its not that big, we had to keep the size down because of the weight of the disc, so if we compaced it in a smaller space, it would be harder to get hold of, nipperier but it keeps the same destructiveness as our future projuct which we havnt started yet.
just an update on Blazer, Ive had it driving around today for the first time. The arm will be finished off tomorrow, so might get the first flip in by the weekend. Ive had to change the layout to be able to fit everything in! The ram now stands vertical in the middle of the robot, which might give better results on flipper.
I now have all the components. Also due to the layout change i should be able to fit two buffers in.
Ive gone for a high flow regulator from Mario de Jongh which should eliminate the necessity of buffer tanks. A good thing as I was scratching my head wondering where I could make room for one. Its pretty much a direct fit onto the gas bottle so the plumbing is greatly reduced.
Im going for a horizontal ram working an arm. The only thing that Im short of is time (again)
Still no thoughts as to a name but thats no problem.
