Weight: 100kg
Shape: Box
Dimensions: 89 X 88.4 X 99
Powered by: 2 X LEM-130 on 4 X NiCad Battlepacks
Wheels: 4 vulkanized wheels
TC: Guess.
GC: 4mm All Around
Weapons: None, its crappy and its a loser.
Srimech: None
Strengths: None
Weaknesses: Its crappy and a loser.
Then maybe you should have made some more vapours, or chosen realies that cope with vapours better... Or it could be that the draw is just unlucky for you.
And when I said I would make it suffer I was more thinking: Mark presses the pit release and drives in!
But Ill only do something like that if you steal my robots.
Weight: 100kg
Shape: Box
Powered by: 2 X Sinclair C5s on 4 X NiCad Battlepacks
Armour: 1cm Cardboard and 1.8cm plastic over a steel ladder chassis
TC: 0mm, duh.
GC: 4mm All Around
Speed: 9mph
Srimech: None
Strengths: None
