An "Experiment" Tournament
  • An "Experiment" Tournament
    Looking for 4 people to enter 1 bot each into a bit of an experimental idea I have
    Rules:
    100kg wheeled robots only.
    No clusters.
    No Spinners.
    RFL standard combat rules.
    Arena: Octagon shaped arena, 10m between opposing walls. Walls are 500mm tall. 1000mm push-out zone in the arena wall at the top of the arena. A hammer on the left wall. A clamping jaw that will hold an opponent for 10 seconds on the right wall. Pit in the very middle of the arena, triggered by a punch panel on the bottom wall. Keeps pit open for 10 seconds.
    These battles will be very different to normal battles. Will require me to email/msn entrants regularly. Ill be posting the battles on Vapourbot Resource, but will link each battle here.
    An Experiment Tournament
    Time to test out http://strickenone.proboards99.com/i...play&thread=16
      Flick of the Wrist, stats on Kody and my board
        Ill enter =)
        Weight: 100kg
        Armour: 4mm Hardox.
        Speed: 18mph - powered by 2 Sinclair C5 motors running at 24v.
        Shape: Box wedge with sloped sides, a rounded back and scooped front.
        Weapon 1: A cam-driven axe mechanism, powered by a 60v Briggs and Stratton 11kW motor. (Interchangeable).
        Weapon 2: A flipping arm, powered by a 60v Briggs and Stratton 11kW motor. (Interchangeable).
        Strengths: Fastest axe mechanism currently around (hypothetically of course, this is only a vapour after all€¦ )
        Weaknesses: The weapon itself is not very destructive, but mainly shows dominance in terms of number of this it can do.
        Ground Clearance: 0mm at the front due to a sharpened Titanium front and side skirts, 4mm at rear.
        Srimech: Invertible, but the axe mechanism has enough power in it to right it back onto its wheels.
        Notes: The axe-head is based on Dominator 2€™s, and has small Titanium spikes on each end to aid in self righting. The axe-head is make of Titanium, with a 5mm Hardox tip. The flipper arm is made entirely out of 10mm Aluminium. The robot has 4 wheels get up in a skid steer system and runs off 2 Sinclair C5 motors @ 24v. Each side is connected to each other by a heavy duty rubber belt, and the wheels are made entirely out of Vulcalore. The weapon systems run off a 60v Briggs and Stratton 11kW motor geared down 15:1. The motor is connected to a cam wheel which in turn moves the weapon up and down on its pivot. When running at 60v, the weapon can move just under 5 times a second. The emphasis is not on power, but in dominance and aggression.
        (Message edited by Team_Britespark on March 13, 200
          That was quicker then expected
            Can I reserve a spot, Id like to try something but its not quite ready yet?
              Id like to enter:
              Holepunch
              Weight: 100kg
              Length: 100cm
              Width : 70cm
              Height: 40cm at the top of the beak, 28cm at the top of the armour.
              Armour: 40mm Hdpe and 8mm 7075 aluminium baseplate.
              Speed: 13mph - powered by 2 wheelchair motors running overvolted at 36v. with 150mm wheels
              Shape: Razer-esqe looks, wedge at the front, a bit more boxy with rounded edges at the back.
              Weapon: A Pneumatic crusher (yes i said Pneumatic) with a 250mm bore 120mm stroke full pressure 7075 aluminium 15mm wallthickness ram, giving a massive 25+ tonnes of force on the ram. this is levered down 2:1 giving 12.5 tonnes of force at the tip.
              The Ram is fed by 4 burkert valves from 4 corners of the ram providing maximum flow to the ram. The beak is retracted by 2 gas springs at the front under the beak still protected from the sides.
              Strengths: Very fast working beak, with tremendous force.The gear ratios on wheelchair motors provide a lot of pushing power all be it not very fast.
              Weaknesses: This thing guzzles gas like a Hummer sucks petrol. I only have 5 to 7 good bites before the gasbottle starts to drain depending on the weather. To save weight I had to go for a slow drive. Selfrigting is also not garantueed.
              Ground Clearance: 0mm at the front due to a sloaped front that scrapes the floor. 10 mm at the rear.
              Srimech: when lucky it rolls over when the beak is in top position due to the low centre of gravity.
              Notes: Still in development, so it is probably going to have some teething problems.
              pictures:
              All dressed up: http://www.computerclub.nl/uploads/fanfic/holepuncharmoured.jpghttp://www.computerclub.nl/uploads/f...charmoured.jpg
              Barenaked: http://www.computerclub.nl/uploads/fanfic/holepunchwihoutarmour.jpghttp://www.computerclub.nl/uploads/f...houtarmour.jpg
              Im pretty pleased with this design, hope it does well.
                Entries closed.
                Entrants, please email me: msn {at} crystalnode {dot} net
                Will get this ball rolling and explain the experiment more in full :wink:
                  All entries now located http://vapourbots.crystalnode.net/fo...?f=6&t=103here
