Robot SMASH!!
Another day, another over-powered ring spinner to face off with :P Although thinking about it I really dont know if Whirly can get its full power into its strikes, pussycat blade shaped teeth dont sound too efficient as theres no single point and no real trauma. Its more likely to slice than to rip and gouge, so its basically an oversized saw blade
Tactics are to go with the wedging under and reversing stratagy to get the spikes into play. The wider area of the shuffle pads compared to wheels means I can get more spikes stuck in, and hopefully can remove an entire shuffle pad doing this, leaving Whirly limping and spinning off centre, which is always bad news for a spinner. Ask Mauler. It might not be the most efficient way of beating Whirly, but itd be one of those moments that makes me regret you cant actually see whats going on in the arena
Good luck Stevey.
Good luck Stevey.
