I recently was given a couple LEM 200's from my neighbor who was using them in some go karts, I have an interest in using at least one of them in a HW spinner, I'm just lost at what I should use lipo and speed controller wise for it.
Lem 200
 If you don't mind me asking, did you run just one 12s or did you run some in a series?Originally posted by typhoon_driver View PostLipo - 12s good quality lipo like optipower
 Speed control - I wouldn't bother unless you can come up with something custom. I would instead recommend a solenoid (speaking from experience here).
 I wouldn't shy away from them if you can get a hold of them / justify the expense. They are lovely motors.
 Brushed and super high speed typically don't go together all that well. If you want high speed with a small diameter drum then you need to be gearing up your motor in stead of gearing it down.
 The cheapest, most powerfull motors suitable for a disk/drum are series wound motors. Old startermotors from cars for example.
 Biggest disadvantage is that they are inefficient compared to any other motor. That translates in a lot of heat and the need for a big battery.
