Vapourbot Images...
  • Vapourbot Images...
    ...is there a joke Im missing there, or am I just being weird?
      Envy seems lower than 30cm...
        No 30cm is about right I think.
          ok kody you are making the effort so i shall to so i went and measured it to the mm ok here we are......
          27cm high at the highest point including pretruding wheels. 24cm without wheels.
          the top flat bit is 27cm long and 80cm across
          from the flat wide bit which is 80cm it goes to the front scoop which is 34cm wide
          from the flat top bit toward the rear it goes down from 80cm to 54.5cm.
          the flat rear end is 54.5 by 16 high i think you should be able to get the angles from that.
          the flipper is 55cm long by 34 wide. then the front scoop is 11.5 from the edge of the flipper to the front tip of the robot.
          i hope you understand this but if you dont please ask and i will go measure cos the robot is just in the other room.
          thanks kodster
            Ta, Shane.
              Sorry about the delays, too much going on right now, almost had it ready, Shane. It will be ready soon, I hope. :sad:
                take your time kody no worries
                  ENVY
                  http://www.geocities.com/origkody/Envy.png
                    Fantastic pictures, Kody
                      Thank ee, Mr. McConnell.
                        I somehow dont think Shane will be disappointed with that Kody - it looks great! And pretty much perfect!
                          TOP BANANA Kody. that is lifelike. i am sooooooo impressed dude. even down to the inside of the flipper. you have done a great job. WOW. can you tell i am impressed.
                            it actually looks bang on kody. it does actually look perfect.
                              Wow, thanks a lot Shane. To be honest I didnt think I would get it at first. I sure showed myself.
                              And thanks Jamie as well.
                                Hey Kody, I dont mean to be a pain cos I know your busy but if you ever get really bored and have nothing to do you can always do an image of one of my vapours
