Mechanical Noise - Series 2
    Okay, Team Targeted
    Flank Attack: DT
    Return of Feedback
    Snijder
    Eurypterus Evolved
    Cosmic Thunder 2
    Cacodemon
    Malaria
    Meat Slicer 2
    http://farr.proboards21.com/index.cgi?board=targetedhttp://farr.proboards21.com/index.cgi?board=targeted
    Still need to get Snijder and Return of Feedback stats up though.
      How about I enter!
      Here is, FROM TEAM ITALIEN STALLION:
      MeCANNIBAL
      € WEIGHT: 110KG (SHUFFLER)
      € ARMOUR: 5MM HARDOX
      € SHAPE: INVERTIBLE LOW CYLINDER
      € MOTORS: 2 x ETEKS AT 46V = 30HP
      € LOCOMOTION: 2 SHUFFLING PADS
      € DIMENSIONS: (L) 80CM (W) 80CM (H) 15CM
      € COLOUR: BLACK WITH SCARY HUMAN FACE WITH OVER SIZED TEETH COLOURED RED.
      € WEAPONRY: RING SPINNER, MADE OF 20MM HARDOX, WEIGHTING 42KG, SPINNING AT 3500RPM, PRODUCING 215KJ PER BLOW. IT HAS 6 BLUNTENED TEETH MADE OF HARDOX. THE TEETH ARE SET IN A TRIANGULAR SET UP. HAS 3 INCHES WORTH OF TITANIUM SHOCK-PROOF FOAM TO STOP IT SELF-DESTRUCTING.
      € SPEED: 22MPH
      € GROUND CLEARANCE: 0MM (HAS A FULL-BODIED SKIRT RUNNING ALMOST COMPLETELY ALONG THE GROUND)
      € STRENGTH: SCARY NAME AND WEAPON
      € WEAKNESS: HARD TO CONTROL
      HYENA
      € WEIGHT: 100KG
      € ARMOUR: 5MM HARDOX/ 20MM BOMB-PROOF POLYCARBINATE/ 12MM TITANIUM
      € SHAPE: INVERTIBLE RECTANGLE WITH FRONT LOW EXTENSION, SPIKED SIDES AND REAR FLYWHEEL
      € MOTORS: 2 x 3KW AT 36V = 10HP
      € LOCOMOTION: 10 x 13CM VULKALON RUBBER WHEELS
      € DIMENSIONS: (W) 50CM (L) 80CM (H) 14CM
      € COLOUR: GOLD WITH BLACK SPOTS
      € WEAPONRY: AT THE FRONT IS A 5CM WIDE AND 8CM LONG EXTENSION, THIS IS THE FIRST PART OF A JAW SYSTEM. THE SECOND PART WORKS LIKE AN AXE AND IS ANOTHER 5CM WIDE 8CM LONG TITANIUM PLATE. THE JAW IS MADE OF HARDOX WITH 5 6CM TEETH MADE OF ENLIGHTENED HARDOX, AND IS POWERED BY 3 HYDRAULIC RAMS AT 3000PSI (EACH) AND USES VERY FAST RAMMING ABILITES TO COME DOWN AT 300MPH, ENOUGH TO GRIP ANOTHER ROBOT AND CRUMBLE IT€™S ARMOUR. AT THE REAR IS THE SKIRT-KILLING FLYWHEEL - WEIGHING 15KG AND USING 1 x LEM 200 AT 48V TO SPIN AT 2500RPM. 5MM THICK AND MOUNTED 1MM OFF THE GROUND. SIDE SPIKES PROVENT IT GETTING BEACHED.
      € SPEED: 20MPH.
      € GROUND CLEARANCE: 0MM.
      € STRENGTH: BRILLIANT WEAPON COMBINATION
      € WEAKNESS: DIFFICULT CONCEPT TO UNDERSTAND
      KAY 9
      € WEIGHT: 95KG.
      € ARMOUR: 12MM HARDOX
      € SHAPE: REVERSED INVERTED STORM 2
      € MOTORS: 2 x LEM200 AT 46V = 36HP
      € LOCOMOTION: 4 x ALUMINIUM WHEELS WITH HARDOX SPIKES FOR GRIP
      € DIMENSIONS: (W) 60CM (L) 60CM (H) 30CM
      € COLOUR: BLUE WITH SHARP TEETH FRONT SCOOP
      € WEAPONRY: 2 x 20 KG HARDOX FLYWHEELS WITH TWO BLUNTNED HARDOX TEETH AT FRONT. EACH SPINS AT 1200RPM. WHEN FLIPPED, THE WEDGE CAN MAKE IT A PUSHER, AND HAS AN EXTENSION TO GET UNDER THINGS
      € SPEED: 20MPH.
      € GROUND CLEARANCE: 10 MM.
      € STRENGTH: POWER OF DRIVE AND WEAPON.
      € WEAKNESS: HIGH GROUND CLEARANCE AT SIDE AND REAR
      CRUSHER C.U (CUTTING.UP)
      € WEIGHT: 100KG
      € ARMOUR: 12MM TITANIUM/ 5MM TUNGSTEN STEEL
      € SHAPE: INVERTIBLE BOX WITH FRONT FIXED SCOOP
      € MOTORS: 2 x LEM 200 AT 36V = 47HP
      € LOCOMOTION: 8 x SCOOTER WHEELS
      € DIMENSIONS: (W) 40CM (L) 60CM (H) 20CM
      € COLOUR: BLACK WITH SILVER LINING
      € WEAPONRY: SCOOP WITH VACUUMS TO TRAP OPPENENTS. A DOUBLE-SIDED CRUSHER COMES IN, WITH 6 TONNES ON EACH. REAR SPIKES
      € SPEED: 17MPH
      € STRENGTH: UNIQUE DESIGN
      € WEAKNESS: UNIQUE DESIGN
      and for real robots, Im going risky
      (the new) TURBULENCE
      MERLIN
      STORM 2}}
        Thats not enough.
          Are you sure Chris? It says 8 robots:
          MeCannibal
          Kay 9
          Crusher C.U
          Turbulence
          Merlin
          Storm 2
          Actually youre right!
          Now put in Big Nipper and the brand new Kronic
            SORRY, I cant do that! Removed Big Nipper and Kronic, and add Sky Blast
            SKY-BLAST
            € WEIGHT: 100KG
            € ARMOUR: FRONT/TOP 10MM HARDOX. REAR/SIDES 20MM ALUMINIUM
            € SHAPE: BOX WEDGE WITH CONVAVE FRONT, ALSO CONCAVE SIDES AND A ROUNDED REAR
            € MOTORS: 4 S28-300 MAGMOTORS AT 24V = 80HP
            € LOCOMOTION: 4 VULKALON WHEELS
            € DIMENSIONS: (L) 50CM (W) 40CM (H) 29CM
            € COLOUR: SKY-BLUE WITH WHITE CLOUDS
            € WEAPONRY: A FIRESTORM STYLE FLIPPER ON TOP. FULL-PRESSURE CO2 FLIPPER, CAPABLE OF FLIPPING 3000KG.
            € SPEED: 32MPH
            € GROUND CLEARANCE: 2MM AT SIDES
            € STRENGTH: SPEED AND POWER
            € WEAKNESS: NONE!
            Thats it
            PS. I know I forgot Hyena in the eariler post, but keep it.
            So thats
            MeCannibal
            Kay 9
            Crusher C.U
            Hyena
            Turbulence
            Merlin
            Storm 2
            Sky Blast
            That should do!!
              Ok Ill enter
              Panic Attack
              Zeus
              Diotior
              Gravity
              TAN
              Black Hole
              WBC
              and Big Nipper.
                Heres my line-up:
                1) Psyclonised (1)
                2) Yet Another Cut Above The Rest (10)
                3) GeForce 4.0 (14)
                4) ForcePower 5.0 (16)
                5) Wedgas Revenge
                6) Axeon 2.0
                7) SOR 5.5
                Aneurysm
                Although if I can, I might try and update the stats before signups close. Good to see a nice range of entries as well so hopefully it will be another great tournament!
                • #23
                  Tim, you cant do that - the rules on entry say:
                  There€™s a MAXIMUM of 3 realies per squad, and MINUMUM of 0
                  You have:
                  Panic Attack - REALIE
                  Zeus - REALIE
                  Diotior - REALIE
                  Gravity - REALIE
                  TAN - REALIE
                  Black Hole - REALIE
                  WBC - REALIE
                  and Big Nipper - REALIE
                  8 REALIES. Try making up some vapourbots and puttiong them in instead.
                  • #24
                    hey guys, Im posting this from a sloooooooooow comp... some points
                    1 Paul Cuomo; good having you aboard. You seem a knowledgable vapourboteer. Ill have a global inspection on your vapours, since all of them are brand-new ofcourse
                    2 With Paul, considering all reserved spots will be claimed, this tourney is filled with 12 entrants!
                    3 Timmy, read point 2
                    4 Timmy, read Pauls reply (and the rules for that matter)
                    5 Andy, good seeing you around
                    • #25
                      Sorry about this change of mind, but Id better do it before its too late.
                      Seeing as Kay 9 is unbelievably unrealistic, I think Ill change it for another vapourbot in my arsenal. Its called Great Bite Shark
                      GREAT BITE SHARK
                      € ARMOUR: FRONT 8MM HARDOX. SIDES/REAR 8MM TITANIUM
                      € SHAPE: BOX WITH SIDES SLANTED AT 10*. TOP SHAPED LIKE PYRAMID WITH CUT-OFF POINT
                      € MOTORS: 2 x B42-500 60V MAGMOTORS = 64HP
                      € LOCOMOTION: 2 x SUFFLING PADS WITH VULKALON
                      € COLOUR: OCEAN BLUE WITH THE €˜JAWS 1€™ POSTER ON TOP
                      € WEAPONRY: HYDRAULIC AXE POWERED BY 3000PSI, PRODUCING 4TONNES
                      € SPEED: 15MPH
                      € STRENGTH: WEAPON POWER
                      € WEAKNESS: WEAK AGAINST FAST RAMMERS
                      So know its:
                      MeCannibal
                      Great Bite Shark
                      Crusher C.U
                      Hyena
                      Turbulence
                      Merlin
                      Storm 2
                      Sky Blast
                      Sorry about this, but I just decided on it
                      • #26
                        Im sure there used to be a robot called Great Bite Shark back in the old days. Does it ring a bell with anyone else?
                        • #27
                          No Frank, that robot is Great White BITE
                          • #28
                            No, Franks right... Great Bite Shark... I wanna say it was one of dundindans later creations? Perhaps someonell back me up on that one.
                            • #29
                              youre all awesome
                              now gimme some more stats
                              • #30
                                Actually, discount what I said, I just remembered. It was Great Fight Shark, although Im equally clueless as to whose it was. Pretty sure it wasnt Dundindan, I think he only entered the smile robots.
