Wiring Diagram needed
  • Wiring Diagram needed
    hey,
    has anyone got a wiring diagram to wire up 2 burkert inlet valves and 1 outlet from a electronize rc switch?
    i think i did it wrong so only been firing 1 valve
    Take one side off ALL the solenoids to your negative / common supply.
    Take the remaining 2 inlet solenoid connections to the normally off connection on the electronize switch.
    Take the remaining spade connection of the exhaust valves solenoid to the normally on.
    The above should work fine BUT the exhaust solenoid will be permanently on.
    Connecting the inlet AND exhaust solenoids to seperate normally off relay contacts should give you independant control and an off position for both inlet and exhaust.
    (Message edited by woody on November 28, 2005)
      thanks alot woody
        AND fit a Diode accross the solodoid. Bar to +
        That stops EMF which can and quite often does cause either missfires or radio intereference.
        I advise an IN4004
        Mike.
          oh and ignore mike lambert!!!
          no reason just ignore him
            I think id better put a diode in then...due to the fact my robot missfired about 5 times at the last event.
              i think in this case, dont ignore mike
              although id of gone with a 1N4007.
              (Message edited by thorak nemesis on November 30, 2005)
                Dont ignore James. Hes better qualified than I.
                Mike.
                  please mike, youll make me blush, and its not pretty .
                  mike id only use the 1N4007 because i have some so it would be el cheepo. the only difference betweent them is voltage rating i beleve.
