AJWars: Another Era
E Clawdius Unum vs. Aftershock
E Clawdius Unum is a box wedge with skirts at the sides and rear. Two S28-400 Magmotors for drive provide 14mph speeds on a four wheel drive system. The weaponry is a hydraulic crushing arm running at 3000psi. E Clawdius Unum also carries spikes and barbs to ram into the opposition. E Clawdius Unum can self-right using linear actuator powered side arms and is armoured in 4mm Hardox.
Aftershock takes its design from the robot Barberous. S28-150 Magmotors contained within produce 10mph speeds. Between the two wheels is a drum spinning at 3500rpm dishing out 43kJ of energy. On the other end of each wheel are wheel hubs that spin at 6000rpm and give out 31kJ. The drum and hubs are 9mm thick Titanium.
3€¦
2€¦
1€¦
ACTIVATE!
E Clawdius Unum is first away, darting across the arena attempting to reach Aftershock before it has spun up to speed. Kody quickly turns his robot out of the way and Clawdius hurtles into the arena wall! Aftershock, now spinning well, comes in for an attack round the back of Clawdius and strikes with the drum! The impact flicks Clawdius up and nearly out of the arena! Aftershock backs away to get the central drum spinning again. Steve turns Clawdius round and goes back in for a suicide dive. This time Aftershock does not evade it as well, but does manage to clip Clawdius with one of the spinning hubs while turning. Aftershock goes slightly unbalanced, while Clawdius seems largely unaffected. The crusher-equipped robot has another attack, sliding the wedge perfectly between the two wheels and runs the wedge right into the drum! The collision causes a shower of sparks and some barbs are ripped clean away from Clawdius€™ wedge. However the drum is now stalled and Steve steers Clawdius neatly in and grasps the drum between the claw and wedge!
The claw comes down and locks Aftershock in the grip, however it is struggling to penetrate the 9mm Titanium armouring. Kody continues to spin the side hubs and wheels, but Aftershock just cannot get free! Clawdius slowly lines itself up and begins to push Aftershock across the arena. Clawdius first carries Aftershock over to the flame grill, and the flames lick out but cause little harm to Aftershock€¦ Clawdius then drags Aftershock away and rams it into the pit release target. The pit starts to descend€¦ and Aftershock is away! The impact of Clawdius slamming Aftershock into the pit release appears to have shaken the drum-bot free! Kody promptly gets Aftershock well away and begins to spin up the large central drum. Clawdius turns and quickly follows, and a chase begins! Aftershock quickly swerves away from Clawdius, and then comes in for a side on attack! The drum slams into the side of Clawdius and the collision causes it to be thrown onto its side! Aftershock continues its charge and hits the underside of E Clawdius Unum with one of its spinning hubs, causing a small dent.
The side arm pops out of Clawdius and it makes its way back to its wheels. Aftershock quickly comes in for another attack and rides right up the wedge, but this time the drum manages to deflect it away before the claw could come into play. However, the impact caused the drum to slow down and Clawdius again slips in and gets a grip around the drum, but once again Aftershock gets away right at the last moment! Kody then steers Aftershock side-by-side with Clawdius and catches the side plate with one of the hubs, causing a few sparks. The drum starts spinning again as the two robots dodge and try to find an opening€¦ Aftershock gets there first and delivers a nice attack on the side of Clawdius, causing more sparks to spray out and both robots bump away. But Clawdius quickly recovers and turns in to pin Aftershock against the arena wall. The claw comes down and again Aftershock is caught in the grip of E Clawdius Unum.
Clawdius turns and heads towards the pit, but one of Aftershock€™s wheels has purchase on the floor and is digging in, making it difficult. Clawdius slowly jolts forwards and comes within inches of the pit, with Aftershock€™s one wheel slowly moving them away from it. Clawdius turns and edges both robots right onto the edge of the pit! One of Aftershock€™s wheels is now hanging right above the pit, while the other continues to spin, now emitting smoke. Clawdius backs up slightly and turns Aftershock right over the pit, but Aftershock digs in once more to steer it just clear. Grey smoke is now pouring out of the side of Aftershock as Clawdius releases its grip and sets Aftershock free. Aftershock is balancing on the edge of the pit, the hubs are moving, but little else seems to be alive and Clawdius rounds it off with the final shove.
CEASE!
E Clawdius Unum helps Aftershock into the pit, and goes marching on!
So with the conclusion of a controversial Round 1, here is the Round 2 draw:
Gabriel II vs. Infusion
Liar 2 vs. E Clawdius Unum
Tactics, predictions and thoughts welcome as always!
3€¦
2€¦
1€¦
ACTIVATE!
CEASE!
