NAME- Death Threat 0.2
SHAPE- Long box with rounded back,
COLOUR- dull grey all over
WEIGHT- about 100kg
DIMENSIONS- L:95cm W:70 cm H:30cm
SPEED- 13mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- 0mm with hinged skirts, 10mm underneath
ARMOUR- 5mm hardox
MOVEMENT- Tracks with 2XBosch Motors with 3 Ni-cad battery packs at 24 Volts
WEAPONS- Horizontal crushing claws at front made out of titanium with 6.25 tons of crushing power
SRIMECH- Invertible. Side spikes to stop it resting on its side
NAME: Axes of Evil
SHAPE: Hexagon, sloping in to a point in the middle.
COLOUR: dark green.
WEIGHT: around 100kg
DIMENSIONS: 60x60x50
SPEED: 15mph
TURNING CIRCLE: 0mm
ARMOUR: 20mm polycarbonate
GROUND CLEARANCE: 0mm all over with skirts, 15mm with.
MOVEMENT: 2WD inside robot. powered by two Bosch motors running at 24 volts.
WEAPONS: Rack and Pinion axe mechanism powered by two CO2 tanks at 160psi. It has two terrorhurtz style heads, one on either side of the shaft, because Axe of Evil doesnt work with the pun, and the name has to be accurate.
SCRIMECH: the axe has spikes sticking out to aid self righting from any angle.
NAME: Cat With Wheels
SHAPE: Wedge with sloped sides.
COLOUR: Like a Tabby Cats coat
WEIGHT: Around 100Kg
DIMENSIONS: L:100cm W:70cm H:50
cm
SPEED: 18mph.
TURNING CIRCLE: Omm
ARMOUR: 7mm Titanium
GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts
WEAPONS: Front hinged high pressure C02 flipper, powered by two rams, running at 500psi.
SCRIMECH: flipper.
SHAPE: Box with wedge at front and inverted wedge at back.
COLOUR: Deep Red.
WEIGHT: Around 100kg
DIMENSIONS: L:110cm W:65cm H:23cm
SPEED: 30mph
TURNING CIRCLE:0mm
ARMOUR: 5mm hardox
GROUND CLEARANCE: 0mm at the front, 0mm with hinged skirts at sides, 20mm at sides under the skirts and at back. (Well, technically 23cm at the very back, thanks to the inverted wedge.
MOVEMENT: 4 Wheels with Vulkanon tires and aluminium hubs powered by 4 36v LEM130s Powered by 6 NiCad battlepacks.
WEAPONS: None but the force.
SCRIMECH: Invertable.
Shape: Cylinder
Colour: Pure Black
Weight: 100kgs
Dimensions: L:90cm W:90cm, H:30cm
Speed: 15mph
Turning Circle: 0cm
Armour: 8mm Titanium all around, on a 5mm titanium chassis.
Ground Clearance: 7mm
Movement: 4 invertable wheels with Vulkanon treads, powered by a couple of LEM130s at 36V with 3NiCad battlepacks
Weapons: Ring spinner powered by an etek running at 48volts with three NiCad battlepacks., which can deal out around 80kjs of power and spins at 2000rpm. Two five kilo hardox teeth, curved to rip armour. The whole ring is about 20kg.
Scrimech: Invertible.
my realies will be Wheelie Big Cheese, Chaos 2 and Dominator 2
Thanks! 2 sign-ups in 1 day! That means I have 3 spots left in the competition, and this is the current entries list.
1- Martijn Benschop (Team Varying Every Day)
a. Storm 2
b. Big Nipper
c. Axe To Fall 2
d. Flick Of The Wrist 2
e. Sheer Heart Attack 2
f. Another Night At The Bar
g. Back To Rock 3
h. With Or Without You 2- Kody Kunz (Team Zlayerz)
a. Wedginator 6.0
b. Super Gore Evo
c. Seung Mina III
d. Aftershock
e. Intrigue
f. Killobite 5.0
g. Turbulence
h. Shrederator 3- Alex Holt (Team DoomForAll)
a. Kali
b. Black Panther Queen
c. Ramthrax 2
d. Achilles
e. Tengu VII
f. Cable
g. Robot The Bruce
h. Bodyhammer 4- Dave Sheppard (Team Jimmy McGee)
a. BioHazard
b. M2
c. Atomic
d. Suicidal Tendincies
e. Quocunque Jeceris Stabit
f. Chalkie 3G
g. Son Of Wedgie
h. Flipping Mad B2B 5- Christopher Mason (Team Dinowarrior)
a. Orka MK.4
b. Die-Ceratops ReInvertus
c. Leprosy Infection
d. Crash Bandi-Bot 3
e. Spring-BOK!
f. Squirmin Vermin
g. Humdrum
h. Axe-O-Lotl 6- AJ (Team ???)
a. Tornado
b. FireStorm 5
c. SOR X
d. Wedga€™s Revenge
e. Exertion
f. Psycloniser
g. The Final Cut
h. GeForce 4.0 7- Joey McConnell (Team Chevron)
a. Gabriel V1.2
b. Fire And Ice
c. Nidhogg
d. 147
e. 13 Black
f. Dreadnaut XP1
g. Panic Attack
h. Darke Destroyer 8- Samuel Park (Team ???)
a. Terrorhurtz
b. S3
c. Typhoon 2
d. Wild Thing
e. Paralyzation
f. Turbo Shredder
g. Black Death
h. Walk Don€™t Run 9- Danny Bailey (Team ???)
a. Death Threat 0.2
b. Axes Of Evil
c. Cat With Wheels
d. Crimson Thunder
e. Sithis
f. Wheely Big Cheese
g. Chaos 2
h. Dominator 2 10- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ??? 11- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ??? 12- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
Hm... well, then Ill just replace it with another vapour....
Death Wish
Body Shape: Just a simple Box with rear wedge
Weight: 100kg
Dimensions: 90 X 85 X 30
Drive: Steel Tracks with Vulkalon rubber
Batteries: 4 X 36V NiCad BattlePacks
TC: Zero
Top Speed: 19 mph
GC: 0.0014mm at the back and 4mm anywhere else
Skirts: A Titanium skirt on the rear
Weapon: At the front, there is a big and devastating 21kg Horizontal Spinning Flywheel powered by a Honda CR125 Motorbike Motor. Its top speed is 8000RPM. It is deadly within 2 seconds. At the back, there is a hydraulic claw with a force of 8 tons on the tip.
Srimech: None, but Invertible and rounded sides and back help it not to get stuck
Strengths: Devastating Name and Weapons, Extremely Sturdy Tracks
Weaknesses: As usual, the tracks might be exposed to axes or crushers (Although Very Strong and Sturdy)
Weight: 100kg
TC: Zero
Top Speed: 19 mph
I fail to see how you can fit a 21kg flywheel, a motorcycle motor, a claw, hydraulics, and 8mm titanium into a 150kg superheavyweight bot, let alone a 100kg heavyweight :P
