So, one of the aspects of using silly-powered brushless motors is that you've got to gear them down a huge amount to make them work properly.
We're looking at two options for gearing down our motor
The first being tried and tested - small pulley meets big pulley, all is well. The issue we have here is that gearing it down to a hopefully safer speed requires some rather small V belt pulleys (unless anyone has a source for 40mm PCD ones?) that will need machining. And I'm not sure we can go below a 40mm PCD, which makes gearing a little too close to our 250MPH tip speed limit that I'm comfortable with - with that gearing, it would be 250.09MPH, assuming 100% efficiency.
Alternatively, we could go down the build-your-own-gearbox route, using timing belts to take the motor speed to something reasonable before attaching it to a standardized set of V pulleys. Along the lines of the Team Whyachi gearboxes - although nowhere near the cost!
Which route do other roboteers take? Should we stick with the KISS route and play the efficiency game? (Realistically, we're probably going to be running at 90% efficiency at a maximum, which puts the tip speed at 225MPH)
Ta
Rob
Team ARC
www.arc-robotics.org.uk
Ta
Rob
Team ARC
