Quite frankly, Im getting bored. Ive been getting no inspiration to do my real robot tournament, and the forum appears to be empty. Having watched the entire of Robot Wars Series 1, Ive decided maybe a vapourbot tournament may inspire me a bit more...so, basically, Im re-inventing the wheel. A RW1 style tournament. Ive no idea how successful it will be, but I may as well give it a go.
RULES
-I need six people to enter six robots.
-Each robot in a persons team is to be designed for a specific trial (I cant have two robots on the same team entering the sumo).
-In S1, there was no real weight limit. Here, the minimum weight is 5 kilos, the maximum is 95 kilos. Youll need every resource you can get here.
-NO real Robots, at all.
-The Gauntlet is the same as the S1 Gauntlet.
TRIAL GUIDANCE.
1: Sumo - Your robot should have a low front Ground Clearance, good traction and, above all, should be as heavy as possible.
2: British Bulldog - Good traction and a powerful weapon is required here.
3: Football - Good control and something to collect the ball.
4: Stock Car - It must be small, fast and agile.
5: Maze - It must be small in size and have good control.
6: Snooker - Again, something to collect the balls.
STATS NEEDED
Robot Name.
Weight.
Body Shape.
Dimensions.
Weight Class (if known).
Speed.
Turning Circle.
Ground Clearance.
Armour.
Weapons (if any).
Flipping Combat (in other words, can it right itself, or run inverted, or is it literally flip and its dead?).
Extra Features (if any).
Trial Built for.
Gauntlet Path (Maze, Ramps, House Robots).
I have no idea how successful this will be, but I hope I get a few looks.
RULES
TRIAL GUIDANCE.
STATS NEEDED
Robot Name.
Weight.
Body Shape.
Dimensions.
Speed.
Turning Circle.
Ground Clearance.
Armour.
Weapons (if any).
Trial Built for.
