Eye Of The Robot - Series 5 Re-Opened
Guess what Mr. Cuomo has given you all - some well-written Round Two fights of E.O.T.R.5!!! See who makes it to the Heat 1 Final!
ROUND TWO:
Intriguer (1) vs. The Deer
Gabriel III (17) vs. Leviathan
INTRIGUER vs. THE DEER
Booth #1: Kody K
Booth #2: Martyn F
Roboteers, stand by!!!
3€¦2€¦1€¦activate!!!
WOOOSH! Intriguer is straight out of the trap, smashing into The Deer like a car smashing a brick wall! Martyn doesn€™t even have time to respond by closing his claws, as Kody uses his spiked front to smash under the ground clearance, and bring the axe down, smacking the Hardox top of The Deer€¦and he€™s dented it! Already The Deer is in trouble! Martyn winces, and turns his robot to the right, trying to find a road to the centre of the zone€¦and he€™s made it - The Deer rushes for freedom, but Intriguer€™s 17mph compared to The Deer€™s 15mph is no contest - BANG! The Deer is pummelled again, this time from behind, and Intriguer has The Deer on the ropes, as Kody presses the power button, driving The Deer into the flywheels of fury! BANG! Intriguer slams the hammer, piercing the Hardox skin this time - and Martyn is now starting to fear the worst, and Intriguer slowly edges The Deer towards the blades€¦CRACK! Martyn looks up stunned, as part of his Titanium crushers is ripped clean off the claw. Kody€™s enjoying this, as he backs up, The Deer still in his clutches, and now powers forward again! CRACK! This time, the whole claw is snapped off! This is murder. Kody€™s axe finally shakes loose, but a miracle has happened - The Deer is still moving, despite the mashing it€™s been receiving! Martyn now changes tactics - he goes from defensive to offensive; and now powers at Intriguer with his 18hp of nudge - but once again, Intriguer comes out better, with his 24hp of nudge! The Deer is SLAMMED against the wall€¦SO HARD HE€™S NEARLY THROWN OOTA! Up against the wall, Intriguer slams his hammer again, and another dent appears. Kody is now continuously firing the axe, causing dent, after dent, after dent€¦ BUT HAS NOW CAUSED A HOLE! The power of the champ is evident here, and that repeated pummelling - has it killed The Deer€¦NO IT HASN€™T! The Deer€™s wheels are still rotating€¦but they aren€™t touching the floor, and that€™s what matters, as the countdown starts to signal to continous, destructive run of the champion Intriguer!
10€¦9€¦8€¦7€¦6€¦5€¦4€¦3€¦2 €¦1€¦cease!!!
Intriguer hits the pit release button, and rushes back over to The Deer - BANG! Another hammer it, another hole in the Hardox top. Kody reverses with The Deerstill impaled on the axe, wheels of The Deer finally impossible of moving, so Kody performs the burial service with a shove€¦BANG! Into the pit goes The Deer, and into Round Two goes Intriguer!
Result:
The Deer is pummelled to death€¦oh Deery me!
INTRIGUER (1) GOES THROUGH TO THE HEAT FINAL!!!
GABRIEL III vs. LEVIATHAN
Booth #1: Joey M
Booth #2: Danny B
Out come both robots, at equal speeds - 15mph each. Gabriel with the narrower front is being careful, as he needs to aim correctly to get under€¦but Leviathan isn€™t being restraint in the slightest - and barrels straight into the seeded robots side, and firing that awesome Behemoth styled scoop with 1000kg of lift - and the seed flies over! Joey quickly self-rights€¦RIGHT ONTO LEVIATHAN€™S SCOOP! Danny puts all 18 of the horses powering his tracked driven machine, and shove Gabriel across the arena - and Joey can€™t escape! FLIP! The match is over in seconds, and it ends with the seed OOTA!
Result:
Gabriel III (17) is one sequel too far!
LEVIATHAN GOES THROUGH TO THE HEAT FINAL!!!
HEAT FINAL:
Intriguer (1) vs. Leviathan
Send in tactics, comments, predictions and something really fantastic for my birthday...like Jaws (last one not required until 15th of November)
ROUND TWO:
Booth #1: Kody K
Booth #2: Martyn F
Result:
Booth #1: Joey M
Booth #2: Danny B
Result:
HEAT FINAL:
