One of my many designs is to build a LW drum spinner for Robogames, I was wondering what would be a good motor for the drum? I did see in the Riobotz book that they use Magmotor s28-400 motor to power the drum, is that still viable? Could I use an Ampflow A28-400?
LW spinner
The A28-400 motor is (or was) a very popular motor for lightweights. They run very hot, so the new fan-cooled version is a good option and you definitely need to get a spare set of brushes as they often chip during large impacts, which causes overheating.
The motor's peak power output is about 3.35 Kw and it's weight is 3.13 Kg; nowadays you can get a more powerful brushless motor that weighs less and costs less IE something from the Hobbyking Rotomax range. The downside to using large brushless motors is that they run at higher voltages than most drive motors, so you need to run dual battery packs or hunt around for HV drive motors.
