Hi Guy's,
I'm cobbling together my first robot and I would still be very much at square 1 if it wasn't for this forum. Thanks everyone!!
I planning to use a limit switch for my self righter. It's basically 2 levers 50cm long that sit horizontally. They will be powered by a scooter motor driving a live axle with the levers at each end of the axle shaft. When engaged it will travel 180 degrees to the other side and self right the robot. Then doing the oppsoite if needed by reverseing the motors polarity bringing the lever back to where it started. Hope that's clear.
From what I've read it looks like it may be possible to use a double throw double pole relay for this. What do you think?
Any thoughts on this would much appreciated.
Thanks
Ed
Thanks
Ed
