NSIREC2 Final signups
  • #31
    lol, Dave, youll need 4 more vapours :P
    • #32
      Awww balls !
      Gimmie a little while and Ill cook up something
      • #33
        alright, thats 11
        Ready when you are Dave, dont let somebody steal your spot now
        • #34
          alright, for those who dont know kody toldme Dave is getting his stuff in soon, so with any luck this can finally kick off
          • #35
            Do you mind if I change my squad, because almost all the robots have been updated since:
            Team Wlesh Warlords
            1) Brutalis 2.0
            2) Apocalypse
            3) Helix
            4) Bumblebee
            5) Exodus
            6) Forza
            7) Duncan
            Gulp 2.0
            http://strickenone.proboards99.com/index.cgi?board=teamwwhttp://strickenone.proboards99.com/i...i?board=teamww
            • #36
              thats fine
              • #37
                Now Im hearing theyll be in REAL soon. Why is it that Im ALWAYS IMed when Im away from the compy?
                Anyway, chances are well get this started up sometime within next week, with any luck.
                • #38
                  Updated List:
                  Nitro-Gene 5.0
                  Knyfe
                  D.V.D: The Sequel
                  MeCannibal 3.0
                  Heyght
                  The Rock
                  Tri-Tainium
                  WORCK-ER
                  • #39
                    Methinks by the time Dave gets his stats in, Tengu 8 will be completed.
                    • #40
                      I have more important things to worry about than vapourbots, so keep your shorts on!!
                      Just for the Draw Purposes, my 4 new bots:
                      When Love and Death Embrace
                      Random Violence
                      Smash and Grab
                      Shadow
                      • #41
                        Stats for Team Hell Beta
                        Weight: 100kg
                        Size: 80 x 70 x 20cm (each botlet)
                        Weapon: Hydraulic Crushing jaws: Love has a pair of horizontal claws (Ala Kan-opener), and Death has a vertical jaw (Ala Killalots claw, with an extended flat front like that on General Carnage, Series 3).
                        Both powered by 40mm bore hydraulic ram on 3000PSI, powered by a mag-motor operated pump
                        Power: 2x Bosch 400 motors at 24v
                        Speed: 12mph
                        Drive power: 4bph
                        Notes: More of a controling robot than a damager, but can still damage lesser armourment
                        Turning Circle: 0cm
                        Armour: 3mm titanium
                        Wheel Type - 4 vulcalon treated Aluminium hubs (Ala Storm 2), but set so there are 4 wheels but set like a 2WD (2 wheels on same output)
                        Strengths: Good at controlling other robots, Invertable
                        Weakness: Each bot a bit on the light side
                        Colour: Love: A vermillion red with a dark pink heart in the middle with Love written across on a parchment. Death: Carbon black background,
                        with a gravestone with Death chiseled into it, and the reapers scythe leant against it
                        Shape: basic rectangular box with angled sides
                        Random Violence:
                        Weight: 100kg
                        Size: 70 x 70 x 30cm
                        Weapon: A 1-peice High grade steel spinning shell (Cylindrical) with 3 claw shaped teeth on either side set at different heights and angled upwards.
                        Being 1 peice means there is no weak welds to break. The output gear is cut into the inside, like the wheels of Tanto. The shell is spinning at 2500RPM,
                        so the start up is easier to get going, Output force roughly calculated at 105Kj. The shell wall is 15mm thick, and the shell takes up half the bots weight.
                        The teeth are angled up to send opponents up and away from the bot, whilst forcing RV downwards, not bouncing off uncontrollably.
                        Power: 2 Bosch 400 at 24v, Weapon: Lem 130 at 36v
                        Speed: 12mph
                        Drive Power: 4BHP
                        Notes: bearings on robots base stop the shell from going inwards.
                        Turning Circle: 0m
                        Armour: 15mm Steel (the shell)
                        Wheel Type: 4x Wheelbarrow type (no need for great traction)
                        Strengths: very tough, reliable, and very destructive
                        Weakness: Once flipped, thats it
                        Colour: Black and red tear graphics, name on top
                        Smash and Grab:
                        Weight: 100kg
                        Size: 140 x 120 x 45cm
                        Weapon: Pneumatic Pincers and 5kg Sledgehammer. Claws on low pressure (150PSI), Hammer on Full pressure (725PSI).
                        Claws are Mild steel. Hammer knocks out about 8KJ, swings a full 180 degrees.
                        Power: 2 Bosch 750 motors, 24v, 8:1 ratio (decent speed, good push, simaler power to Shunt)
                        Speed: 16MPH
                        Drive Power: 10BHP
                        Notes: Very much Dead Metal in appearance
                        Turning Circle: 0m
                        Armour: a collection of steel pipe and 5mm Hardox plates in strategic places (Claw pivots, over motors, batteries, speedo, and gas tank
                        Wheel Type: Go-kart x 2
                        Strengths: Can put repeated blows in the same places, Hard to flip, uses hammer to self right when it does, weapon synergy
                        Weakness: Armour not brill with spinners.
                        Shadow:
                        Weight: 100kg
                        Size: 100 x 90 x 25cm
                        Weapon: Brute Force and a pair of 9 hardox ramming spikes.
                        Power: 2 Magmotors, 16:1 ratio, 36v, pushing power unknown at time of writing, but Ill get it to you
                        Speed: 22MPH
                        Drive Power: Est. 18BHP
                        Notes: Satanix in HW form
                        Turning Circle: 0m
                        Armour: 10mm Steel in all places
                        Wheel Type: Nylon, with high grip mountian bike tyre
                        Strengths: Tough, speedy
                        Weakness: Lack of offensive weapon
                        Shape: Look on Team Hell Website for Satanix. Its that shape
                        • #42
                          Once AGAIN I get IMed while away. This is a freaking creepy trend.
                          anyway, ive been surprisngly busy over the summer, so it might take me a while to get this show on the road. Ill get there though, and I shouldnt be long.
                          • #43
                            Replaced D.V.D: The Sequel with Inferno. Stats on my section in the VED board.
                            • #44
                              Not to be picky, Paul, but its ZED, not VED. :P
                              • #45
                                Alright, my schedules calming down a bit, so this is gonna get booted off soon.
