Velociraptor's Fanfic Tournament: The Comeback
  • Velociraptors Fanfic Tournament: The Comeback
    w00t again, both my vapourbots went through, and in equally awesome battles!
    Good stuff once more, Richard
      In this next battle, reigning champ Wedge Devolution will have its hands full against interchangable Exodus, now fitted with torsion sprung skirts and a hydraulic claw on its wedge!
      House Robots: Ultimate Snakebite & King Cobra
      3, 2, 1 - ACTIVATE!
      As in many previous fights, both robots were aiming to get under their opponents side as they met in the arena centre - with its torsion-sprung skirts, Exodus found it couldnt turn quite as fast as Wedge Devolution, who in turn struggled to surpass the skirting! It managed to shove Exodus in a circular pattern, taking them into the northwest corner - being shoved at a difficult angle against the corner allowed Exodus to escape, but in doing so, it exposed its inverted wedge to Wedge Devo! The reigning champ reacted quickly, firing its flipper and neatly tossing Exodus onto its back! As Exodus landed and tried to run, it was attacked from behind and flicked over again! This time, it managed to evade Wedge Devo, and attack side on itself! The wedge didnt manage to beat Wedge Devos skirting, but the champion was successfully shoved into the arena disc to have its Hardox armour sliced! Wedge Devolution dodged as Exodus charged in for another assault - it reversed into its opponent to pin it against the wall, but that wouldnt do much good! It moved off to turn, and as Exodus reacted, the two robots met head on!
      With equal power between them, a stalemate ensued until Exodus broke away and aimed for its opponents side, but Wedge Devolution still turned faster and caught Exodus, pushing it into King Cobra and letting the House Robots axes smash the titanium top! Exodus had to struggle for a few moments before it got away, but that just allowed Wedge Devolution to come under the rear wedge again and flip, this time leaving Exodus propped against the wall! Exodus used its tracks to shift itself, but didnt drop down before Wedge Devolution came in again and gave it a taste of its own medicine - or rather, a taste of the arena disc! Exodus turned again as Wedge Devo charged after it - the two robots ended up parallel before Wedge Devos faster turning allowed its flippers blade to come under Exoduss inverted wedge again. It fired the flipper, and Exodus was successfully tossed over! Managing to run underneath Exodus before it settled, Wedge Devolution decided to finish the rookie, driving it against the pit release! But as it turned, Exoduss tracks were used again to try and run off the wedge, and it was left propped against Wedge Devos side! This ultimately failed to save it as Wedge Devolution turned to get a better grip, then ran Exodus back towards the pit, and down and out!
      CEASE!
      WEDGE DEVOLUTION GOES THROUGH TO THE QUARTER FINALS!
      Now we finish off Round 2, with Back To Rock III taking on Inferno!
      House Robots: The Martian & Assassinator
      3, 2, 1 - ACTIVATE!
      Back To Rock III rushed forward - straight past Inferno and into the pit release! Swerving away from Infernos advance, it then charged head on! It didnt fire its lifting arm quite fast enough and so was spun away, the teeth having struck the front plates! Having failed to fly into the pit, Inferno moved ominously towards Back To Rock, who charged in again, still taking a hard knock itself without sending Inferno towards the pit! As Back To Rock tried to reverse away, Inferno managed to strike it on the side, tearing at the skirt! Dodging another attack, Back To Rock moved back towards Inferno and tried another charge, taking another hit to the scoop which left its front saw motionless! The disc on Inferno was slowed, but it was spinning again when Back To Rock attacked again! This time Inferno struck a front corner, leaving a scar in the titanium armour! Back To Rock now brought its rounded rear into Inferno - flung away again, it charged head on again, slowing the disc some more but still sustaining damage! Backing off a little and bringing the disc back up to speed, Inferno managed to hit Back To Rocks corner again, denting the titanium even more!
      Looking unhealthy but still functioning, Back To Rock III reversed back into the pit release while the slower Inferno chased it! It skidded around Inferno and tried charging it towards the wall - but after the hit, Inferno didnt fly quite that far! Back To Rock recovered quickly and with its next rush, managed to send Inferno nearer to the wall! The teeth grazed it, and Inferno was knocked for six, nearer to the pit! However Back To Rock III had been slowed - the hits to the front had jammed the left front wheel! Still, it pressed on, ramming Inferno again, but still the spinner didnt quite go into the pit, and now Back To Rock III had taken even more damage! As the scooper reversed in, Inferno was lucky not to fall in: as the pit closed, Back To Rock limped back towards the release! Inferno came back towards it, and Back To Rock rammed it yet again, only to be flung against the wall with a wide wound in its front panel! Now the damaged Back To Rock was moving even slower, Inferno came back in and ran into the damage it had already caused, ripping the panel open even more! This attack didnt tear the panel off, but it was enough to switch Back To Rock III off! Inferno spun down as its brave but knackered opponent was counted out!
      CEASE!
      INFERNO GOES THROUGH TO THE QUARTER FINALS!
      So now we have the draw for the quarter finals:
      Troubloon 6 vs Wedge Devolution
      SoR X vs Wedginator Devilution
      Achilles vs The May Tracks Has You
      Inferno vs System Shock 4.0
      Send in those tactics and predictions! And thanks for the positive comments - Im glad I can still please!
        Still wooty as ever for the most part Richard, keep on going
        PREDICTIONS:
        Wedge Devo to get Troubloon down the pit after much flipping
        Wedginator vs. SOR X...not calling this one. Sorry, but its close and could genuinely go either way.
        May Tracks to get Achilles down the pit after much flipping
        Inferno has got to catch fire at some point. Its a physical impossibility, and that goes for both the chances of it winning and the robot itself. :P
        Seriously, running two Mags at 36v with no mention of any protection on them...Pauls toast. He has to be.
          Yesh, good ol battles once again, Richie. You can still definitely please.
          Now, quarter-final line-ups!
          Oh...dear. The VFT6 champ. Eek. :S
          The ONLY good things are that Im invertible, and there are no OOTAs, so flipping me over does essentially nothing but delay me a bit. However, I cant underestimate Mr. Most Popular Vapourbot, so I will have to do my best.
          Stay WELL away from the pit and house robots, and I mean WELL away, and try to immobilize Wedge Devo with the discs. If I can get his flipper to open prematurely, attack the rams. Attacking the skirts does relatively nothing as I dont plan on getting under Wedge Devo, so just keep hitting, hitting, and more hitting, preferably with the rear disc since its higher up.
          Son of Ripper X vs Wedginator Devilution
          Holy God, YES. We meet at last, SoR.
          It worked before, so lets try it again. Grapple him with the barbs and send him down the pit. Crash into the spinning rim to stop it first, but try not to get the barbs ripped off, lol. Stay away from the house robots.
          Did these two fight before? Regardless, May Tracks FTW.
          Someone please tell me why Inferno got this far. System Shock through easily.
          Lookin good Richie, and good luck to both Steve and AJ.
            Why do people hate Inferno SO much :sad: Hes not THAT bad Kody! Whats he done wrong, dont balme him, blame his fath...oh - he doesnt have one /
            Troubloon has done EXTREMELY well so far, and well done toKody for creating such a good vapour thats done so well, but Wedge Devolution is going to make mincemeat out of it, as I believe its Hardox will take the blows and get under the discs each time and flip it about like nothing to win the JD.
            SOR X vs Wedginator Devilution
            Im siding with Kodster on this one, as his barbs are what that rim is going to hit, and those barbs are as tough as tough stuff Wedginator to stop the rim and pit SOR quickly.
            Purely depends on who gets under who on a first hit. If Alex gets under, hell control the fight. If vice versa, then Alex is doomed
            Ive done well so far, which is good, but I think I can get further. I wont get through the 4-7mm thick Hardox, and since its a monocoque, no point is trying to remove it bolt by bolt from the chassis, so Ill just go for the aggressive approach - spin up and JUST KEEP HITTING HIM! Liam didnt state shock-proofing, so I should shock-kill him OK. Failing that, try to dent the side armour ONTO the gears and chains and try to stop his wheels turning.
            Good luck Liam - please come back :sad:
            PS: WOOT! I beat Back To Rock III - the best moment of my day Awesome fights Richard, and I look forward to the Quarters.
            (Message edited by paulc on November 04, 200
              Paul, Ive tried to tell you whats wrong with Inferno before, sometimes subtly, sometimes not, but the fact remains that youre not listening to me about it.
              Thats why we seem to hate it
                Awesome fights Rich, and may I say again what a pleasure it is to see you writing again
                Achilles... Not the opponant I was expecting, but nevermind.
                Tactics as ever are to get under the side and damage the tyres, making him hobble around and thus be unable to manouver as well, and also compromise his front GC. If the wheels are uneven, so will the GC.
                Thanks to his waaaay overkill Etek drive and top speed, May Tracks should easily be the more controllable machine.
                Im guessing Wedge Devo, Wedginator Devil and Inferno through the other fights.
                  Great fights again, Richard! You€™re definitely back to your best.
                  SOR X vs. Wedginator Devilution
                  This should be a good fight. I€™ll start off by trying to cause some cosmetic damage. The skirts look fairly tasty, so they will be the first target. If I can rip those off it should rack up damage points and allow me to get under it easier. Then I€™ll go for those barbs. They are strong, but I think a few good hits could dislodge them. The 5mm Hardox is probably a bit too tough to damage, but I€™ll have a go anyway. Once I€™m content with the damage caused, I can start flipping. As long as I still have battery life, my flipper should keep going, where Wedginator has limited CO2. So that could play in my advantage. I just need to make use of my weaponry to flip and damage as much as possible. Then try and get it into the pit.
                  Good luck Kody!
                  Wedge Devo, Achilles and System Shock FTW in the other battles.
                    Most excellent, Richie!
                    QUARTER-FINALS
                    Troubloon 6 VS WEDGE DEVOLUTION
                    No sense in wasting good CO2 on an intertible opponent in an enclosed arena. Im going to stay passive for this battle and save the flipper for when it is truly needed. Charge Troubloon right from the off to stop whatever disc is in the way. Quickly try and slide underneath and slam it into whatever hazard is handy - the disc, the CPZs, the Pit, anywhere. Wedge Devo should hold up quite well against the double discs, but Id rather deal with Troubloon ASAP. Better safe than scrapped.
                    Good luck to Kody and the other survivors!
                      Also, Liam says he wants to use the lifter set-up for System Shock 4.0 and flip Inferno.
                        How are you still in touch with Liam?
                          Thanks for all the tactics and comments!
                          Weve reduced 32 robots to 8, and reached the quarter finals! In our first battle, will Wedge Devolution get revenge on Troubloon 6 for knocking out its teammate Spin Dash Unleashed?
                          House Robots: Drilla Killa Ultimate & Ultimate Snakebite
                          3, 2, 1 - ACTIVATE!
                          Wedge Devolution charged straight away, while Troubloon 6 remained static to spin up its flywheels! As the flipper approached, Troubloon swerved to one side and managed a glancing blow on Wedge Devo! Unfortunately, this turned Wedge Devo a little and allowed it to run into Troubloons side, but Troubloon 6 turned again and the two robots became parallel - again, Troubloon used its own weapons first and gave Wedge Devo another knock! Wedge Devo dodged the next advance, turned round and came back in: this time, with the right manouvre, it caught Troubloon 6 in the side! Managing to slip its plate under the skirt, it ran Troubloon 6 towards the nearest House Robot, Ultimate Snakebite! As Troubloon 6 was pushed up onto Snakebites wedge, the House Robot lifted its jaws to tip the spinner, before giving it a taste of the rear flywheel! Troubloon 6 almost rolled from the impact, before being shoved towards the arena disc by Wedge Devo - but Troubloons own flywheel caught the arena wall and knocked it out of its opponents clutches, allowing it to whack Wedge Devolution in the side before the champ could respond!
                          As Wedge Devo was smacked against the wall, Troubloon 6 had the chance to hit it again with the rear flywheel, but Wedge Devo moved again and ran into Troubloons side again! A few seconds later, Troubloon was being run right back into Ultimate Snakebite, who managed to clamp it in its jaws this time before doing a victory spin! Troubloon 6 was released with a few toothmarks, before finding Wedge Devo attacking again! Troubloon deterred the champ with a slight hit on the front, then managed to twist again and give it a harder side blow! As Wedge Devo went round to the side again, it was struck by the rear flywheel, but on the next go, it was luckier, coming into the side at a better angle and getting underneath its opponent again! Seeing the pit release dead ahead, Wedge Devolution ran straight into it, but as it turned to take Troubloon 6 towards it, the front flywheel hit the wedge and Troubloon ricocheted off! Wedge Devo quickly ran towards it again, manouvering and pinning Troubloon 6 against the arena wall before it could escape! When it came underneath again, it brought Troubloon 6 to the left of the open pit: it accidentally let one of its own wheels run over the abyss, but when it tilted, Troubloon 6 slid down into the pit, while Wedge Devolution managed to drive away, without having used its famous flipper at all!
                          CEASE!
                          WEDGE DEVOLUTION GOES THROUGH TO THE SEMI FINALS!
                          Next up, the quarter finals other flipping wedge, Wedginator Devilution, faces former champ SoR X!
                          House Robots: Megaraptor & King Cobra
                          3, 2, 1 - ACTIVATE!
                          Wedginator Devilution came rushing forward while SoR X moved cautiously away as its rim began to spin. The VFT1 champ then reversed towards Wedginator, who moved quickly and brought its front into the rim, which spun it into the arena wall! SoR X quickly moved in and went crash into the side before Wedginator could move away! It managed another glancing side blow as Wedginator turned round, but then had to reverse away as Wedginator charged towards its front! Wedginator went round the side and ran head on into SoR X, taking another little dent on the front - SoR X moved away to get spinning again, and as Wedginator attacked again, it brought its spinning rim back into the front, striking the barbs but not getting caught! As Wedginator was knocked away again, SoR X got in another side strike, ripping the left skirt! It aimed to attack again, but Wedginator ran back into it - unfortunately, SoR X was still resisting being caught thanks to its spinning rim!
                          Both robots ended up comically missing each other on the next charge - as they turned and came running in again, SoR X hit the left skirt again, and half of it finally parted company with the main body! SoR X excitedly chased Wedginator, who managed to outpace it and run back into it to slow the rim! Knocked against the wall, Wedginator was well positioned to charge again, but the still spinning rim still kept it from getting underneath SoR X, who after being rammed a second time, ran into Wedginators side, unhindered by the broken skirt, and flicked it onto its back! Wedginator was forced to fire its flipper for the first time - as it landed right side up, SoR X ran into its other side, but couldnt get past the intact skirt! It pushed Wedginator for a moment before finally breaking away and hitting Wedginator with its rim, almost in annoyance! Wedginator angrily chased SoR X, who almost obligingly ran back into the front to try and dislodge the barbs, but they remained intact! Wedginator dodged the next assault by SoR X and then ran into it head on! As the more powerful robot, it shoved SoR X backwards until they reached the arena wall, whereupon SoR Xs rim sent the spinner/flipper skimming away, with Wedginator in hot pursuit!
                          Coming back to meet Wedginator Devilution, SoR X swerved at the last moment so its rim again hit the barbs - they still didnt come off, but it was able to spin Wedginator into the wall and attack the right skirt, accidentally hitting the pit release in the process! Trying to seize the oppotunity, Wedginator swerved and rammed SoR X against the wall to try and slow the rim! SoR X bounced off again, now some distance from the pit - it hurriedly reversed away from the advancing Wedginator until its rim was spinning fully again, before attempting to go for the right side! Wedginator stopped it with its front again - SoR Xs next attack missed the side, but it was able to run into the left side again on the next go, this time flipping Wedginator into the air and against the arena wall! Wedginators self right almost brought it into King Cobras CPZ, but its most immediate worry was SoR X ramming it again and causing damage to the right skirt! However, Wedginator reacted by running into SoR X again and sending it bouncing off King Cobra! Settling on the arena floor again, SoR X ran back in, glancing off Wedginators left side and almost colliding with the arena disc as it made evasive manouvers!
                          On its next attack, SoR X successfully ripped the right skirt, but Wedginator spun round as it came in to try and flip again, and met the front wedge! The result was SoR X being rammed against the wall once again and bouncing off! The VFT1 champion now went for the pit release while Wedginator Devilution followed - as Wedginator ran towards it, it glanced against the rim and was knocked, allowing SoR X to run under its exposed right side, turn Wedginator around and fire its flipper! Unfortunately, it was trying to be a little too fancy, as Wedginator landed on its back to the side of the pit! SoR X rushed to catch Wedginator as it flipped itself over.....and succeeded! Wedginator Devilution could do nothing to escape as it was properly shoved into the pit, as it had already done itself to Flipping Hell and Black Panther!
                          CEASE!
                          SoR X GOES THROUGH TO THE SEMI FINALS!
                            What a surprise, thats the end of my VFT...
                            Well now that Im out, there can only be a classic Wedge Devo vs. SoR showdown left...of course this being VFT itll be good.
                              Now a clash between two flipping/lifting box wedges, Achilles and The May Tracks Has You!
                              3, 2, 1 - ACTIVATE!
                              Achilles went for a full-on charge - and ended up running past The May Tracks Has You as the other robot tried to turn into the side! Quickly turning and coming back, Achilles just managed to run into its opponents side, pushing for a moment before the spatula came under the skirts! Achilles soon had May Tracks in the air on its arm - The Martian was close by, so Achilles headed for the CPZ, and May Tracks got a taste of the alien tripods saws, as well as a blast from the flamethrower! It was left in this position for some time, the tracks rotating helplessly, while firing its flipper had little effect! When Achilles finally decided to end the torture, it rammed May Tracks against the wall, overturning it! May Tracks quickly selfrighted, but Achilles was soon on the attack again, and the only escape route was towards The Martian! Desperately, May Tracks ran into the House Robot, firing its flipper and tipping it, enjoying the sweet taste of revenge! Achilless path was blocked by the House Robots body, allowing May Tracks to make good its escape!
                              The May Tracks Has You was quickly back in the action, taking a little nick from The Martians saw as it ran into Achilles side on! Pinning its opponent against the wall, it managed to surpass the skirts with its wedge extender and bring the famous wedge spikes into play, slicing into Achilless front go-kart tyres! Achilles was then flipped onto its back - a slower selfrighter than May Tracks, it was unable to avoid being rammed across the arena by May Tracks and flipped against the opposite wall! As Achilles was turning itself over again, May Tracks manouvered round to the side and shoved it into the corner - the titanium baseplate held up to the spikes, which missed the tyres this time, although Achilles did receive a flip for good measure! However, it landed on its wheels, and was still pretty mobile! Achilles ran aggressively at May Tracks, who quickly responded - the two robots collided and turned together, before May Trackss superior speed brought it round to Achilless side! It was soon time for another hard ram, and this time, the spikes met the front tyres again, ripping them more substantially! Flipped again, Achilles balanced on its sloped side for half a second before falling over, allowing more time for May Tracks to attack again, this time propping Achilles against the south wall!
                              Achilles, however, slid off the wall, causing The May Tracks Has You to almost comically collide with the Lexan! However, the damage to the front tyres had affected its mobility - it was a bit wobbly on its wheels! When May Tracks turned, the robots met head on, straining against each other - Achilles just managed to push May Tracks back towards Assassinator, who gave it a quick thump with the pickaxe! May Tracks escaped with a reverse corner that any driving instructor would be proud of - Achilles tried to turn after it, but May Tracks ran round to its side again, only to find Assassinator blocking it as it tried to shove its opponent! That said, Achilles itself got a taste of the pickaxe in this collision! May Tracks eventually shifted Achilles and brought it back against the wall, using the spikes against the rear tyres now! The flipper neatly flicked Achilles over, into Assassinators CPZ - the House Robot happily turned and hammered Achilles while it selfrighted and reversed out of the way! Achilles was unable to turn in time before it received another attack from May Tracks - again, the flipper robot missed the tyres and only scraped the baseplate, but still flipped Achilles back onto its back!
                              The May Tracks Has You again ran under Achilles as it was selfrighting, shoving it towards the arena disc, but Achilles overturned itself just in time and managed to swerve away! Both robots turned, Achilles now with some difficulty with its torn tyres! May Tracks came back into the side after a little dancing around, using its perfected technique on Achilles again to cause more damage to the underbelly! Landing on its wheels, Achilles ran to attack May Tracks, but now wasnt quite as fast! May Tracks ran into it head on, now able to bring the wedge extender under the spatula, for another hard ram - again, only the armour suffered the spikes, and it was still holding up! Flipped again, Achilles again landed on its wheels, and actually managed to run into its opponents side, but as it was wobbling due to the tyres, the spatula was no longer able to get under the skirts straight away! It could push, however, shoving May Tracks slowly across the arena towards the arena wall and pinning it! With a slight struggle, May Tracks managed to escape Achilless grip, then come under the side again and shove it right into The Martian, who sliced enthusiastically at Achilless sides! Achilles reversed away, but May Tracks soon caught up with its limping opponent and rammed it back against the wall - the spikes now left even more scars in the baseplate, but still couldnt pierce it! With time running down, May Tracks flipped Achilles again, but only gave it a half-hearted ram as it was selfrighting! When the two robots collided again, they turned once again before May Tracks came back underneath, now pinning Achilles against the wall for the seconds that remained!
                              CEASE!
                              Dominance: A - 3/10 x 6 = 18, MT - 8/10 x 6 = 48 (Achilles was dominant at the beginning, but almost completely dominated from then on in)
                              Damage: A - 3/10 x 5 = 15, MT - 5/10 x 5 = 25 (both robots did some damage to their opponents armour (directly and indirectly), but MT knackered As tyres as well)
                              Aggression: A - 5/10 x 4 = 20, MT - 8/10 x 4 = 32 (sadly, Achilles didnt get much of a chance to be aggressive with MT all over it)
                              Control: A - 7/10 x 3 = 21, MT - 8/10 x 3 = 24 (MT was a little more controlled)
                              Strategy: A - 5/10 x 2 = 10, MT - 8/10 x 2 = 16 (MT had more of a strategy - to go for Achilless sides and use its spikes and flipper to attack the tyres - and carried it successfully)
                              Style: A - 3/10 x 1 = 3, MT - 7/10 x 1 = 7 (MTs flipping and ramming was more stylish than Achilless lifting and ramming)
                              Total: Achilles = 87, The May Tracks Has You = 152
                              THE MAY TRACKS HAS YOU GOES THROUGH TO THE SEMI FINALS!
                              And finally, which rookie will go into the semi finals - Inferno or System Shock 4.0?
                              House Robots: Horcrux & The Martian
                              3, 2, 1 - ACTIVATE!
                              System Shock 4.0 came blazing forward as fast as it could while Inferno began to spin, backing away from its advancing opponent as it did so! With a crash, the two robots met! System Shock was spun away, while its lifting wedge tipped Inferno a little so its teeth hit the floor, slowing the disc and causing Inferno to bounce a little! The spinner soon stabilised, only for System Shock to reverse hard into it, having been spun round in that direction! System Shock was cast away again, but not quite as far, and was now able to bring in its lifting wedge again! Tipped so that a tooth grazed the floor again, Infernos disc was finally slowed enough for System Shock 4.0 to get in underneath properly! The rammer raised its wedge and pushed, but Infernos wide circumference meant it wasnt going to be overturned easily! Balancing its opponent on the wedge, System Shock ran it into the wall: Inferno tipped up....and back down again! Carrying its opponent away, aware of the 30 second time limit, System Shock 4.0 tried another hard ram! Inferno was tipped up again....and this time, was left leaning against the wall! With a side bump from System Shock, it landed on the floor, on its back! With no srimech, Inferno was helpless, while System Shock 4.0 spun victoriously, obviously unwilling to push Inferno onto the arena flipper!
                              CEASE!
                              SYSTEM SHOCK 4.0 GOES THROUGH TO THE SEMI FINALS!
                              Semi-Final Lineup:
                              System Shock 4.0 vs The May Tracks Has You
                              SoR X vs Wedge Devolution
                                Awwwwsome fights
                                Tactics are to aim for the sides and flip it around and into the house robots/arena disc until hes not as mobile. Then try to pit him.
                                Wedge Devo to win the other fight.
