Team Gore Presents: House Robot Rebellion 2!
  • Team Gore Presents: House Robot Rebellion 2!
    Okay, this is the sequel to my original house bot tournament. This time, its individual fights.
    My upgraded house (vapour) robots will be:
    Exa-GORE-ic: AI
    Ancalagon the Black
    Double Big Mac
    Double Whamlet
    Taki-san
    Tira-san
    Asterixus Heroicus
    Obelixus Bulguous
    (see the previous HRR2 thread for the original HBs)
    More details for my HBs will be posted later.
    I need EIGHT vapourbots, specifically EIGHT people to enter ONE vapourbot. Or real robot if you wish. (e.g: If you are Jeroen and you want to enter your real robot TAN, then go ahead )
    Stats will be required with your robot. It must be a heavyweight. Rules are in the C&BT. NO VAGUE STATS. NO STUPID ROBOTS.
    It will be like a Heat from Series 3 and 5. One-on-one action until we have a winner.
    So, my friends, enter and...
    Prepare for take off!
    Save me a spot mate
      Done
        For the sake of doing something, Ill enter Leprosy Infection, probably the best option for House Robots. The stats are in your tournament. They havent changed.
          Thats you done, Chris. Six more needed (if I can get em). Ill go on MSN and wrangle up the gang.
            Well since its past 10 minutes from my previous post I cant edit it. SOMEONE isnt entering but I dont blame him in the slightest. I still need 6 more people.
              Love Bite V 2.0, same stats as the ones you linked me to from the Spanish Inquisition.
              And some bugger coulda told me Alex was doing the Wars Incarnate again
                Ill give it a go.
                robot name: Hannibal (real robot, mine)
                Weight: 94 Kg
                Weapon: FP Flipper 80mm bore 150 mm stroke
                Armour: High Density Poly Ethylene, Titanium and Aluminium 7075.
                Drive: 2 Litton motors 36V on a Sidewinder speed controller.
                  As this may be the only chance I have of fighting Leo for a while....
                  Ill give it a go.
                  robot name: Wheely Big Cheese (real robot, mine)
                  Weight: 99 Kg
                  Weapon: FP liquid draw Flipper 75mm bore 450 mm stroke, custom valves.
                  Armour: Titanium
                  Drive: 2 CIM4 motors 24V on a Sidewinder speed controller.
                  Tactics: send them out of the arena.
                  Weaknesses: NOT THE AXLES, THEY ARE SOLID TITANIUM BAR (over an inch thick), IT WAS FIXED AFTER TORNADO(?) BROKE THE THIN ONES IN SERIES 4/5.
                    I always thought it was the welds between the axles and the wheels that gave out, not the axles themselves. Live and learn.
                    Might come to your event in April James, still thinking and planning for it.
                      Excellent. 3 more people needed, (2 if Tony gets his vapourbot in :P) and then Ill go into more detail about the house robots.
                        Archangel time I think....
                        http://www.alexjholt.tkwww.alexjholt.tk as per usual.
                          A form has been requested, so...
                          Name:
                          Shape:
                          Colour:
                          Drive:
                          Armour:
                          Weight:
                          Speed:
                          Weapons:
                          Srimech:
                          Strengths:
                          Weaknesses:
                          There you are.
                            Boo
                            As a favour for Kody, Im entering with:
                            Shape: Invertible box
                            Colour: Well it was a choice of either buying paint or a pie, and the pie won, so it is unpainted.
                            Drive: 4 wheel drive, keep things simple with 2 motors, chain drive
                            Armour: A mixture of a steel chassis and 4mm steel panels covering the major parts, and 5mm Ali plate over the not-so-important parts
                            Weight: 98KG Ish
                            Speed: 10 mph, acceleration is fast.
                            Weapons: A wedge at the front.
                            Srimech: Its invertible
                            Strengths: Its invertible, 4 wheel drive
                            Weaknesses: First bot I have designed in over 18 months or so, not the most high-tech.
                              ive had a look at some of your vapourbots, and i think wbc needs swapping for wbc 2
                              Name: wheely big cheese (2)
                              Shape: same as the old one
                              Colour: red and golden yellow
                              Drive: 2x LEM130 at 36v, 12:1 ratio twin cobra controllers with turbo button
                              Armour: titanium (mostly 4mm, up to 8mm in places)
                              Weight: 100kg
                              Speed: 25mph
                              Weapons: 120mm bore, 450mm stroke full pressure ram, twin buffertanks, twin 2kg bottles, 1 burkett valve and secondary 1/2 burkett (varies power)
                              Srimech: dont need one, runs and flips both ways up.
                              Strengths: if wbc, storm 2 and gravity had a baby....
                              Weaknesses: dunno, its not finished yet.
