The FSTT tournament.
Okat, PTT style stats:
Shiny Happy People
Shape: Box with Wedge
Colour: Mirror
Speed: 5mph
Weight: 99kg
Armour: 10mm corrugated fiberboard attached to a wooden chassis, but with some shiny old Robbie Williams CDs attached to the outside, so it looks like a mirror
Drive: 4 wheel drive with 4 Ford windscreen wiper Motors @ 12 volts
Power: Some 12 volt battery packs.
Wheels: 4 wheels
Ground Clearance: 2cm, but zero at the front
Dimensions in CM: 50 x 50 x 20
Weapons: Shiny Wedge
Srimech: None
Strengths: Its shiny!
Weaknesses: Its Shiny!
Name - Hundreds of Thousands
Colour - Unpainted
Shape - Each is a little wedge
Weight - 99.9kg in total
Speed - 20 mph
Armour - Nothing
Motors - Antweight Motors with 2 wheels at the rear, powered by antweight batteries.
Weapons - Nothing
Ground Clearance - 3mm
Notes - 665 automatic 150g antweights with a wedge
Strength - You try working out when 333 are knocked out
Weaknesses - Easy to destroy
Name - The Flying Machine
Shape: Cone with outriggers
Colour: Grey, with invisibility paint, makes it hard to see
Speed: Depends which way its flying, but up-to 20 mph
Weight: 90kg
Drive: Flys
Power: Some weird method in which it can fly and dance in the air to come into attack
Wheels: It has wheels?
Ground Clearance: 0mm to 20000mm
Dimensions in CM: 50cm^3
Weapons: Bottom mounted spinning disc, and some more spinning discs thrown in for good measures
Srimech: It will right itself by flying
Strengths: Can attack from a number of angles
Weaknesses: Cant attack from the ground up though
Realies:
Shunt (with a bit less armour)
Roadblock
Bodyhammer
Shiny Happy People
Colour: Mirror
Speed: 5mph
Weight: 99kg
Wheels: 4 wheels
Srimech: None
Colour - Unpainted
Speed - 20 mph
Armour - Nothing
Weapons - Nothing
Weight: 90kg
Drive: Flys
Realies:
Roadblock
Bodyhammer
