flag, super special awesome thanks to Daniel Stickler, Martijn and AJ for helping with the design
                STRENGTHS- good traction, tough shell, fairly manoueverable, nippy, powerful grip
                WEAKNESSES- untested weapon, exposed ground clearance
                http://img381.imageshack.us/img381/1130/trafficwardenfinalto6.pnghttp://img381.imageshack.us/img381/1...enfinalto6.png
                  Ill enter Genocide please, stats on ZED
                    Heyght II will be my entry.
                    http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=30 2http://strickenone.proboards99.com/i...n=display&thre ad=302
                    And...whoa! Thats all 8 entry spaces filled in - impressive stuff Samuel :wink:
                    (Message edited by paulc on October 07, 200
                      Pah! You cruel people, taking advantage of me being at college.
                      I did say I was tempted to reserve a spot though, but I dont want to kick anybody out.
                        I sense a classic case of tough luck Kody :sad:
                          Sorry, Kody.
                          I will need four more entries to crank it up to 12.
                            Draws:
                            Battle 1:
                            Back to Rock VS (Kody Entry) VS Robo-Hedgehog
                            Battle 2:
                            Heyght 2 VS Traffic Warden VS cROoKED
                            Battle 3:
                            Dantu VS (Another Entry) VS (Another Entry)
                            Battle 4:
                            (Another Entry) VS No Consequences VS Genocide
                            Two robots go through from each battle and then it will be one-on-one from then on.
                              Heyght II vs. Traffic Warden vs. cROoKED: Get ready to fly! Traffic Warden is much more of a threat than cROoKED, due to its massive power. Simple tactic - ram into the sides of Traffic Warden, get underneath, and push him to the sides and flip him out. I should get under him OK, its outpushing him Im worried about. If cROoKED wants to have a go at me, Ill just give him some Heyght Sorry - bad pun, basically, if Jack has a go, Ill flip him.
                              Good luck Jack and Steven :wink:
