Robot SMASH!!
Mark, I told you not to reply! Do not post anything else in this thread again, ever.
Semi-Final 1/2:
Wedge Devolution v ISDSFA
Ladies and Gentlemen, welcome back to the arena, WEDGE DEVOLUTION!
To reach this semi-final Steven McGregor€™s simple wedge flipper has defeated:
- Woodpecker
- Wedginator 6.0
- Razer
- Liar 2
And the next bot on the menu, please welcome ISDSFA!!!!!!!!!!
To get this late stage of the contest ISDSFA has slain:
- 259
- Pure Evil: Return of the Disc
- Killobite 5.0
- Whirligig 4.5
Steven and Frank clash again, this time for a place in the finals!!!!!!!!!!
Booth 1: Steven McGregor
Booth 2: Frank Goacher
5, 4, 3, 2, 1, SMASH!!
The semi-finalists both get off to a very quick start, and if you have been reading the posts leading up to this match you€™ll know that both vapourboteers have opted for similar tactics, and this is visible at once as ISDSFA and Wedge Devolution both try to avoid each other€™s front ends and get under the corners! But neither bot succeeds, and they drive past each other, only to turn around and face each other again! Wedge Devolution looks menacing and heads towards ISDSFA, but Frank has some tricks up his sleeve! When Steven gets near ISDSFA Frank quickly turns out, then back in, getting in under the corner of Wedge Devo as planned! And now with a quick flip up and over goes Wedge Devo and in goes Frank with the spinning disc! Frank presses down with the scoop to stop Wedge Devolution self-righting and pushes Steven into the pit release, and now Steve-o looks really worried! But there€™s nothing ISDSFA can really do from this position, as the disc has failed to cut through the hardox armour on Wedge Devolution. Finally then Frank gets the scoop off Wedge Devo and Steven springs back onto his wheels before he goes speeding away from the arena wall and then turns around to face the pursuing ISDSFA! They meet each other, and Wedge Devo manages to get that bent upwards plate underneath ISDSFA and throws Frank€™s creation up and over! And before he can self-right Steven continues this dangerous onslaught and pushes ISDSFA across the arena again, then as they get near the arena wall Steven hits the flipper button!
FLIP!
ISDSFA somersaults through the air and lands with its front scoop on the ground, but the rear end propped up on the wall, and ISDSFA can€™t go anywhere from there! Steven grins maniacally, but the celebration is ended when Frank uses his scoop to shimmy off the wall and gets under Wedge Devo to throw it over again! But this time Steven is faster self-righting and does so before Frank can get the disc into play, but Wedge Devo self-rights onto ISDSFA€™s raised scoop, allowing Frank to lever Wedge Devo back up and over and bring the disc into play again! ISDSFA pushes Steven across the arena floor and into the angle grinder, and Steven doesn€™t look too happy being stuck between a rock and a hard place! But once again the judge€™s order Frank to stop the pinning after a minute, so Frank lets go after about thirty seconds, perhaps to give himself more time to finish Wedge Devo off? If so, he€™s underestimated the wedge flipper, which now self-rights, speeds underneath ISDSFA and throws it into the air again!
CRASH!
And this time Frank has suffered a bit of a crash landing, hitting the floor with the scoop raised in a premature attempt to self-right and ISDSFA bounces painfully over the flame pit and lands on its side by the grinder! And before Frank can get out of there in comes Steven with an evil glint in his eye!
FLIP!
Over the wall goes ISDSFA and we have our first finalist!
WEDGE DEVOLUTION GOES TO THE GRAND FINAL!
Semi-Final 2/2:
Supreme Glory Omega v Nidhogg
Supreme Glory Omega has already beaten:
- Dead Horse Beater
- D.V.D
- All Scoop and No Stab Make Steve a Dull Boy
- Storm II
His opponent Nidhogg has decimated:
- The Curse
- Doorstops
- WORCK
- Seung Mina IV
Who will go on to meet Wedge Devolution in the grand final?
Booth 1: Daniel Stickler
Booth 2: Joey McConnell
And the second semi-final gets underway! It€™s Nidhogg immediately on the attack, but SGO is equally aggressive and both bots head out to meet each other! Daniel switches on his vacuum-like mechanism and swings down with his axe, landing a hefty blow on Nidhogg€™s wedge! Joey panics and ploughs straight into SGO, trying to get the forks underneath, but failing! And so Daniel gives Joey another taste of that lethal axe, but this time Joey raises his forks and traps the axe! He pulls SGO onto the flame pit, but Daniel retracts the axe and reverses out of danger! Joey drives back on the attack, but once again can€™t really get underneath and Daniel gets in his third blow, this time striking the top of the crusher and knocking some of the spines loose! Though distinctly ruffled by that blow, Nidhogg pushes SGO back into the pit release button, and when Daniel withdraws the axe it hooks onto the arena wall and lifts SGO€™s rear end into the air! Before Daniel can repair that mistake Joey swiftly skids around to the rear and lifts SGO with the lifting forks, and then coming down with that dreaded crusher! The armour isn€™t very strong and the crusher sinks in, doing damage? We€™re yet to find out, but with SGO speared on the end of the crusher Nidhogg lifts Daniel into the air and begins the trek towards the pit! But Daniel swings the axe madly and manages to loosen Nidhogg€™s grip, therefore falling onto the ground! Daniel tries to hit Nidhogg with the axe again, but something seems to be wrong- SGO is only going in circles! It seems one of the motors was pierced by Nidhogg€™s last attack and now Daniel€™s hopes are in tatters! The crowd scream with both horror and delight and begin the countdown!
5, 4, 3, 2, 1, IMMOBILE!
SGO is out of the contest and with great sportsmanship Daniel claps Joey and grudgingly stops struggling to let Nidhogg push SGO into the pit of oblivion, therefore signalling the true end of SGO€™s Robot SMASH!! Campaign, and with it SGO takes Daniel€™s hopes of winning the trophy!
PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT, PIT!
The crowd are sad to see good old Supreme Glory Omega go, but they€™re ecstatic to see Nidhogg go through!
CRASH!
SGO collapses into the pit, Nidhogg goes through!
WE HAVE OUR TWO FINALISTS!
Play-Off:
ISDSFA v Supreme Glory Omega
Final:
Wedge Devolution v Nidhogg
Semi-Final 1/2:
- Woodpecker
- Wedginator 6.0
- Razer
- Liar 2
- 259
- Killobite 5.0
- Whirligig 4.5
FLIP!
CRASH!
FLIP!
Semi-Final 2/2:
- Dead Horse Beater
- D.V.D
- Storm II
- The Curse
- Doorstops
- WORCK
- Seung Mina IV
CRASH!
Play-Off:
Final:
