Crash & Burn: Mini-Tournament of Death
Not v-v-v-vengeance, just vengeance.
						 ) with the hammer, but Spin Dash squeezes further into the CPZ, right at Obelix€™s side€¦and begins to push, the stationary sawblade slid under the ground clearance! Damocles pauses and backs off, not wanting to damage a fellow house robot as Steve pushes Obelix towards it. Gabriel shoots in to take advantage of Spin Dash€™s distraction, and finds that Steve isn€™t all that blind because Spin Dash backs away as Gabriel comes in from the side. Spin Dash moves in to push Gabriel, and sends him straight towards Obelix who has turned right around to give his victims wrath€¦WHAM!
  A few more inches, and Gabriel is plunged into the deep depths of the pit.
  spinning back at maximum potential again and heads in Dolce€™s direction. Dolce does not wait for The 6isc to make its way over to it, but instead greets the barbell bot with a menacing shunt straight into the whirling blade!
 spinning back at maximum potential again and heads in Dolce€™s direction. Dolce does not wait for The 6isc to make its way over to it, but instead greets the barbell bot with a menacing shunt straight into the whirling blade!  Ancalagon moves away from the saws quickly, but releases The 6isc over them, who gets hit again€¦BZZT! More sparks off the hub€¦and€¦The 6isc, are you mobile at all? Dolce moves in to check€¦bump. No movement, but time is ticking down€¦
  ) I have the 2nd round line-ups:
