Crash & Burn: Mini-Tournament of Death
Here are my stats, everyone. Say hello to the sixth member of the Spin Dash clan!
NAME- Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
SHAPE- skirted box, with rounded sides and back.
COLOUR- dark blue bodywork, with red-and-white striped skirting.
WEIGHT- about 100kg
DIMENSIONS- 100cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
ARMOUR- 4mm Hardox
MOVEMENT- inner, 6WD
POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
NOTES- flies Scotland flag.
STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
PIC- http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
WEIGHT- about 100kg
SPEED- 16mph
TURNING CIRCLE- 0mm
ARMOUR- 4mm Hardox
 The 6isc (Frank)
 The 6isc (Frank)
						 First of all though, those 5mm Ti skirts look tasty. €œHardox hinges€ or not, my aim is to give them a couple of hits and wipe them clean off. Then, take to all those nice corners. Spin up the shell and smash it to as many pieces as possible. Target the edges and rip it up.
