How Could I Improve...
  • How Could I Improve...
    Front means front of the robot.
      what shape does All Torque have?
        A long box, with a wedge on either side. Non-invertible.
          Ground Clearance: 0mm at front and back. 5mm at sides.
            You said you use the TWM 3R, but those are just the gearboxes, what Magmotors do you have attached to them?
              LEM-130.
                ...those...arent..Magmotors...grr...
                  S28-400 Magmotors.
                    In that case, I would not pick the TWM3R, because youe tracked robot would go a whopping 78,5km/hour, or 50mph!
                    Use the TWM3 instead, that gives you a 7.14:1 ratio. and 2 motors is plenty, no need to shove in 4, that is just way overkill and weight (26kg instead of 12.8kg).
                      I am keeping the TWM3R, but I am removing 2 of them.
                        Although, if I didnt, I would have the fastest ever track robot.
                        (Message edited by corsair_lightning on March 31, 200
                          Yes, but it would be next to impossible to turn it at any speed.
                            If there is a sprint competition, I will use the 4 TWM3Rs.
                              you would only be driving in a straight line or turn on the spot, and eat amps in any attempt to turn. Aiming to line up is right out the door, your robot would be worse to drive than InTriVerter.
                                Fu-Ma Ninjabot
                                Shape: Hazard with skirts on the sides and back.
                                Weight: 100kg (Wheeled)
                                Colour: Red
                                Dimensions: 100cm x 78cm x 17cm
                                Speed: 25mph
                                Turning Circle: 0mm
                                Ground Clearance: 0mm all around, but 5mm at sides and back if there are no skirts.
                                Movement: 2 Vulkalon wheels at the back.
                                Armour: 6mm titanium
                                Power: 2 TWM3R Team Whyachi gearboxes connected to 2 S28-400 Magmotors, powered by 7 NiCad packs.
                                Weapon: A 3m titanium sharpened blade powered by a Tornado Mer weapon gearbox. It spins at 5000rpm.
                                Srimech: none, since the weapon is long and low so no robot can get under without suffering major damage.
                                Notes: Updated bot from Team ZlayerZ RPG: Identity Theft.
