Eye Of The Robot - All Stars
  • #31
    ...right?
    TACTACTACTICTACTICS:
    Psyclonizer vs. Killotine vs. Tengu vs. GABRIEL II
    ...great. Gabriel will spin around, and try and use the spikes to cause damage. With the shockproofing I reckon I could withstand a few hits, and if I get hit while spinning it probably wouldnt cause me as much armour damage as if I wasnt. Ill use the flipper though if it comes down to close quarters.
    Leprosy Infection vs. Whirligig vs. NO OBJECTIONS vs. The 6isc
    Spin. If not spinning, use the lifter to get anyone who could pose a threat out of the way, and target Leprosy over the other two if it comes down to it, as I know I can stop the weapon and have beaten it before - get it down the pit. Ill worry about the others when they worry me...
    Intriguing vs. NIDHOGG vs. E Clawdius Unum vs. Flick Of The Wrist
    Go for Intriguing, get the forks underneath the side, lift, crush, and pit. Then, go for whichever of the others is closest, and repeat, then the other one.
    Salamander vs. Die--Ceratops vs. Sheer Heart Attack vs. PHOENIX DOWN
    Ill use two claws for this fight - Die-Ceratops should be easy to get a hold of, so thats my first target, grab and pit. Then, Ill go for Salamander, seeing as I could get a hold of the axle with the claw, and then play things by ear.
    Good luck, people :wink:
    • #32
      Alright, if Joeys going to play awkward...
      Intriguings revised tactics
      Go for Nidhogg. Smack the axe onto the main body of Nidhogg until it dies from either something breaking, or just plain shock damage. THEN go for Clawdius.
      Open for a team-up, Martijn?
      • #33
        Kody, you do realise one goes through from each melee?
        • #34
          Id rather fight you at full strength rather than if Flick and Clawdius go out and Ive taken a beating.
          • #35
            Kody - only 1 robot goes through from each fight, so Ill have 8 robots in the next round. Your tactics of teaming-up are going to be worthless, as eventually, only 1 robot will go through.
            Its not the classic 4 way battle, 2 winners - its 8 x 4 way battles, 1 winner per battle.
            • #36
              Oh well, my tactics still stand, as the person I want to team-up with would generally be my preferred opponent when the others are killed off. Thats the beauty of it.
              And besides, Tira III is SoL anyway. Two flippers and a heavy ring spinner? Suuuuure.
              • #37
                I need a LOT more tactics from:
                AJ
                Steven
                Frank
                Chris
                Martijn
                Alex
                So if they can all send in some of their tactics, it could be a great help.
                • #38
                  I dont really have any immediate tactics, per se. Just do what the robots do best.
                  • #39
                    Tactics arent actually needed for fights to be written. They help, but fights can be written without them.
                    • #40
                      Yeah, Alexs tactics are as obvious as...a very obvious thing, that graduated from the college of obviousness with honours and is now Special Advisor to the United Nations Obvious Committee.
                      • #41
                        Paul, I hope youve remembered what happened in E.O.T.R. 4...dont go in that direction again.
                        • #42
                          My tactics for all fights will be as follows.
                          Black Panther will hit and run or should I manage to get a robot upside down, just bludgeon into it as logn as possible.
                          Tengu and Salamander will spin at opponenets in an attempt to damage them.
                          Achilles will ram into opponents and endeavor to thrwo them in a flipping motion.
                          Everyone shall aim for the weaker parts of their foe.
                          I think Im going to start includign a standard tactic section in my stats....
                          • #43
                            WEDGE DEVOLUTION - Aim for the corners of whoevers nearest. Flip them over, then flip them out.
                            KILLOTINE: EVO - Box-rush, grapple and pit the spinners. Aim for Gabriels sides and try to grapple n pit it too. If Im lucky, Ill get the axe stuck into an open flipper.
                            WHIRLIGIG 4.5 - Spin.
                            E CLAWDIUS UNUM - In no particular order: Aim for Flick of the Wrists sides and crunch the wheels. Avoid Nidhoggs crusher and aim for the sides and rear. Get underneath, grapple n pit. Same for Intriguing.
                            • #44
                              Come on Steve, dont you want to join the all-Wedges-attack-May Tracks club?
                              • #45
                                Well, I wouldnt say no.
