The Roaring Donkey mini-tournament
    Ferpect
      quote:
      except there are no house robots
      Boo
      No fun without house robots
        Id like to reserve a place for The 6isc please
          Oh dear...this could be bad...
          THE LIST:
          1: Tri-Tainium (Paul Cuomo)
          2: Macduff the 2nd (Kody Kunz)
          3: (Matty space)
          4: Back To Rock III (Martijn Benschop)
          5: Darkestar (Alex Holt)
          6: Envy (Shane Swan)
          7: The 6isc (I assume thats the official spelling?) (Frank Goacher)
          8:
          One more free place guys, thanks for the entries.
            You assume correctly
              I only reserved to make sure no-one nicked the spot while I was finishing this off. Ladies and... Actually, there are no ladies here. This section needs estrogen, damnit! Gentleman, I present:
              The 6isc
              Shape: Too complicated, apparently. See picture in the vapourbot images thread.
              Size: 60X110X60 CM (LWH)
              Weight: ~100 KGs
              Speed: 10 MPH.
              Ground clearance: Under the wheel protectors, it€™s 5 mm.
              Weapon: 26 KG spinning disc, powered by one LEM 130 Lynch motor and going at 2500 RPM. The disc is shaped with its own teeth rather than needing teeth surgically attached to it, so dentistry is quite impossible. The energy output is 36 KJ€™s which, while modest by vapour €˜bot standards should still be enough to make a mess of things.
              Wheels: 6 wheels, but four wheel drive. This has three wheels on either side arranged in a triangular fashion, so it only runs on four at a time. The wheels are 1 CM solid Ti with soft compound rubber wrapped around them to provide shock resistance, and a layer of Vulcalon wrapped around that to provide traction.
              Chassis: The main chassis consists of one solitary 1 CM thick 4 mm box section hardox bar. Slotted over that is a secondary axle, inside which are the batteries. There are also two other triangular chassis€™ supporting the wheels. These are made from 4 MM 1 CM box section Ti bars with weight reducing holes.
              Armour: The true axle and chassis is a 4 MM hardox bar. The battery axle is 2 mm aluminium. The semi circular wheel protectors and side spikes are 5 mm Hardox. The disc itself is 14 MM of Hardox 500, and the outer axle is 4 mm grade 5 Ti.
              Srimech: Totally invertible. Controls won€™t even have to be reversed after flipping, meaning it can just go straight back on the attack.
              Drive: 2 S28-400 Magmotors at 24 volts.
              Strengths: The newest version of The 6isc does away with as many weaknesses in The Disc 5 as I could find.
              Weaknesses: Weak armour in places. Can€™t use axe attacks.
              Based on Joeys trial fight Im looking forward to this
                save a space for me please, i will be able to give you stats by monday
                • #23
                  Thanks Martyn - all spots are now filled.
                  THE ROARING DONKEY TOURNAMENT LIST OF SACRIFICIAL VICTIMS:
                  3: (Matty space)
                  7: The 6isc (Frank Goacher)
                  8: (Martyn space)
                  Draw to be posted when I have all the stats or next week, whichever is sooner.
                  • #24
                    Looks like quite a good list.
                    • #25
                      doesnt estrogen have an o at the beginning or am I being blonde again?
                      • #26
                        I think it does, but I spent two years convinced it had a J in it so dont count on me being accurate.
                        • #27
                          http://dictionary.reference.com/search?r=2&q=oestrogenhttp://dictionary.reference.com/search?r=2&q=oestrogen
                          Both spellings are right.
                          • #28
                            Monday 28th July?
                            • #29
                              Ill take Martyns place with http://vapourbots.crystalnode.net/fo...&t=19Resonance
                              • #30
                                erm rude, i mean tomorow.
