Use the Arena to your Advantage 1 - Bloody Low Walls
So Ripper is weak to ostriches? :P
. Just as Achilles is self righting it is nudged by the marching in Wedge. Achilles spins around like a mad top but with help of the T-bar he does manage to self right. The Greek warrior faces Wedge now who€™s only gotten a bit closer to the wall after that last nudge. Achilles heads for Wedge straight away, and like earlier, Wedge can€™t answer this attack. Achilles gets under€¦ the wall gets closer€¦ flip!
. Starstorm is getting the hang of it, moving closer to the wall with each flip. Frank struggling to throw Cosmic Thunder a long distance shows Starstorm isn€™t the most notorious OOTA€™er in this flipper-dominated tournament, then again, its the only flipper that can claim to be full bodied, which is something
. Alex has had enough of it and moves away thanx to his invertible setup. Starstorm stays offensive, but Cosmic Thunder created quite some distance between itself and zeh Storm now and selfrights, turns around, and turns on the offensive itself now. The simple wedgebot drives at the less simple domebot, which in response lowers its skirts to an impressive 0 mm ground clearance€¦
. Starstorm is on its back and has to self-right now in order to survive, which it, of course, does.
