Mute
  • #31
    Mute
    But doesnt that happen when you self right as well?
    • #32
      Mute
      The bend is due to deceleration of the flipper - when it hits the end stops the flipper flexes and tries to carry on moving. When we are upside down this cant happen as the flipper isnt moving until the rams are fully extended. Only after the rams are fully extended will Mute self-right as we use the momentum of the rest of the robot to carry us over.... and over.... and over...
      • #33
        Mute
        Being able flip fequently without worrying about exhausting the gas bottles is probably better, no?
        • #34
          Mute
          wow, must have a fair bit of speed there to be able to bend it like a bannana...what bore rams you using? Ive heared you can fire the flipper in 0.01seconds or somthing crazy like that..
          Dave moulds
          Team Turbine
          • #35
            Mute
            Um, on a similar note, how are the rams restrained? Do you have the end caps from hell, or is something else getting wrecked by this kind of force?
            Fluppet
            • #36
              Mute
              Mutes rams (four in total) are all 1.5/38mm bore and we fire them with a couple of home made valves. Under no load conditions the valve/pipework can pass enough gas (assuming pressure remains constant at around 40 bar) to completely fill our front rams in 0.01 seconds.
              The rams are homemade and are nothing too special, although they are a bit chunky to cope with the duty. Cylinder wall is 6mm thk, front end cap is upto 10mm thk stainless steel, and the rear is upto 20mm thk stainless steel. We use tie rods to hold the whole thing together which are again stainless steel.
              We do have to regularly inspect the rams, mounting brakets and chassis where the rams are attached to check for bending but this isnt really a problem.
              • #37
                Mute
                How many high power flips do you have before the tank starts to run out?
                • #38
                  Mute
                  Earlier in the conversation it was mentioned that Mute has about 50 flips, if they dont waste liquid CO2.
                  My calculator tells me that, if the stroke (can anyone tell me the correct stroke?) is 100 mm, 1 action uses 14L of gas(7l per ram). 3 kg is */-1500L. So, up to a 100 actions are possible.
                  • #39
                    Mute
                    I think the rear rams are about 90mm stroke and the front ones are about 190mm, but Dan and Adam will know more then me about it!
                    • #40
                      Mute
                      Alan your almost right, its 80mm on the rear and 215mm on the front or there abouts anyway.
                      50 flips is about right assuming we run on gas and dont start pulling liquid. 100 flips would be possible I guess if the temperature remained constant and there were no leaks but its hard to tell as we use the flippers randomly depending on which way were heading.
                      Also we can run with upto 4Kg on board if its a warm day but 3Kg is more the norm.
                      • #41
                        Mute
                        I have to say that Mute is one of the more brillant robots of the combat robot world. It adds more action in flipping and self-rghting.
                        • #42
                          Mute
                          Daniel - where the hell have you been!?
                          You better come to the Winter Tour matey! Were all missing you and Adam and mainly Jez
                          Mr Stu
                          • #43
                            Mute
                            How much did it cost to build Mute in all?
                            (Message edited by kevin on August 19, 2005)
                            • #44
                              Mute
                              Would it be possible to build a featherweight version of Mute?
                              • #45
                                Mute
                                Thats a stupid question, there is no perfect answer, do you mean a featherweight with two flippers? If so, then yes its perfectly possible but stupidly pointless in a featherweight. As to the how much mute cost, its cetainly worth over two grand.
