Ground clearance
  • Ground clearance
    What ground clearance is best for the Robot Wars arena? We currently have about 3-5mm.
    Id say more like 10mm, otherwise you may get beached on things like the flame pit
      10mm is good. If its live events then the wooden floor gets chopped up alot (once lost a featherweight down a hole)
        10mm minimum
          Can you use flappy skirts to keep the flippers out or to get under other bots?
