Running tracks from engine
  • Running tracks from engine
    Hello everyone i want to run tracks on my robot off a minimoto engine but how do you set it up so the one engine can run each track indipendently thanks
    chris
    Re: Running tracks from engine
    You'd need 2 clutch mechanisms to engage / disengage each drive side .... plus a reverse gear on each.
    OR The engine could drive a hydraulic pump and thus hydraulic motors.
    A really expensive and PITA build
    The alternative would be a single wheel drive engine combo that rotates 360... NO tracks.
