The Crash & Burn Tournament 2
  • The Crash & Burn Tournament 2
    Wouldnt a drum be vulnerable to a direct disc hit because of the surface area, and the fact drums are very susceptible to going off balance?
      regular discs are more vulnerable to going off balance, and a drums surface area is just as much as any robots front would be, I believe the surface would even slowe Tempest down a bot, like how Alex Ramthrax works
        Look up Mini Touro on youtube, youll see an exception drumbot that survives a lot of spinners....
          I dunno, this is going to be bloody CLOSE.... but I think this will go to the judges and Tempest will be the champion... but...
          Eh, no need to explain the details...
            We have one more battle to settle before the Grand Final Battle.
            3rd-place Play-Off
            SUNCUST vs. Infusion
            Roboteers, stand by!
            Booth 1: SUNCUST
            Booth 2: Infusion
            House Robots: Ivy-X, Obelix Bulguous
            3!
            2!
            1!
            ACTIVATE!!!!
            A quick start for SUNCUST as it makes its way all over to where Infusion is, at the other end of the arena. Infusion suddenly bursts to life itself and slams into SUNCUST immediately, the spinning rim fuelling the Kinetic Boost, which is able to penetrate the jaw and slide under it! Tony is indeed alarmed, but he has no time to get the hell out of there as Aaron is taking him for a tour of the arena, and that tour is going to end right in a CPZ!!! WHAM! Bouncing off the wall is SUNCUST, and onto the left side of Infusion€™s wedge. The house robots jointly leave their CPZs and head for the competitors. Obelix gets there first, and smacks his hammer onto the wedged SUNCUST! BANG! No damage; however Infusion and Obelix have pinned SUNCUST, and in comes the new house robot, Ivy-X, with the spinning chains. CRASH! CRASH! CRASH! CRASH! Repeated blows against the 12mm titanium rear of SUNCUST, and it€™s hard to imagine any one taking such punishment...BANG! Obelix lays down another huge blow with the hammer, and the 12mm titanium actually has been dented badly now! Infusion moves away, but SUNCUST doesn€™t have a chance to get the hell away because Obelix drives forwards further, and slides under the skirts of SUNCUST, wedging him and pinning him against the wall! BANG! Another echoing blow leaves Tony in quite a state, and that€™s saying something even though he knows he€™s not won the tournament. Infusion, however, decides to have some fun with the house robot, Ivy, and wedges under her by surprise. Obelix notices absolutely nothing, and BANG! Another blow given to SUNCUST! The Watcher is going starkers out there, trying to decide to free SUNCUST, or tell Infusion off. In the end, it€™s his fellow comrade that he thinks about and rams Infusion. Bad move!
            CRASH!!!
            The 10mm hardox rim meets the front wedge of The Watcher and sends the ref flying the across the arena! NOW Obelix turns around with wrath: you don€™t do that to a referee. But before he does...BANG! Obelix hammers SUNCUST once more, then un-wedges him, turns around for real, and bellows a path towards Infusion. Aaron simply smirks, and points Ivy at Obelix. SUNCUST...SUNCUST? Wakey wakey? Obelix halts, then decides to try and move around Ivy to get to Infusion. It doesn€™t work. Infusion simply rams Ivy into Obelix€™s side as he turns, and pushes the pair of them towards SUNCUST in the CPZ. Oof. SUNCUST is nudged by Obelix, who gets out of the way, and attempts to come towards Infusion€™s side, only for the recovered refbot to smack into him blindly and send the pair of them back into the pile of metal. Infusion un-wedges Ivy and smacks into her with the rim.
            CRASH!!!
            WHOA! That was...incredible. Ivy has just lost several side panels, made of 7mm Hardox, and is exposing internals, very clearly. Infusion smells blood, but also smells trouble as Obelix and The Watcher close in. Infusion turns to use the wedge and smacks into Obelix. BANG! The hammer comes down on Infusion€™s top but is withstood largely. He wedges the hammerbot and pushes him into The Watcher, who admits defeat and goes to count-out SUNCUST, who has done nothing since the last hammer blow he suffered, and must now settle for 4th place.
            WHAM! Obelix is smacked against the wall, and lands on his side. The hammer comes swinging out but all it does is spin Obelix around. Tempted to rip off the hammer, Infusion does not, and instead chases down the wounded Ivy, who isn€™t spinning at all and instead goes to hit the pit release button, but Infusion gets her anyway.
            CRASH!!!
            The other side gets it this time, but nothing happens...except for the fact that Ivy ain€™t movin€™ no more! Infusion wedges her, as the pit descends, and stuffs her onto the arena saws. BZZT! Lovely sparks, and I€™m surprised The Watcher isn€™t coming over to help. Then again...it IS Infusion. Speaking of Infusion, he€™s just smacked Ivy€™s exposed side!
            CRASH!!!!
            And...GAH!!! That€™s a motor...and it€™s cracked open! Oh...my. The Watcher stays put, not wanting to provoke the mighty Warrior SKF look-a-like, as he digs in once again!
            CRASH!!!
            More side panels gone, joined with a wheel! Can somebody please stop this?! Obelix finally rights himself, but decides to end the match, and goes for SUNCUST, immobile in the corner. But...
            CRASH!!!
            Another smash to Ivy, and it€™s even more destructive! Gears sent flying in pieces, and dislodging the spinning chain mechanism completely, all of this and a battery too! Obelix wedges SUNCUST, but can€™t get him off the wall easily. BANG! The hammer thuds on top of SUNCUST, and finally we get a hole! Obelix drags SUNCUST backwards as Infusion continues his grisly slaying!
            CRASH!!!
            More batteries, wiring, and motors get it, also a speed controller, and Ivy is just completely laid to bare, now, most internals strewn out, and armour dispatched, the chassis just brutalised! Aaron finally takes five as Obelix swings SUNCUST around, and shoves it down the pit.
            CEASE!
            It€™s fourth for SUNCUST, and the scrapheap for what should have been a fearsome house robot that was proved the opposite.
            +1>INFUSION CLAIMS 3RD PLACE!!!
            Well, we€™ve come to it at last. The final that you all anticipated without blinking...for 30 seconds. Let€™s see how these two unholy lords among robots got here.
            Sheer Heart Attack
            - Destroyed Quocunque Jeceris Stabit
            - Pitted The Deer
            - Immobilized Aneurysm (4)
            - Destroyed Cyclone Force 2.5
            - Destroyed Flank Attack: DT
            - Pitted SUNCUST
            Tempest Evil-er-oution (14)
            - Destroyed Wheely Big Cheese
            - Destroyed Back to Rock II
            - Destroyed Big Nipper
            - Destroyed Aquarius (5)
            - Destroyed Son of Ripper 5.0
            - Immobilized Infusion
            All right...IT€™S THE GRAND FINAL BATTLE!!! LET€™S GET IT ON!!!
            +1>Sheer Heart Attack vs. Tempest Evil-er-oution (14)
            Booth 1: Sheer Heart Attack
            Booth 2: Tempest Evil-er-oution
            House Robots: Tira-san, Growler, Exa-Gore-Ic: AI, Matilda
            3!
            2!
            1!
            ACTIVATE!!!!!
            HERE! WE! GO! Both competitors come flying right out at each other, really fired up to start laying the hurt on the other! That drum doesn€™t look slow at all, in fact it€™s going quite fast, and so is Tempest€™s ring, but they smack into each other very quickly!!!
            CRASH!!!
            First hit! Neither had fully spun up yet, but it sent a load of awesome sparks into the air! Furthermore, it has sent Tempest a little bit away and given SHA a huge advantage; to push and slam and ram and bam and whatnot! Without pausing to think, Martijn directs SHA towards and into Tempest with almost the force and speed of an F5 tornado, before the latter can get away! Tempest, thanks to his cylindrical shape, is able to move around him, but finds SHA€™s drum at the ring again immediately! Martijn isn€™t letting go of this battle that easily, and he€™s pulling out all the stops to make sure he gets it! Frank growls at this, as those are his plans too, and moves Tempest back, only for SHA to catch him again and smack him into the wall!
            Tempest however is grateful for this, as it sends him flying out of harm€™s way and gives him a break for him to get that ring and hooks spinning at dangerous speeds! SHA backs off, spinning up his own drum now, anticipating when Tempest reaches full speed, and a second after this his own drum is at full speed, just as Tempest comes flying towards him! SHA drives forwards in a courageous effort, and the long-awaited clash of the titan spinning weapons occurs!
            CRASH!!!!!
            WHOA!!! That is SOME air for Tempest! It must have flown about three feet into the air! A mighty blow to say the least, but Martijn does not look worried at all, considering that SHA€™s drum has largely survived the impact. As a matter of fact, Tempest is quite the same, enduring that blow to the extreme, and now both spinners are again beginning to become dangerous whirlwinds of destruction! Both Martijn and Frank glance at each other and smirk, as they come flying into each other at storm-force winds!
            CRASH!!!!!
            Tempest plays pinball this time, ricocheting off the drum and into the arena wall, halting near the flame pit but not having gained the energy to go airborne, and Martijn takes matters into his own hands as SHA makes a bull on parade () and stampedes towards Tempest. Tempest moves away quickly, but a nifty turn from the tracked bot and SHA is on course with Tempest, who is spinning too slow now to do any damage! Likewise is SHA, but he rams Tempest now with the drum and tackles it into the arena wall. This would have given Tempest a chance to escape, but unfortunately the along-the-wall hit smashes Frank€™s feared spinner into the angle grinder! With his opponent trapped, SHA backs up and spins around quickly. Frank takes the chance and steers Tempest away from the wall, but that€™s what Martijn was hoping for, as a fully-spun SHA whips around and barrels into Tempest with the drum!
            CRASH!
            More of a dull THUNK than a CRASH, Tempest is nonetheless smacked upward, the other side of the ring balancing Tempest as it falls timbers onto its back, but it barely has time to register its newfound invertedness before the titanium drum smashes into him again! It€™s not even a moderately big hit, but it had the effect that Martijn wanted; Tempest is bounced again, but falls right back onto SHA€™s drum! The drum is not spinning at the moment, but that€™s okay for Marti, as he turns to try and smack Tempest into guest house robot Matilda€™s CPZ. To his displeasure he finds that Tempest can€™t be kept on the drum while SHA turns around, otherwise he€™ll fall off. Shrugging this off, he bites the bullet and goes for a huge ram against the arena wall!
            WHAM!!!
            Frank winces, as even he could feel that one. SHA seems to be controlling this battle, as Tempest sails over the chassis of SHA and lands behind him. Frantic to get this Grand Final back on even footing, Tempest races away as the rear end of SHA moves in on him, and begins spinning up. Martijn isn€™t smiling anymore; he€™s just allowed Tempest to get a free spin up, and that could be devastating. SHA turns once again, the drum back at full speed, as is Tempest€™s ring, and the two come to blows in their heated combat!
            CRASH!!!!!
            Tempest and SHA part ways once again, flinging the other away with sheer brute force, and come to rest at opposite ends of the arena! AND TEMPEST HAS STOPPED SHEER HEART ATTACK€™S DRUM!!! OH NO!!! Martijn is visibly alarmed, and tries to get it working, but it€™s no go! Tempest however IS spinning up. And approaching fast. Again, with no time to think, SHA has to bear the earlier blow and box-rush Tempest€™s spinning ring!
            CRASH!!!
            Tempest is the one sent flying after that one, but it€™s crystal clear that SHA no longer has a working drum. Martijn is still trying to figure out how to get it going again, but Frank has a major confidence boost after seeing this and steers Tempest right back into the direction of the wounded SHA! SHA box-rushes again, indeed so quickly that it almost startles Frank, but he keeps his composure and meets the drum head-on!
            CRASH!!!
            What a hit! Tempest again receives the kick-back he wanted...but not in the right place! It€™s right in Tira-san€™s CPZ! Tira doesn€™t want to leave the house robot ranks without leaving a final mark, and does so on Tempest€™s ring!
            CRASH!
            A minor hit, but it€™s stopped Tempest from spinning up, and SHA pounces at this golden moment, smacking into Tempest with the drum and pushing it into Tira. Tira pushes back and Tempest is slid away and thankfully out of range, though SHA is after him in a reckless abandon for his own safety! Frank taps the controls and Tempest quickly dodges a charge from SHA, but the latter swerves about and bulldozes towards the spinner again! This time Tempest meets it fully!
            CRASH!!!
            THE DRUM IS LOOSE! THE DRUM IS LOOSE! Sheer Heart Attack is in major trouble now! The drum has been dislodged from one of the sides and is sliding out of place in front of Martijn€™s robot! Martijn thought this would happen once the drum stopped, and isn€™t surprised anymore, his only thought is to ram Tempest to hell now! Frank is focused mainly on avoiding this, but it€™s become hard to do now as SHA charges in quickly, and now Tempest can€™t dodge fast enough because SHA is already in his face! WHAM! Tempest is rammed and brought to the arena wall! WHAM! Another ram, and Frank is now doubting what damage he€™s done to SHA, as it appears that SHA, other than the lack of a spinning weapon, has been mostly unaffected! Tempest is again moving away, but finds himself moving faster than usual. That€™s because SHA has caught him again and pushes him into Growler€™s CPZ! The 375kg junkyard dawg happily chomps down on the ring spinner, as Frank can€™t get Tempest away, and SHA seeing that Tempest is trapped, goes for the pit release button and nails it!
            As the pit descends, as are the number of seconds remaining in this Grand Final with just under a minute left, Growler holds Tempest over the arena saws, and BZZT! SPARKS! We have some major sparkage until Tempest right now, and Growler moves him away - WAS THAT RUBBER I JUST SAW? It€™s thin, but a strip of rubber has been torn away from one of Tempest€™s tires! But is it too little, too late? Martijn does not seem to think so, as SHA smacks into Tempest even before Growler has released him. Growler now does so, opening those competitor-devouring jaws, but SHA forces Tempest back into that CPZ. Growler lower the jaws and shoves Tempest AND SHA away with his snout, and Tempest is on the move again. SHA follows him, having to turn bit since Tempest€™s mobility seems to have been limited by the arena saws, but is spinning once more! SHA pummels into him, not wanting the drum to find freedom on the arena floor just yet. Tempest turns around and suddenly makes a beeline for SHA€™s tracks!
            CRASH!
            Tempest is bounced away, JUST missing the tracks but managing to hit the mangled drum again, furthering damaging it by chipping a tooth off, but of course this leaves him very vulnerable, once again, to a shove by SHA, and Martijn is having it his way as Tempest is AGAIN shoved across the arena and smacked into the wall...NEAR THE PIT!!! But no! SHA is unable to turn fast enough to catch Tempest as he makes a break for it and escapes! SHA is in hot pursuit, eager for a pitting, but this late in the game, I doubt he€™ll get it...
            10...9...8...7...
            Tempest begins what must be his tenth spin-up this match, as SHA careens towards him, and Tempest once again heads for the tracks!
            6...5...4...
            CRASH!
            Again, he just misses them, but gets the drum and it gets a tear in it now! SHA is spun around, but backs into Tempest and even from the back begins to push him away!
            3...2...1...
            Oof. Tempest is pinned against the wall!
            CEASE!!!
            THAT...was a final for sure! Before we have the judges€™ decision, let€™s get some highlights of that exciting battle!
            *Tempest and Sheer Heart Attack colliding with both weapons, sending each other flying*
            *Sheer Heart Attack flipping Tempest over with the drum*
            *Tempest disabling Sheer Heart Attack€™s drum, and then dislodging it*
            *Sheer Heart Attack pushing Tempest into Tira-san€™s CPZ and getting him damaged*
            *Growler dropping Tempest over the arena saws*
            *Tempest chipping Sheer Heart Attack€™s drum once again*
            Okay, the judges decision. Here it is:
            Sheer Heart Attack - Tempest Evil-er-oution
            Strategy = 2/5 - 3/5
            Style = 4/10 - 6/10
            Control = 11/15 - 4/15
            Aggression = 14/20 - 6/20
            Damage = 7/25 - 18/25
            TOTAL = 38/75 - 37/75
            The battle was long and intense, but now the fact we craved for so long stands before us. Tempest Evil-er-oution fought on with the strength and bravery of an iron-clad knight, and the intensity of a tornado, but in the end...
            +2>SHEER HEART ATTACK IS THE WINNER OF THE CRASH & BURN TOURNAMENT 2!!!!!!!!!!!!
            CONGRATULATIONS, MARTIJN M BENSCHOP!!!
            *hands Martijn his trophy*
            Now, the temporary seedings for The Crash & Burn Tournament 3 have been done. They are...
            1. Sheer Heart Attack
            2. Tempest Evil-er-oution (14)
            3. Infusion
            4. Super Upright Natural Clamper Unsurvivable Shover Thingy [SUNCUST]
            5. Flank Attack: Divisionary Tactics
            6. Son of Ripper 5.0
            7. Axeon (13)
            8. Killotine: EVO (9)
            9. Cyclone Force 2.5
            10. Aquarius (5)
            11. The Disc 5
            12. A Night at the Bar
            13. BIACS-LE
            14. Tengu VII
            15. Salamander III (1)
            16. Cosmic Thunder 2
            17. Aneurysm (4)
            18. Big Nipper
            19. Clawdius Decimus Murderous (2)
            20. Malaria
            21. Turbulence
            22. Die-Ceratops Re-Invertus (6)
            23. Wedge Devolution
            24. Axe-O-Lotl
            25. Baldur Gamma
            26. Leprosy Infection
            27. Liar
            28. Turbo Tails (12)
            29. Enter the May Tracks (7)
            30. Cacodemon
            31. Disco 5
            32. Knightrous Wedge
            The Crash & Burn Tournament 3, hopefully, will start sometime between May and July 2008, by which time I will have some of my ideas for it up to scratch. I€™m actually looking for 16 people to join it, but we€™ll burn that bridge when it comes.
            And so, we bid this tournament adieu...I would like to thank everybody who joined this whole thing, and give them a round of applause. Without you guys, none of this would have been possible. And before we head on out, I would like to pull a Steven McGregor and give out one last award: the Best Reader€™s Award.
            The winner: You all tied.
            Thus, the Crash & Burn Tournament 2, the second major tournament of Team Zlayerz...
            ...is over.
            Comments and thoughts please.
              dgdafgdfs im gonna lose in the first round again next tournament, arent I? :P
              Also woooo, 4 ranked robots
                That had me on edge just reading it.
                  Im very good at being wrong at this prediction lark, arent I?
                  Very well done to Marti for winning, everyone else for being there, and Kody for some extremely awesome fights.
                    AWWWW COME ON, MY FIRST MAJOR VICTORY? YOU GOTTA BE KIDDIN ME!
                    w00000000000000000000000000000000000000000000000t
                    Sheer Heart Attacks successor will have a lot of work to do next time, but hes up for it
                    Congratulations to Frank for putting up a great fight, and of course congratulations to Kody for pretty much the same reason :wink:.
                    Like I said to you, please go for a 16 person tournament next time, Im sure you can pull it off :wink:
                      Well done Martijn!
                      And great work everyone.
                        Overall, I did pretty well, all things considering. Next time, at least Ill have more professional stats.
                        *Hands Martijn Cyclone Forces wrecked disc*
                        Think of it as a monument.
                          Great battles Kody, looking forward to C & B 3
                          Congrats for your first win, Martijn. Im taking that trophy off you in the next series though
                            hahaha yeah right frank. The only think holding Flank Attack back were some damn wheel guards, and now hes got them
                              Ill be back with a new design or a new Infusion Time to up the ante :wink:
                                I will definately be interested in competing next series. =)
