ETC08 Extreme
  • ETC08 Extreme
    Paul, care to respond? :P
    EDIT: Thinning the armour down from 6mm to 5mm isnt going to help THAT much, probably make it go from 110kg to 95kg, and then you have to including everything else.
    (Message edited by kodster on June 07, 200
    • ETC08 Extreme
      Taking off 2 LEMS and their associated batteries might do it...youre not getting four LEMs, Hardox, and a nitrogen powered weapon in 100kg.
      • ETC08 Extreme
        Unless the Hardox is pretty thin.
        But yeah, follow Joeys advice and it should be okay.
        • ETC08 Extreme
          Ive already responded Kody - I think you need to move a bit faster :wink:
          • ETC08 Extreme
            I edited my message too, silly. :wink:
            EDIT: Just like I edited this one. :P Anyway, you still havent done anything about Shovearound-Gene 5.2.0 except make the dimensions almost impossible. :P
            • ETC08 Extreme
              Still somewhat overweight.
              • ETC08 Extreme
                And now he deleted it entirely off Zlaying Every Day... :P
                EDIT: Okay, seriously what the hell is going on here? :S First you thin the armour by a dismal amount, then shorten the dimensions so that its middleweight sized. Then you delete it entirely, AND RE-POST IT WITH THE SAME NAME OF THE VAPOURBOT ABOVE??? :P
                Im so confused. :S
                EDIT AGAIN: And now were back to square one. Paul, if you dont mind, would you post the stats you have NOW in the How Can I Improve thread? Please? :P
                • ETC08 Extreme
                  I started to get stressed that I wanted to keep most of the parts from Nitro-Gene 4.0, but without putting it over the weight limit, so I deleted it and started again.
                  And its not THAT small - Baldur Gamma is only 15cm smaller in length and 15cm shorter in width, but 40cm taller. And it hasnt changed too much, Ive thinned armour off the flipper and put it to use on holding the body-parts together along with the monocoque, to make sure that panels dont break off as easily this time around and Ive lowered the ground clearance to make it more controllable.
                  • ETC08 Extreme
                    The thing about Baldur is that its height makes up for its very small length and weight. If we halved the height, the length and width would probably double, or least increase by 1.5 times.
                    • ETC08 Extreme
                      ...my head is unwell...
                      • ETC08 Extreme
                        Get some ice for that, youre going to need it. :wink:
                        • ETC08 Extreme
                          Its probably got something to do with the fact that Im redesigning No Objections, mind :P
                          • ETC08 Extreme
                            Ah. Post it in the you-know-where place when youre done. :P
                            • ETC08 Extreme
                              Given that Nitro-Gene is facing serious issues about obesity () Im going to put Knyfe forward to challenge Flick instead:
                              http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=18 6http://strickenone.proboards99.com/i...n=display&thre ad=186
                              If Nitro-Gene is now fine, tell me and Ill have Nitro-Gene 5.0 instead.
                              http://strickenone.proboards99.com/index.cgi?action=display&board=tivapours&thread=17 7&page=1http://strickenone.proboards99.com/i...tivapours&thre ad=177&page=1
                              • ETC08 Extreme
                                Youre not willing to change the armour or motors on N-G 5.0, are you? :P
