Why does basically nobody use sensored motors? Are they afraid of the hall effect sensors breaking? Even then, surely they'd still run in sensorless mode, assuming you've got the ESC to cope.
Using winch motor for weapon drive?
 The problem is, those first few seconds, or even second are incredibly valuable. It doesn't take long for a rush across the arena to happen and most spinner impacts occur when the weapon has relatively low RPM. The big impacts are few and far between and generally due to chance more than anything else.
 Thermal mass of the motor is another issue. I have no concerns about an etek burning out (my wiring and batteries are more likely to) but I just don't have the same confidence with brushless kit.
 So team shock dabbled with with brushless for our heavyweight spinner...so learn from our mistakes ! For 1st time users forget brushless...we wasted £400 on HK flux Escs - which fell over just by looking at it and a 6.6kw brushless which should have done the job. But we geared it all wrong...as everyone has said starting torque is rubbish. Get a big old brushed motor and solenoid and it just works..we got lots of advice after our brushless failed. Brushed was heavier setup for sure but for 1st time heavyweight don't mess about is my advice. We also looked at winch motor and we almost went this route. I spoke to a great winch company I got off eBay and they could have supplied a decent looking motor with a usable shaft at about 4hp but Rpm was around 1400rpm at 24v. And weight was ilighter than A LEM 170 which was how we went in the end. they did sell me 600a solenoid for about £35 and that worked faultless. Brushless ESCs at this power required are tricky to get hold of. I think brushless for heavies are still in infancy and only good for advanced teams who have deep pockets !!! Hope this helps.
 Thanks for all the replies - some very interesting discussions. Obviously we are not in a position to risk blowing a chunk of our budget on something that won't work - though this could be true of both brushed and brushless. I will come back to you once we have more info on the drive system. It currently looks like it will be chain driven (ratio of 3:1 assuming a rough rpm of 3000rpm from the motor) with a torque limiting clutch in between. The current design looks to be unsuitable for a belt drive - partly because we can't find belts small enough and also we would want two belts and are limited with the depth of the gearbox.
 We have another robot on the go which we plan to use for combat practice. There will be space for a spinning drum so maybe could look into brushless on here as this is more experimental.
 I noticed on eBay you can buy a scooter motor and controller (brushless) for not a huge amount. I wondered whether the controller would be a simple case of connecting the throttle wires together to get it to run. If so this might be an easy thing to implement.
 Thanks!
