Vertical Spinner
  • Vertical Spinner
    My team and I are currently designing a vertical spinner bot, and we were wondering what would you guys recommend for things like bearings, pulleys, etc....?
    Deep groove ball bearings on a decent sized shaft and V belts.
      What would you say is a decent size shaft is?
        Depends on the distance between the bearings but 40mm is a good starting point
          Thanks for the help
            We use 40mm shaft/Bearings. On Griffalo. 22" long bar.
              Got a link to the a place that sells the bearings your using? Does the shaft need to be keyed?
