Enjoy The Violence - 80kg Tournament
  • #31
    Junkyard Mawler vs. Shadow
    Dunno at this point. Just flip it around, I guess. Aim for OOTA.
    Full Life Consequences vs. Wrath Of Fangorodrim
    Bwahahaha, perfect, just the kind of bot I wanted to face. Good luck trying to get any type of hold with my curvy shape, Mr. McG. :wink: Basically attack from anywhere, the claws should be able to get a good hold in. Dump him somewhere nasty, or the pit if theres one.
    Saying just the kind of bot I wanted to face isnt going to make Joey make me lose on purpose, is it
    • #32
      Come on, I dont make people lose
      All I do is alter their odds of winning somewhat...
      • #33
        Hooray for line-ups!
        CHAOS 2 VS Delta Rex
        Avoid the front and get under that 8mm ground clearance at the sides. I assume from its stats that Delta Rex has flat sides, so Ill throw it onto its side ala Chaos 2 VS Steg 2 and leave it for dead. Then Ill have a dig at the House Robots.
        FULL-LIFE CONSEQUENCES VS Wrath Of Fangorodrim
        The key to victory here, I think, is Full-Lifes superior traction. Fangorodrim may have Tazbots manoueverability, but Full-Life has Tornados pushing power and acceleration. The main plan here will be to avoid the front, get around the sides or rear and grab on for dear life. The claws and saw will hopefully do some damage to the titanium and polycarb shell, or at least get a darn good grip. Dump it in the Pit ASAP and have a nibble at the House Robots.
        EDIT: Even if the claws cant get a grip on it, I can still push it all over the shop.
        (Message edited by Steven_McG on June 23, 200
        • #34
          Stats by Wednesday, I promise.
          • #35
            It be Wednesday...
            • #36
              Tactics:
              Delta-Rex v Chaos 2
              Keep flipping, over and over. I can knock my myself back over with the flipper if he does manage to beach on my side (I hope). Hell run out of gas to self-right before I do.
              Bambi v Cassius 2
              Drive in, grab, lift, pit
              Good luck everyone
              • #37
                My computer decided to crash yesterday, perminantly. I suggest you be very patient.
                • #38
                  I suggest, seeing as youve been on the forum since then, that you post your stats by next Wednesday, or I will be forced to invite entries from others and redo the draw.
                  • #39
                    Ive been having MAJOR computer (and specifically, internet) troubles recently. Anyway, Ive got the stats for Bad Temper Jr now. IF I dont get Shadow done, just replace him with a random real robot.
                    BAD TEMPER JR
                    Weight: 80 kilos
                    Body Shape: Rectangular, long and low. Similar dimensions to Tornado, but not invertible.
                    Speed: 12mph
                    TC: 0
                    GC: 7mm
                    Wheels: 4 inner
                    Armour: 6mm titanium
                    Power: 3x 12v batteries, powered by S28-400 Magmotors, at 24v...the usual.
                    Colour: Red underbelly, black sides, grey top, white weapon.
                    Weapon: Pneumatic knife blade, powered by CO2. Theres about 40 odd hits in it. Basically, it looks like someone stuck the blade of Overkill onto the axe arm of Dominator 2.
                    Srimech: The weapon goes that.
                    Notes: I have a little Lego model if you need pictures.
                    Strengths: Persistant.
                    Weaknessess: The arm is fairly long, so it has to be a distance away to work effectively.
                    • #40
                      ...you DO know that whatever realie Joey chooses will probably be crap, right?
                      • #41
                        No, itll be something I like
                        -2>...admittedly, a lot of the realies I like are crap...
                        • #42
                          El Tactics Grande!
                          Iris VS Bad Shadow Junior: Main tactic in this fight is to push BSJnr around whilst avoiding the knife blade. If possible, stay close to it so it cannot attack, and keep acting tenaciously and aggresively. If all else fails, slam into it a few times using the spike and try and get it into the pit.
                          Diva vs Mortis: Flip, push to arena wall, flip again.
                          • #43
                            Try Temper.
                            • #44
                              Try getting another sets of stats up. :wink:
                              • #45
                                I mean, try calling it Bad Temper Jr. Shadows stats will be up as and when.
