Why the hell am I in?! And when I entered the Challenge Belt, I was competing under Liam, not you. If this was a Liam competition and I was given warning, Id be fine, but Im not fine! Im sorry Ive just gone haywire, but I havent got the faintest idea of WHY Im in because I did well in another competition someone else wrote.
And theres no such thing as Nitro-Gene 4.5, its 4.0!
But since you want me to enter, Ill enter. Ill team-up with Joey and together we can dispose of the Ripper and Sir Spinalot. You can go for Sir Spinalot and Ill go for the Son. Ill try to toss him out the arena as quickly as I can.
The bar shouldnt hurt me all that much, and I should be able to get beyond it, grip, and pit fairly easily. Afterwards, if SoRs still going, try and get the forks in on it to stop it fleeing.
3..2..1..Activate!
SoR heads towards Nitro-Gene, who is patiently waiting, while Nidhogg attempts to attack Sir Spinalot. Nitro-Gene gets underneath SoR, who gets off in the nick of time. Meanwhile, Nidhogg appears to be LEAKING HYDRAULIC FLUID! Apparently, Sir Spinalot cut a hydraulic hose, and the fluid is spraying everywhere. However, thats not stopping Nidhogg from going after SoR, whose blade has stopped running, but Sir Spinalot HAS CRUMBLED THE BACK OF NIDHOGG! Nidhogg has stopped moving, but the claw still is slightly crushing into SoR, who is being counted out.
1..2..3..4..5..6..7..8..9..10!
SoR is out, and is that movement from Nidhogg? Yes it is. So Nidhogg is still mobile, while the carcass of SoR is put into the pit. Nitro-Gene is now going after Sir Spinalot, who has almost decapacitated the armour of Nidhogg.
This will go to a judges decision.
10..
9..
8..
Nidhogg almost uncontrollably rams into Nitro-Gene, who is still chasing Sir Spinalot around the arena.
7..
6..
5..
4..
Is that smoke coming out of Nitro-Gene 4.0?
3..
2..
1..
Cease!
The judges can give 1 point to each bot.
A max of 3 points can be given for each:
Style
Control
Damage
Aggression
