Name.. dunno yet
Drive Bosch: 750s at 32v 4wd
armour: hardox, titanium, steel + whatever i find at work
speedo: Vantec
Weapon: Dunno, maybe a spinner, maybe a lifter, maybe nothing.
notes: Better then craigs.
Picture on profile of Maxus so far.. Weapon is going to be interchangeable from a mag powered egg beater style blade or an actuated set of lifting spikes at the front.
Armours going to be 8mm titanium front and back and 6mm down the sides
Probably going to run it with craigs middle as a cluster bot team thing at normal events.
obviously thats down to the event organiser to either make sure there arena can cope, or to say no its too dangerous im happy driving it around against none flipper heavyweights though, until my new heavyweight is finished.
Ed- Ive got those jet engine designs you wanted in my car. you should be able to machine most of the parts at work, but youll need someone to roll the titanium or stainless for the exhaust to a decent quality and the pettle valve will need spark eroding or lazer cutting.
