New Blood... New Beginning...
  • New Blood... New Beginning...
    New Blood€¦ New Beginning€¦
    Okay, new tournament as I€™ve decided I€™m getting back into things. I€™m not bothering to write any rules or anything so I€™ll give some basic guidelines. You€™ll catch on hopefully.
    - I need 8 people to enter 1 new vapourbot each (well 7 people, cause Im entering)
    - However this vapourbot must be brand new and never competed anywhere else before
    - Usual rules apply and battles will take place in the RW arena
    - Looking for anyone in the tournament to help with writing battles, please volunteer if you would like to write a couple of fights (however everyone in the tournament must write at least 1 battle)
    That€™s all I can think of, ask if there€™s any questions, go!
    NAME- Disco tech 3
    SHAPE- Invertible box
    COLOR- silver
    WEIGHT- 100kg
    SPEED- 20mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- 9mm under the discs has 0mm at sides due to skirts that will work when flipped
    ARMOUR- 3.6mm hardox
    WHEELS- it has 4 inner wheels
    POWER- Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction connected to the 6 wheels.
    Batteries: 120 x 3000mAh NiCD cells producing 36v @ 9amp
    WEAPONS- It has 2 horizontal flywheels (think 13 black) each spinning at 2500rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheels produce 31.5Kj€™s at maximum RPM but is lethal at around 1 second. It has one weapon on the front and one on the back
    SRIMECH- Invertible
    NOTES- can spin on the spot
    STRENGTHS- It is stunning
    WEAKNESSES- easy to flip if discs aren€™t spinning
      Thanks Martyn!
      1) AJ - ?
      2) Matty - ?
      3) Steve - ?
      4) Martyn - Disco Tech 3
      5) ? - ?
      6) ? - ?
      7) ? - ?
        Ladies and gentlemen, the latest disasterpiece from Team Braveheart!
        NAME- The Riddler
        SHAPE- bowler hat with a small scoop shape at front and back
        COLOUR- green with a white band, purple question mark at front
        WEIGHT- approx 100kg
        DIMENSIONS- 90cm X 90cm X 35cm
        SPEED- 15mph
        TURNING CIRCLE- 0m
        GROUND CLEARANCE- approx 0mm for scoops, 8mm all round elsewhere
        ARMOUR- 4mm Grade 5 titanium
        MOVEMENT- 4 inner wheels
        POWER- 2 x C40-500 MagMotors. These will run at 36v and produce approximately 12hp.
        WEAPONS- 180 degree pneumatic axe with twin heads, appears similar to a walking cane. It is powered by 2 x CO2 tanks running at 160psi and uses the rack-and-pinion mechanism. Hopefully, the hammer can produce between 30-40 blows per fight.
        SRIMECH- the axe
        NOTES- flies the Scotland flag
        STRENGTHS- fast and manouverable, a mighty thwack, good pushing power
        WEAKNESSES- possible spasms, limited blows, average armour for the Hardox Age, stats may be complete rubbish
        Piccy here: http://img296.imageshack.us/img296/3128/theriddlervapourbotza1.pnghttp://img296.imageshack.us/img296/3...pourbotza1.png
        Hope thatll do, Mr J and welcome back to Bedlam!
        (Message edited by Steven_McG on December 24, 2006)
          Ill give it a shot. Ill give you details in a moment or two.
            amazing Andy, please reserve me a spot
              Ooh.....hold me a spot....I need to get my creative brain in gear....
                WEIGHT: 100 kilos
                BODY SHAPE: Spawn Again
                SPEED: 12mph
                TC: 0
                GC: 0mm at the flipper plate, 2mm at the side, 3mm under the flipper and blocker.
                WHEELS: 4 inner
                ARMOUR: 6mm titanium
                POWER: 3x 12v batteries, powered by some MagMotors...you know, the usual.
                COLOUR: Layers of Black, Grey, Red and Yellow, with a Grey flipper and Black blocker.
                WEAPONS: An enourmous front flipper capable of tossing about half a ton. It can literally flip a robot out of the arena halfway from the arena...and trust me, Ive seen it do it. No, seriously.
                SRIMECH: The flipper acts as a srimech. To prevent it getting stuck on its back, a rectangular blocker has been installed, preventing it from getting stuck. It is extremely successful.
                NOTES: If youre wondering how I actually make these claims, its this...the prototype has been made of Lego bricks. I have a whole army of home-made robots which battle each other and Flipperdont 2 is easily one of the most successful.
                STRENGTHS: The flipper!
                WEAKNESSES: For some reason, it doesnt do well against high-speed full-body spinners.
                  Ill steal a spot. Since hardly any of my vapourbots are new and many of them havent competed...I think Ill enter Entropy. Stats can be found on my forum:
                  http://strickenone.proboards99.comhttp://strickenone.proboards99.com
                  If you need stats posted here, then Il do it. Cheers!
                    NAME- Dakkon
                    SHAPE- Difficult to describe - think a smooth Sumpthing with a front scoop. Ill try to knock up a picture.
                    COLOUR- A greenish-grey with flecks of silver
                    SPEED- 18mph
                    TURNING CIRCLE- 0m
                    GROUND CLEARANCE- Zilch for front as is has a titanium strip, the rest varier at over a centimetre
                    ARMOUR- Front plate is 6mm hardox, the rest however is 7mm aluminium over a titanium chassis.
                    MOVEMENT- 2 large wheels behind the front plate, again similar to Sumpthing.
                    POWER- 2x 750 watts Bosch motors at 24v.
                    WEAPONS- A huge single edged pnuematic axe - the recoil is only enough to self right it, and the blade is a quarter circle and weights 5kg, with sections cut out of it to decrease weight. It works similar to terrorhurtz - ie attempts to mash things apart, but only in one direction. It uses four canisters streamed into the piston to produce its power.
                    SRIMECH- The axe does it all - there are side struts from the shaft to aid it in this.
                    NOTES- Other than having a bizarre shape isnt very creative for me - but there again I havent had any losses to react against with my scheming
                    STRENGTHS- Powerful, decently fast, the front armour should protect it from spinners
                    WEAKNESSES- Back vulnerable to flippers and most things, will probably dance like terorhurtz a bit, axe could get stuck in certain things like wood.
                    Ill need to make up a picture of it, which Ill do this week with any luck.
                      Ill take a spot too. I thought of something really interesting to try.
                        Ill pull out of this one to give others a chance. Thanks for all the interest guys!
                        1) Matty - ?
                        2) Steve - The Riddler
                        3) Martyn - Disco Tech 3
                        4) Chris - FlipperDont 2
                        5) Martijn - ?
                        6) Kody - Entropy
                        7) Alex - Dakkon
                        Nick - ?
                        Entries now closed, just need details from Matty, Martijn and Nick.
                          what about bots that did enter a tournament before but never fought?
                            Yeah thats fine too. Anything will do really.
                              Stats for Barrage will be up ASAP
                              At least you have a name for it now
