The Easter Bunny Tribute Championships 2008
  • The Easter Bunny Tribute Championships 2008
    Easter again...Its a good excuse to have a smashing twenty-four robot tourney!
    Welcome to the Easter Bunny Tribute Championships here in the RW arena, as seen in RW7.The rules are the usual kind:
    Weight- 100 kg wheels
    110 kg shuffle/tracks
    150 kg walkers
    The tournament structure is also pretty simple.If you have seen the newblood tournament in RW extreme 2 theres no need to read the description, as its the same:
    4 heats, each has 2 x 3 robot melees with 2 robots advancing to round 2, where there 2 x one-on-one battles.The winners go head-to-head in the heat final, and the four winners will come back for the grand final, where there will be two one-on-one matches with a play-off for third place and the final itself.
    I need 6 people each to enter 4 robots.
    You can have 2 vapoura and 2 realies, or 3 of one and 1 of the other, but you cant have ALL vapours or All realies.
    Enter for the chance to win that elusive EASTER BUNNY TRIBUTE trophy!
    not a bad way to kick off a tournament Liam, not bad at all
    you might wanna structure the text a bit more, use fat letters, open spaces and the likes to make stuff a tad more readable, but the way you did it now does work for me
    one question, what shall the arena be like?
    Ill enter...
    Flick of the Wrist
    Sheer Heart Attack 2
    Another Night at the Bar
    http://strickenone.proboards99.com/index.cgi?board=thvapourshttp://strickenone.proboards99.com/i...oard=thvapours
    and Gravity!
      Storm 2
      MeCannibal
      Nitro-Gene 4.0
      WORCK
      Those are my entries. The stats are in your Challenge Belt thread
      (Message edited by paulc on March 23, 200
        May I reserve a spot?
        My Realie will be Behemoth
          Davids dusty crew from Team My Lawyer Made Me Change The Name Of This Team So I Wouldnt Get Sued also known as The Team with No Fixed Name :wink:
          1 - Behemoth
          2 - Calm Down Dear (http://farr.proboards21.com/index.cgi?board=TeamSolarizedStats&action=display& thread=1118787258http://farr.proboards21.com/index.cg...ion=display&th read=111878725
          3 - PCC http://farr.proboards21.com/index.cgi?board=TeamSolarizedStats&action=display& thread=1114814416http://farr.proboards21.com/index.cg...ion=display&th read=1114814416)
          4 - Its The Last Thing On My Mind
          Name - Its the last thing on my mind
          Weight - 100 Kg, aint gone though it with a fine tooth comb because I couldnt be bothered.
          Shape - Invertible Box, with rear wedge, plus side bumps
          Ground Clearance - Rear end it is zero due to wedge, side skirts can be added to reduce the sides down to zero if need-be, and at the front it is a modest 10mm
          Speed - 18 mph, enough to dodge and dive if my primary weapon stalls.
          Movement type - 4 Wheel drives the machine, with 2 S28-400 Magmotors at 24 volts providing the power.
          Armour - 4mm Hardox.
          Weaponry - Rear wedge and front X-axis €œI€ bar spinner, powered by another S28-400 Magmotor, designed to flip and damage at the same time.
          Srimech - Runs up-side down, the front weapon is reversible but the rear wedge is stuck.
            TEAM BRAVEHEART
            1. Wedge Devolution
            2. Whirligig 4.5
            3. E Clawdius Unum
            4. Robochicken (RW7)
            1. Wedge Devolution
            SHAPE- low wedge with sloped rear
            COLOUR- sleek and shiny silver
            WEIGHT- about 100kg
            DIMENSIONS- 90cm X 75cm X 30cm
            SPEED- 16mph
            TURNING CIRCLE- 0
            GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
            ARMOUR- 4mm Hardox
            WHEELS- inside robot, 4-wheel drive
            POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
            WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
            SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
            NOTES- flashing red light on top of robot, flies Scotland flag
            STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
            WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers :P)
            2. Whirligig 4.5 (sort of formerly Whirligig 4.0)
            SHAPE- flat disc
            COLOUR- gold with Mauler-style scary face on top. The face shows the direction of the robot.
            WEIGHT- about 100kg (see bottom)
            DIMENSIONS- 101.6cm diameter X 12.7cm
            SPEED- 15mph
            TURNING CIRCLE- 0
            GROUND CLEARANCE- 8mm
            ARMOUR- 1.905 cm thick Grade 5 titanium
            FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
            POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
            WEAPONS- The main weapon on Whirligig is the spinning outer ring, fitted with 9 x Pussycat-style claws. The spinner is powered by an LEM-130 running at 36v. It can reach speeds of 1000rpm and produce up to 100kJ...more than enough to kill another bot at full speed.
            As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
            SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
            NOTES- flies Scotland flag, thanks to AJ, my first properly calculated machine
            STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
            WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
            WEIGHT CHECK:
            armour = 33.72kg (inc blades)
            chassis, mounts, bracing etc = about 30kg
            drive and weapon motors = 12kg overall
            NiCads = about 15kg
            feet = about 10kg overall
            TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule. Probably.
            http://img137.imageshack.us/img137/1297/whirligig45xt7.pnghttp://img137.imageshack.us/img137/1...ligig45xt7.png
            3. E Clawdius Unum (formerly Clawdius Decimus Murderous)
            SHAPE- skirted wedge with small box section and rounded back
            COLOUR- deep green with red shield emblazoned on the wedge, depicting a gold lion with a crown
            WEIGHT- about 100kg
            DIMENSIONS- 95cm X 70cm X 40cm
            SPEED- 14mph
            TURNING CIRCLE- 0m
            GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
            ARMOUR- 4mm Hardox
            POWER- 2 X S28-400 MagMotors
            WEAPONS- The main weapon, as ever, is the hydraulic diamond-tipped crushing claw. It is powered by a Vivoil pump with an 80mm x 40mm ram, with a 2kg tank for storing the hydraulics. The claw runs at 3000psi and, aided by the diamond tip, should be able to leave plenty of holes in another robot.
            The front wedge also features a Firestorm-style blade and two flat spears to aid in getting under the opposition. The wedge itself is now home to several Mute-style barbs to help ensnare other robots.
            SRIMECH- A forward-hinged pneumatic arm on either side, powered by a pair of linear actuators. The rounded rear also prevents the robot getting beached.
            NOTES- flies the Scotland flag, thanks to AJ, et tu, Brute? written on the underbelly
            STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fairly quick srimech
            http://img137.imageshack.us/img137/1801/eclawdiusunumor1.pnghttp://img137.imageshack.us/img137/1...iusunumor1.png
              NAME: Cat With Wheels
              SHAPE: Wedge with sloped sides.
              COLOUR: Like a Tabby Cats coat
              WEIGHT: Around 100Kg
              DIMENSIONS: L:100cm W:70cm H:50
              cm
              SPEED: 18mph.
              TURNING CIRCLE: Omm
              ARMOUR: 7mm Titanium
              GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
              MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts
              WEAPONS: Front hinged high pressure C02 flipper, powered by two rams, running at 500psi.
              SCRIMECH: flipper.
              SHAPE: Box with wedge at front and inverted wedge at back.
              COLOUR: Deep Red.
              WEIGHT: Around 100kg
              DIMENSIONS: L:110cm W:65cm H:23cm
              SPEED: 30mph
              TURNING CIRCLE:0mm
              ARMOUR: 5mm hardox
              GROUND CLEARANCE: 0mm at the front, 0mm with hinged skirts at sides, 20mm at sides under the skirts and at back. (Well, technically 23cm at the very back, thanks to the inverted wedge.
              MOVEMENT: 4 Wheels with Vulkanon tires and aluminium hubs powered by 4 36v LEM130s Powered by 6 NiCad battlepacks.
              WEAPONS: None but the force.
              SCRIMECH: Invertable.
              Shape: Cylinder
              Colour: Black with red teeth
              Weight: 100kgs
              Dimensions: L:90cm W:90cm, H:30cm
              Speed: 15mph
              Turning Circle: 0cm
              Armour: 8mm Titanium all around.
              Ground Clearance: 7mm
              Movement: 4 invertable wheels with Vulkanon treads, powered by a couple of LEM130s at 36V with 3NiCad battlepacks
              Weapons: Ring spinner powered by an etek running at 48volts, which can deal out around 80kjs of power. Two five kilo hardox teeth, curved to rip armour. The whole ring is about 20kg.
              Scrimech: Invertible.
              Chaos 2
                It does say in my first post that well be using the Robot Wars 7 arena.I think its a good arena and any arenas I make will be rubbish anyway!
                There is only 1 space left people!
                  Super Gore Evo
                  Seung Mina III
                  The Zenith
                  and...
                  Iron Awe 5 (Leichester 2008 or most recent version)
                  Stats can be found at http://strickenone.proboards99.com/index.cgi?board=heavieshttp://strickenone.proboards99.com/i...?board=heavies
                    Heres the line-up:
                    Heat A:
                    Flick of the Wrist v Sithis v Robochicken
                    Worck v The Zenith v Calm Down Dear
                    Heat B:
                    Iron Awe 5 v Nitro-Gene 4.0 v Crimson Thunder
                    Sheer Heart Attack 2 v PCC v E Clawdius Unum
                    Heat C:
                    Cat with Wheels v Seung Mina III v Behemoth
                    Whirligig 4.5 v Gravity v Storm II
                    Heat D:
                    Chaos 2 v Wedge Devolution v Another Night at the Bar
                    Super Gore Evo v MeCannibal 2.0 v Its the Last Thing on my Mind
                      The Zenith looks evil, but those wedges on Worck would make it hard to turn quickly due to the added friction and with 4 wheel drive it looks rather balanced. Im not sure at what my 6 wheel drive will be like with double wheels at the back, but The Zenith looks evil with those wedges...
                      ...therefore my tactics are to attack the house robots :-)
                      Heat B:
                      Ah PCC, the robot designed when I was going though the stage of being high on drugs, so I am going to fit the so-called Pie-Tosser Flipper, get underneath either robot and try and flip them out of the arena
                      Heat C:
                      Go after Cats with Wheels, Kody want to team up?
                      Heat D:
                      Drive into Super Gore Evo with the I bar at full speed and try and cause some damage, dodge out of the way of MeCannibal, although those spin-ups speeds seem too fast.
                        Danny, shall we show this chicken whos boss?:wink:
                          WORCKs tactics are to ram under Calm Down Dear and drive into The Zenith as fast as I can. The thing about my wedges is that they reduce the amount of shock going through to the rest of the robot, so if The Zenith does hit me, I wont self-destruct so easily.
                          In the other battle, Robochicken shall go out.
                            Dont you want to help me take out the house robots?
                              Flick of the Wrist V SITHIS V Robochicken.
                              Sounds good to me, Martijn. Id suggest the nice, simple tactic of shoving Robochicken onto me so I can rip it apart.
