Originally posted by daveimi
View Post
Speed Controllers Recommendations?
It would probably be a more reliable setup to use a bang bang style controller using relays, servos and microswitches or with servos making direct connections between wires giving 'full on or full off' control. Although this can make steering difficult it will probably be less prone to breaking from too much current than a joystick.
info@teambigbro.co.uk i think this might work aswell
ian@teambigbro.co.uk i have a wotty 360 for sale if interested.
Interest definitely, I just do not know what I need, an excerpt of my mail to Ian Watts...
Single Channel Controller for the Weapon of Luzifer
Continuous current 160A
And Surge Current 300A
I have in my Robot this Weapon engine...
http://www.robotmarketplace.com/products/0-A28-150.html
The Stall Current is 285A
Where the controller for this?
And the most important question, for me, how big is the controller and what he weighs?
And of course, what is the price?
Do you really need controlled movement
Ahh the watty speed controller is dual chanell.
The Controller make Maximum Current 160 Amps per Channel for 5 minutes
and important ---Attempt to draw more than 200 amps per channel from it.---
The Engine Stall Current is 285A, the Wotty must therefore be Connected so...
Also the Wotty Duall Channel, would be so the right thing!
i have a wotty 360 for sale if interested.Last edited by IceMaster; 26 September 2013, 22:42.
What would be even better...
http://www.teamstorm.com/storm2/speed.htm
that would be really perfect for Luzifer!
As well as the old Storm i have two 4QD-200 for the Drive and search a Controller for my weapon!
If I could get this controller, it would be even better!
Know one if you ran as is, or was that just a one time special production?
The Storm II controllers were a custom build - you would not be able to get new ones made.
We now use a MegaWotty (as named by us!), it's a bespoke designed Wotty which runs 2xLEM130's at 36v with no problem. We also use the same MegaWotty to drive Storm II's arm. If we have a drive failure we can swap them over.
Amazing controller !
