Gasp of horror, yes I am doing another tournament, but an Extreme style one this time. This will be easier for me, and random gaps will be better than in a regular style tournament. This also means it isn€™t a fixed length and will go on for as long as I want it to, although knowing me it will take me till the end of 2008 to do just one event lol.
At the moment the events I am considering including are:
All Stars (selected by me based on performances in my tournaments)
Tag Team
Football
Assault Course
Mayhems and annihilators
80kg (series 1 and 2 style)
80kg (current style)
Challenge Belt
Real Robots Vs Vapour Bots
Battle Of The Weapons
Vengeance
World Championship
Clusterbot Carnage
Each event will have sign ups just before it, so don€™t give me stats or reserve places until I ask as it will be ignored.
Ok some rules, if the rules are different for a tournament, for example in both 80kg tournaments, I will say before hand.
Weight limits:
Wheeled Robots 100kg
Tracked Robots 115kg
Shuffle Robots 150kg
Walking Robots 200kg
Others will be considered if asked about
The Arena is the robot wars series 6 arena
Stats Layout:
You can explain your stats however you want really, as long as everything is covered, if it is not in the stats it won€™t be their in the fight. However some things which would be good to include are the following:
Weight
Shape
Ground Clearance
Dimensions
Speed
Movement type
Armour
Weaponry
Motor
Srimech
Anything more than that is of course welcome. If I see a problem in your stats I will inform you, if you choose to do nothing about it then that robot will be expelled from the tournament.
Please don€™t enter crap.
Clusterbots are allowed, however the maximum is 5 parts, and no part can make up less than 15% of the total weight. I will be using the 100% cluster rule, as I feel that is better. As this is the cast for non cluster robots, they have to be 100% immobilised to be counted out, so if the drive goes on one side you can carry on.
Passive weaponry is allowed.
Robots are allowed to have interchangeable weapons, but with no more than 6 different set ups, the same disc but on a different axis counts as one set up on each axis.
Other than that basic FRA rules apply, so basically that means no nitrogen powered weapons sorry.
Any questions on eligibility or anything else just ask me.
Tag Team
Football
Assault Course
Challenge Belt
Vengeance
World Championship
Clusterbot Carnage
Weight limits:
Stats Layout:
Weight
Shape
Ground Clearance
Dimensions
Speed
Movement type
Armour
Weaponry
Motor
Srimech
